Author Topic: [Q] about Ergo Clears.  (Read 2325 times)
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« on: Mon, 30 December 2013, 06:47:21 »
I would like to ask if anyone has used 65g springs on clears before ?
It's really hard for me to source 62g springs here to make ergo clears.
Anyone thinks 65g is alright to be used on clears to make ergo clears ? =/
& should I lube it immediately or let it wear out for a few months first ?
& is the lube from EliteKeyboards alright for this mod ?
Here's the link : http://elitekeyboards.com/products.php?sub=access,misc&pid=mechlube_2
Thanks in advance.  :)
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
Re: [Q] about Ergo Clears.
« Reply #1 on: Mon, 30 December 2013, 09:04:20 »
65g will be fine (in my opinion). I use an even heavier spring, 67g, and really enjoy it.
See this thread for discussion on breaking switches in before lubing them.
Don't buy the EK lube; buy the thick formula from Originative. This is a mix of Krytox GPL 206 and 1506, and will last much longer than the EK lube and do a much better job. This stuff has really been battle tested.
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #2 on: Mon, 30 December 2013, 09:26:32 »
Cheers buddy for the reply.
I'm not sure if I can get them from originative since they don't accept paypal & I'm currently based in the UK. sooooo yeah  :(
anyways, I was thinking 3g won't be really noticeable so I guess I'll go ahead and get the 65g's.
Thanks for the link, I'll read them up about lubing it later.
Cheers again. :)
Offline daerid
    • Rossipedia
« Reply #3 on: Mon, 30 December 2013, 10:38:07 »
I had 65g springs (from originativeco.com) on my ErgoDox for a while. They felt really good (not too light). I only went back to stock clears after I got my 2nd ErgoDox and didn't want two different spring weights for my clears.
Now I'm hooked on stock clears, such an awesome typing experience.
Offline TheSoulhunter
  • ~ BOOO ~
« Reply #4 on: Mon, 30 December 2013, 10:49:14 »
Even 70g would be fine...
I prefer 65g over 62g, slightly less sticky!
A Ghost From The Past
Offline 1pq
  • Hipster Doofus
« Reply #5 on: Mon, 30 December 2013, 11:22:46 »
I've heard (from VesperSAINT) that as you go up in force, tactility increases, and the switches get better for typing and worse for gaming. 65g vs 62g is not very large, though.
Also, you should use them unlubed for ~4-6 months before you lube them if you want them to be really smooth (longer for maximum smoothness).
main kbs:  87UB (55g)  Custom Filco TKL (62g clears)
WTS JD40, Custom Ergoclear Filco
WTB ROHS Red BBv2 (Topre), OG EK Tri-Color Skull (TOPRE)
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #6 on: Mon, 30 December 2013, 11:30:07 »
Thanks for all the feed backs guys :)
I've tried stock clears on the switch tester but not on a proper board. I kinda like it but I've tried swapping some 62g springs on it and it felt pretty nice I'd say.
I'll try clears with 65g springs then. About lubing I'll figure that out later as I'll have to find a way to get it to the UK. :x
Offline Vintage
« Reply #7 on: Mon, 30 December 2013, 12:28:09 »
Do most people like ergo clears better lubed? I would think that it would reduce the tactility... or am i wrong?
CM QFR w/ MX Reds  | Logitech G900
« Reply #8 on: Mon, 30 December 2013, 12:29:56 »
It depends on where you lube and how much.
« Reply #9 on: Mon, 30 December 2013, 12:33:40 »
any lubed mx switch, when typing fast,  feels LINEAR..
