Author Topic: Model M's as substitute for futon mattress?  (Read 3630 times)
Offline Typey Toes
« on: Thu, 09 January 2014, 21:41:11 »
I've been pondering this. How many would you need? Would the Model M be ideal or something else such as Cherries? Obviously we are well catered for regarding choices.
As a side art project you could connect them all to a pc and then in the morning see what mysterious key presses your body entered as you slept.
Re: Model M's as substitute for futon mattress?
« Reply #1 on: Thu, 09 January 2014, 21:42:47 »
wat
Offline fourzeropooh
« Reply #2 on: Thu, 09 January 2014, 21:48:35 »
You won't get an accurate result with 2KRO
Offline Typey Toes
« Reply #4 on: Thu, 09 January 2014, 21:53:06 »
Speechless...
« Reply #5 on: Thu, 09 January 2014, 22:02:11 »
« Reply #6 on: Thu, 09 January 2014, 23:18:05 »
« Reply #7 on: Thu, 09 January 2014, 23:49:33 »
Hmm........
you could fit about 4 keyboards behind you..
Further assume each key is heavy and offers 80g max
you're ontop of 80% of the keys at any one time..
104 x 4 x .8 x 80g = 60lbs of force
mmm.. this might be possible if you're very skinny.... and your torso is very flat and evenly distributed...
Offline berserkfan
« Reply #8 on: Fri, 17 January 2014, 13:19:43 »
Hmm........
TP4tissue
That doesn't sound like An American to me. Flat torso? How many of the folks in your average Krispy Kreme or Dunkin Donuts have flat torsos?
« Reply #9 on: Fri, 17 January 2014, 13:30:28 »
Hmm........
TP4tissue
