Author Topic: N00b keyboard building guide  (Read 4857 times)
Offline Misterorjoe
« on: Sat, 28 December 2013, 16:10:35 »
After searching for months for my perfect keyboard, I have decided instead to try my luck at building my own keyboard. I have no experience with micro controllers and limited experience with soldering, but I am not too concerned with the programming aspect. I am sure this has been addressed before, but I did not see anything in the stickies, so.. Thanks!
Re: N00b keyboard building guide
« Reply #1 on: Sat, 28 December 2013, 16:13:24 »
wait for ergodox on mass drop, or source the kit pieces urself..
Offline Misterorjoe
« Reply #2 on: Sat, 28 December 2013, 16:54:30 »
The link on the site is dead for the MX switches. Where can I find some?
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
« Reply #3 on: Sat, 28 December 2013, 16:56:00 »
Depends on the switches. For MX Clears, go to mechanicalkeyboards.com. For other stuff, try http://www.originativeco.com/. If you're in the EU, check out 7bit's group buy for switches on deskthority.net.
Offline Misterorjoe
« Reply #4 on: Sat, 28 December 2013, 17:49:16 »
Around how much would that end up costing?
« Reply #5 on: Sat, 28 December 2013, 17:59:03 »
source kit urself, if you're in a developed nation, $400,  if you're in the 3rd world, ~$250
Offline Misterorjoe
« Reply #6 on: Sat, 28 December 2013, 18:41:39 »
Unless I am making a very simple mistake, it seems like it would be more like $200 ?
50 for the switches, 50 for the electronics, and 50 for the PCB, plus the case (i can get that for nothing.)
« Last Edit: Sat, 28 December 2013, 18:50:12 by Misterorjoe »
Offline terran5992
  • One With The Cup Rubber
« Reply #7 on: Sat, 28 December 2013, 20:28:22 »
Some where about there. You have to account for keycaps as well
Offline kyb
  • i love the smell of nopsleds in the morning
« Reply #8 on: Sun, 29 December 2013, 06:27:44 »
That's about right. And that's the common case with DIY boards because: economies of scale.
You as a private person simply can't get the parts cheaper without buying obscene amounts of them.
(PS: Cases usually are the most expensive part if you don't resort to things like acrylic layering. So be happy that you can get it for free.)
Ergodox :o
Offline Misterorjoe
« Reply #9 on: Sun, 29 December 2013, 12:31:51 »
Where do most people get there cases when there isn't a mass drop occurring ?
Offline nzhao20
« Reply #10 on: Sun, 29 December 2013, 13:39:44 »
They post a WTB on the classifieds or buy an expensive one from a GB or buy it from mkb.com or some other retailer, all of which range from 50-200 dollars.
You also have to check whether the PCB is SMD presoldered, and if you're going through the hassle of making a custom keyboard, you probably want it plate mounted.
I think its more like- 40-50$ PCB, 10$ stabilizers, 50$ switches, 20$ plate, 70$ case (unless you get it for free), 20-30 dollars for cheap keycaps, solder would cost you around 10 bucks for all the switches+soldering equipment.
This would get you something that is on par with like a 100-120 dollar board.
I, for one, see no reason to build a custom keyboard if you aren't going to make it something that significantly differentiates itself from the retail competition.
If you want a custom keyboard for like around 200 there is a korean custom with ergo clears for that price, which i'm surprised no one has bought yet.
« Last Edit: Sun, 29 December 2013, 13:48:58 by nzhao20 »
Offline Misterorjoe
« Reply #11 on: Sun, 29 December 2013, 14:00:27 »
I have looked around to see if I could find one. Where are they?
And would this PCB work?
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=537
Offline nzhao20
« Reply #12 on: Sun, 29 December 2013, 14:21:47 »
Wait...you're trying to build a dox? -.-
You should just wait another month for a massdrop. If you build a dox, it will cost you 300-400 dollars without massdrop.
Offline Misterorjoe
« Reply #13 on: Sun, 29 December 2013, 14:57:37 »
Is that how long it will be? I couldn't find any info on it.
Offline Pacifist
  • on hiatus
« Reply #14 on: Sun, 29 December 2013, 15:00:52 »
usually
there have  been like 4 or 5 drops so far
Offline kyb
« Reply #15 on: Sun, 29 December 2013, 16:23:25 »
The cad files are freely available. Shapeways & co. will happily rip you off :)
The most economical thing to do would be laser cutting acrylic plates imho. Or if you know someone with a CNC router/extruder :)
Ergodox :o
Offline Misterorjoe
« Reply #16 on: Sun, 29 December 2013, 16:49:53 »
usually
I can wait a month or so if thats all it would be. I was thinking it would be over a year.
Offline Pacifist
  • on hiatus
« Reply #17 on: Sun, 29 December 2013, 16:53:15 »
usually
its not going to be a year. Probally 3-4 months top
Offline Misterorjoe
« Reply #18 on: Sun, 29 December 2013, 17:06:46 »
usually
What affects the amount of time that it takes? And how can I check to see how much longer it will be?
Offline SonOfSonOfSpock
« Reply #19 on: Sun, 29 December 2013, 17:37:12 »
They start a new drop soon after the previous finishes. You could email mass drop support to see if they have an estimate for the next drop.
« Reply #20 on: Sun, 29 December 2013, 17:41:23 »
usually
no amount of discussion will make the drop sooner..  LOL..
just hang tight.. it's sure to come.
Offline Misterorjoe
« Reply #21 on: Sun, 29 December 2013, 19:02:39 »
Thanks! I'm pretty new to all this.
Offline tbc
« Reply #22 on: Sun, 29 December 2013, 19:05:58 »
http://geekhack.org/index.php?topic=52851.0 - soldering kit gb
maybe relevant?
