Author Topic: That really old worn discolored beige..  (Read 5186 times)
Online tp4tissue
« on: Sun, 29 December 2013, 01:29:40 »
You know that beige on really old abs plastic beige computers..
What would you guys call that...
I am looking to color match it..
This color
but even worse..
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
Re: That really old worn discolored beige..
« Reply #1 on: Sun, 29 December 2013, 01:33:37 »
This color
but even worse..
Wouldn't that colour be called Half-Eaten Apple....?  Or Granny Morgue or even Couscous Deluxe.
« Reply #2 on: Sun, 29 December 2013, 01:35:09 »
They don't just turn that color from being beige, it's smoke damage from cigarets.
Online tp4tissue
« Reply #3 on: Sun, 29 December 2013, 01:41:33 »
yea.. that's the color i'm looking for.. with the abuse
Offline PointyFox
« Reply #5 on: Sun, 29 December 2013, 01:47:24 »
It's usually the UV oxidization of bromine fireproofing added to ABS plastic that turns it the yellowish brown color.
Online tp4tissue
« Reply #6 on: Sun, 29 December 2013, 01:47:46 »
http://www.colorcodehex.com/d6c183/
Hmmmm.. close.. but it doesn't say... I'm old, and my teeth don't work...  I'm looking for the My teeth don't work color...
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #7 on: Sun, 29 December 2013, 13:22:40 »
soak a bunch of tobacco in bromine and iodine, strain it out them use the wash on the item... then seal it in a box with UV lamps for a few months!
Online tp4tissue
« Reply #8 on: Sun, 29 December 2013, 17:11:25 »
Hmmmmmmmmmmmmmmm, I like this idea of using real tobacco coloring.. Though the surface is aluminum so the UV won't do anything, and if I do that to the paint, it'll probably harden and chip.
« Reply #9 on: Sun, 29 December 2013, 20:06:54 »
Oh with metal? Maybe some 'bisque' appliance enamel... like on 1980's stoves.
I used some of that but in gloss white for my custom PC case. It have a very very nice finish.
« Reply #10 on: Sun, 29 December 2013, 20:20:49 »
I had been looking for a few months for a nice beige for my keyboard with beige/grey caps ... and then I found that I already had the right can all the time: Duplicolor beige primer. I started painting with it today, actually.
I have also got Plasti-cote Satin Super "Sand" that is a bit darker and more yellowish. If I used that, it would really look like it was discoloured in the sun.
It is really hard to accurately reproduce colours online without calibrating equipment and such, so  I don't think that posting pictures would do any good.
Offline ideus
  • Björkö.
« Reply #11 on: Sun, 29 December 2013, 20:51:38 »
Does this work on ABS or PBT? I want to paint a couple of spacebars.
« Reply #12 on: Sun, 29 December 2013, 21:54:58 »
NO... it will literally MELT ABS. Vinyl dye is better for plastics, similar shade is available. Vinyl dye also holds up way better to wear than paint. I used it on my MX Revolution which I last did like 3 years ago and it's still like perfect after all the near constant contact.
« Last Edit: Sun, 29 December 2013, 21:56:38 by IvanIvanovich »
Offline Photoelectric
« Reply #13 on: Sun, 29 December 2013, 22:41:20 »
That's interesting--I shall try it when it gets warm again.  Which variety did you use?  DupliColor?
Offline ideus
  • Björkö.
« Reply #14 on: Sun, 29 December 2013, 22:48:42 »
Alright, thank you for the tip.
« Reply #15 on: Sun, 29 December 2013, 22:56:08 »
VHT penetrating I think is better, Duplicolor is also ok.
« Reply #16 on: Sun, 29 December 2013, 23:00:51 »
Thanks--I think VHT vinyl dye is sold in a nearby auto shop.  (Or maybe that's engine enamel, and they sell DupliColor vinyl dye...  Either way I know what to look for now).
« Reply #17 on: Sun, 29 December 2013, 23:24:38 »
I bought mine off Amazon.
« Reply #18 on: Mon, 30 December 2013, 09:49:07 »
You mean you want a yellow-beige Space Bar? ... well, that's the first time I have heard that.
Who knows.. maybe it will catch on.  :))
Offline ideus
  • Björkö.
« Reply #19 on: Mon, 30 December 2013, 10:03:23 »
The space bar is for a FC660M that has stems 85 mm apart, instead of the regular 100 mm posts. I may mod one gluing two stems but I do not like the feeling of a moded one, thus I prefer to paint the original I have in white.
« Reply #20 on: Mon, 30 December 2013, 12:15:43 »
Take apart Leopold and fix the plate to have standard stabilizer spacing, it will never be problem again to have match spacebar :D I'm sure some of lasercutter could take care of it no problem.
Offline ideus
  • Björkö.
« Reply #21 on: Mon, 30 December 2013, 12:28:45 »
This is a really good idea. I'm gonna try it.
« Reply #22 on: Mon, 30 December 2013, 12:47:44 »
Once you do it, you should send picture to Leopold.
Online tp4tissue
« Reply #23 on: Mon, 30 December 2013, 13:12:50 »
So the concept is.. I spray on some  yellow type beige...   THEN.... a clear coat that's tinted brown..
I'm not sure how I'm gonna get that second coat..
« Reply #24 on: Mon, 30 December 2013, 13:18:50 »
Step 1: Get a box
Step 2: A few coats of lighter beige to match the original, but a bit darker/dirtier shade.
Step 3: Spot-spray some even darker beige/taupe from some direction (from some distance, so it does't look like a big circle of paint, but a quick light directional sweep) to get the uneven look.  Basically you want to mist the darker color on very finely.
« Last Edit: Mon, 30 December 2013, 13:21:42 by Photoelectric »
Online tp4tissue
« Reply #25 on: Mon, 30 December 2013, 13:22:58 »
Step 1: Get a box
wouldn't I just get pokadotted spots like this?
« Reply #26 on: Mon, 30 December 2013, 13:26:06 »
Not it you follow step 3 and if you don't get a faulty/cheap spray that sprays in droplets instead of a fine mist.  Some nozzles are bad and spray like that, so always test on scrap cardboard first and begin spraying away from your surface.
