Author Topic: [IC] - Aerospace grade titanium 60% plates - GB starting shortly!!!!!!!  (Read 57655 times)
Offline The_Beast
  • I like wood ಠ_๏
Re: [IC] - Aerospace grade titanium 60% plates - GB starting shortly!!!!!!!
« Reply #150 on: Tue, 21 January 2014, 21:46:35 »
I would like 1x Poker plate and 2x pairs of tools (so 4 tools).
Beast, I don't see my name in the OP.
Alright, I that was more than likely before I had the quote in with the price. I'll confirm
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #151 on: Wed, 22 January 2014, 02:25:18 »
As long as I can't find someone that can design a FC660M plate, could you put me down for a universal TKL plate?
|||My other keyboards :
x
Offline lilky
« Reply #152 on: Thu, 23 January 2014, 13:33:49 »
If you did a 87 key plate GB I would hop on that in an INSTANT.
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #153 on: Thu, 23 January 2014, 21:37:47 »
shouldn't a universal TKL plate fit 87 key layouts?
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #154 on: Fri, 24 January 2014, 03:54:26 »
It should, yeah. Especially since we have had numerous groupbuys and plenty of models to try them on.
x
« Reply #155 on: Fri, 24 January 2014, 14:26:33 »
So...... 64% of an 1/8 of an inch....
what'd be really cool is an 1/8 inch... oh man.. so thick... LOLOL
Offline joneslee85
  • HHKB Scrub JP
  • Professional Rubyist programmer!
    • Ruby Journal
« Reply #156 on: Sat, 25 January 2014, 23:16:17 »
I'm interested in tools please
TOO MANY KEYBOARDS THAT I COULD NOT COUNT! BUT I AM STILL USING MY MODEL F77
Offline tbc
« Reply #157 on: Sun, 26 January 2014, 01:48:03 »
interested in switch tool
Offline fart_toast
« Reply #158 on: Sun, 26 January 2014, 08:36:56 »
Any estimate on when these will go into production as we have enough for the first sheet? Stripped my poker down, made my ergo-clears, ready for new plate! :D With regards to the thickness...are these thicker than say a normal poker 2 plate or about the same? If thicker, it'll still work right... Just can't be too thick or the side clips of the MX switches won't bite when pushed into the plate...?
Offline taylordcraig
« Reply #159 on: Tue, 28 January 2014, 03:12:40 »
 I'm dreaming of a 40% titanium board. Could we do a 40% plate?
Definitely interested in a set of tools, and I'm thinking about how many 60% plates is reasonable to buy in one month...
Offline mkawa
« Reply #160 on: Tue, 28 January 2014, 20:32:46 »
i can get this material to the laser with a couple days lead time, but we need a better idea of what the demand for switch tools is. so, speak up! if you want switch tools, please say so and how many!
more plates are cool too, as long as you or the_beast have a drawing for them.
it would be cool to get full 40% cases into this cutting job, but jd would have to revise his drawings, and it would delay the buy significantly. we need to get this material out to the laser and give him time to work with the material before we go too crazy. hence, we're trying to get as many switch tools made and purchased so that we can continue to get Ti plates cut with different drawings.
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
« Reply #161 on: Tue, 28 January 2014, 20:36:13 »
I'm a bit confused. The_Beast doesn't seem to care much about the switch tools. If the problem with moving this forward is a lack of switch tool interest, it should be in the title so that more people know about it.
Offline The_Beast
  • I like wood ಠ_๏
« Reply #162 on: Tue, 28 January 2014, 20:49:42 »
Kawa is partially right. Plates are the main part of this buy, tools are just to file space so we're not wasting an expensive material.
I need to figure out how many plates will fit onto the sheet, how many tools I can get out of the scrap and at what price GH is willing to buy them for.
« Reply #163 on: Tue, 28 January 2014, 21:09:37 »
$15? :D
Offline Zeal
    • Zeal Generation Inc.
« Reply #164 on: Tue, 28 January 2014, 21:14:16 »
I'd be down for 2 pairs of switch tools! Opening a switch one leg at a time isn't efficient  :p
I'm not sure how much the Aluminum ones went for, but I'd be fine with $15/ea ;D
Offline Pacifist
  • on hiatus
« Reply #165 on: Tue, 28 January 2014, 21:15:09 »
if its $15 for a 60% ti plate count me in for two
Offline Zeal
« Reply #166 on: Tue, 28 January 2014, 21:15:51 »
Keep dreaming. :))
Offline The_Beast
  • I like wood ಠ_๏
« Reply #167 on: Tue, 28 January 2014, 21:23:45 »
Don't be stupid, the material alone cost is WAY more than that
Offline JayKthnx
« Reply #168 on: Tue, 28 January 2014, 22:43:27 »
are you willing to add in a universal tkl plate to this, or limiting it only to 60% and below? either way, I'd like to confirm intent to buy a pair of switch tools.
Offline strict
  • TKL Zealot
« Reply #169 on: Tue, 28 January 2014, 23:00:39 »
I'm definitely down for at least one set of switch tools if/when they are ready for sale. Depending on price I might want 2 sets. $15 seems a little steep IMO. If they are that much I'll probably stick with just one set.
Offline Pacifist
  • on hiatus
« Reply #170 on: Tue, 28 January 2014, 23:25:10 »
Non ti tools were around $10-15. Ti tools will naturally be more than that.
« Reply #171 on: Tue, 28 January 2014, 23:34:57 »
I would love a 40% case and plate. And again, stating my interest in tools. Just one set for myself to work on my own keyboards.
Offline fart_toast
« Reply #172 on: Wed, 29 January 2014, 05:46:24 »
Yeh if they're around $15 i'll get a set of tools added to my plate order. If they end up being much more expensive then i'll have to stick to plate only...already pushing budget out to get the plate :)
Offline heedpantsnow
  • Old enough to know better
« Reply #173 on: Thu, 30 January 2014, 07:50:10 »
I'm in for 2 pairs of tools in addition to the Poker plate
I'm back.
Offline korrelate
  • iubeo stultum esse libenter
« Reply #174 on: Thu, 30 January 2014, 10:58:44 »
Good Luck With This!!
Topre REALFORCE
« Reply #175 on: Thu, 30 January 2014, 13:04:29 »
They'll probably be more, seeing as previous tools of cheaper material were priced at $15. I'd estimate $30, but I could be WAY off.
Offline Dreamre
    • kbdlife
« Reply #176 on: Thu, 30 January 2014, 22:51:30 »
Would love another set of tools and if possible, a TKL plate :D.
Offline fart_toast
« Reply #177 on: Fri, 31 January 2014, 08:58:32 »
Ok just the plate then lol, I'll make a tool out of a bulldog clip or just use tweezers xD I have titanium tweezers already to be fair.
  • Cherry Peasant
  • keycult.com
« Reply #178 on: Fri, 31 January 2014, 09:37:58 »
I don't believe the tools will be $30, and I'd be quite disappointed if they were.
I understand that the material is expensive, but the surface area required for a plate makes up more than 10 sets of switch tools (they're not very big), and the plate is only about $75. Additionally, the switch tools are being produced from the scrap left over from cutting plates, which would be waste otherwise.
A nice price on the switch tools would be a nice gesture to those of us jumping into this :). (I understand if that can't happen, though.)
Offline mkawa
« Reply #179 on: Fri, 31 January 2014, 09:54:40 »
i can tell you that we have not tossed around the 30$ number at all. i agree that's too much
« Reply #180 on: Fri, 31 January 2014, 09:59:19 »
Wasn't there a bit of manual labor involved with the previous switch tools?
They have to be bent and the ends filed down right?
How much more difficult would it be with titanium?
That would add to the costs and even the feasibility of getting them done considering The_Beast is primarily focused on his education at the moment.
  • Cherry Peasant
  • keycult.com
« Reply #181 on: Fri, 31 January 2014, 10:02:48 »
That's certainly true. I was actually assuming that most of the $15 cost of the last round of tools was labor compensation, not materials. Of course I could be wrong about this.
Offline mkawa
« Reply #182 on: Fri, 31 January 2014, 10:42:43 »
yah there's a fair amount of labor involved on the_beast's part.
Offline JayKthnx
« Reply #183 on: Fri, 31 January 2014, 11:37:46 »
anyone?
Offline mkawa
« Reply #184 on: Fri, 31 January 2014, 12:48:11 »
the_beast only has cutting fees and has reserved space for smaller plates. however, we have some more material. we just don't know how much (it's actually blocked on me, sorry). certainly, the more people who are looking for larger plates, the easier it is on us.. this is an IC, so please register your interest as loudly as possible and find compatriots, etc.
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #185 on: Fri, 31 January 2014, 12:55:15 »
In that case; a formal expression of interest in a TKL plate ;)
x
Offline The_Beast
  • I like wood ಠ_๏
« Reply #186 on: Fri, 31 January 2014, 12:58:29 »
anyone?
At this time no, in the title it clearly states 60% and I've said multiple times that this GB would be for 60% plates only
Offline JayKthnx
« Reply #187 on: Fri, 31 January 2014, 13:31:05 »
my apologies. I had been watching this thread for some time and never saw any definitive response either way to interest in tkl plates, so I simply wanted to clarify. thanks for the response and glwgb!
« Reply #188 on: Fri, 31 January 2014, 14:09:42 »
This dude Jay is interested a universal tkl plate! [Thought I'd get his voice in here a little louder with the conflicting answers and his shying away.
I WANT A 40% CASE AND PLATE. and 1 set of switch tools I'm sorry, I just don't need a 60% titanium plate right now. :<
Offline The_Beast
  • I like wood ಠ_๏
« Reply #189 on: Fri, 31 January 2014, 19:48:53 »
No worries, I just want to get these cut to see how well they come out. I also want to maximize space used due the material cost TKLs are a lot hard to fit onto the plate/nest
Offline moogle
_
« Reply #190 on: Sat, 01 February 2014, 05:20:18 »
_
« Last Edit: Mon, 11 September 2017, 14:34:17 by moogle »
Offline Cottonsox
« Reply #191 on: Sat, 01 February 2014, 08:53:51 »
Interested in a set if tools.
Offline billnye
  • ability man
« Reply #192 on: Sat, 01 February 2014, 08:58:14 »
I'm interested in a Poker plate.
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #193 on: Sat, 01 February 2014, 17:05:26 »
Please put me down for some titanium tools, and maybe a ANSI tenkeyless plate if there will be a option to get one.
« Last Edit: Sat, 01 February 2014, 23:28:42 by CommonCurt »
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline snoopy
  • The Flying Ace
  • Gone with the Wind
« Reply #194 on: Sun, 02 February 2014, 12:53:23 »
I'm interested in this: iso, 1,5-1-1,5-7-1,5-1-1,5. split right shift, off-center capslock (want to use a original cherry capslock, hope offcenter is the correct term for that). Tool would also be cool.
Offline aggiejy
« Reply #195 on: Sun, 02 February 2014, 13:16:51 »
Interested in some tools, and possibly a poker plate!
  • Cherry Peasant
  • keycult.com
« Reply #196 on: Mon, 03 February 2014, 16:35:26 »
The_Beast, do you expect this to go to GB/invoicing phase this week? (Want to make sure funds are in the right places.)
Offline The_Beast
  • I like wood ಠ_๏
« Reply #197 on: Mon, 03 February 2014, 19:13:14 »
Getting everything figured out. Once I start GB, payments will be taken right away, kawa gets Ti, ships to laser, gets cut, ships to me and I ship to you
I doubt it will be more than 2 weeks to GB starting
  • Cherry Peasant
  • keycult.com
« Reply #198 on: Mon, 03 February 2014, 19:18:54 »
Awesome, thanks for the update.
Updates for everyone!
Offline fart_toast
« Reply #199 on: Tue, 04 February 2014, 14:40:35 »
STILL SO EXCITED FOR THIS!
