Author Topic: Is this legit? Cherry Brown Kb $23 New  (Read 4378 times)
Offline clickclack123
« on: Fri, 10 January 2014, 06:05:00 »
http://www.newegg.com/Product/Product.aspx?Item=9SIA2C518T3698
My favourite part is "strong waterproof function, 9 scupper drainage".  :D
Description:
100% brand new,New high quality
Appearance characteristics: stability strong support, unique appearance modelling, the human body engineering science design is very comfortable
Control performance: professional game key cap, suitable for the application in a key design
Keyboard size: 475 x192x30mm
Waterproof performance: strong waterproof function, 9 scupper drainage
Key life: knock keyboard 30 million times
Product interface: stability USB special interface, transmission more accurate fluent
Texture outstanding fashion design
Multimedia function key: is there
Plug and play: support
Interface types: USB
Connection mode: cable
Package included :
1 x game Keyboard
Offline damorgue
    • Personal portfolio
Re: Is this legit? Cherry Brown Kb $23 New
« Reply #1 on: Fri, 10 January 2014, 06:14:19 »
Something went wrong with Google translate... repeatedly.
If it uses Cherry switches, it is quite a cheap source for them once you desolder them.
23/104=22¢/switch
« Reply #2 on: Fri, 10 January 2014, 06:16:28 »
That's why I'm questioning whether anyone thinks it's legit or not. I guess those TVe Gold ones were about the same price... But they didn't have 9 scupper drainage!
Offline yasuo
  • spanengan puyeng newbie
« Reply #3 on: Fri, 10 January 2014, 06:24:14 »
I don't think it uses cherry
looks rubber dome reguar
« Last Edit: Fri, 10 January 2014, 06:26:26 by yasuo »
Logitech MK220 Colemak DH
Offline damorgue
« Reply #4 on: Fri, 10 January 2014, 06:28:59 »
I would also guess that it doesn't use Cherry MX. They aren't waterproof without some sort of rubber cover which they would have had to fit underneath the caps. MX are rated at 50 million keystrokes as well, not 30 as stated there.
« Reply #5 on: Fri, 10 January 2014, 06:34:31 »
Yeah seems too good to be true. The reason I thought it was was because when I searched it came up with this:
50466-0
Offline inteli722
« Reply #6 on: Fri, 10 January 2014, 06:44:59 »
No. It's also labeled "Ergonomic" and has half-sized caps for the function keys. I've also never seen a mech with the large rounded mods this one has.
Waiting for: Phantom Plate
« Reply #7 on: Fri, 10 January 2014, 06:51:53 »
Plus it says that it's a mouse.  ;D
Offline berserkfan
« Reply #8 on: Fri, 10 January 2014, 07:19:31 »
They just made a mistake. Cherry makes rubber domes too.
Online tp4tissue
« Reply #9 on: Fri, 10 January 2014, 10:00:32 »
so these are the brown domes.... ?
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #10 on: Fri, 10 January 2014, 13:40:23 »
Looking at all the other items from this fivestar... there are quite a lot of them that are clearly not possible to be MX that are listed as such. Newegg has gone majorly downhill since they started allowing these other sellers on there.
Cherry MX black...
oh yes I'm sure... :))
Offline inteli722
« Reply #11 on: Fri, 10 January 2014, 15:43:32 »
Cherry MX black...
I really don't like what they've done. The people they front for rarely have better prices on the things I want, and always have a ton that I don't want and is not relevant at all to what I want to buy.
Offline terran5992
  • One With The Cup Rubber
« Reply #12 on: Fri, 10 January 2014, 23:58:08 »
Cherry MX black...
This uses mx switches?
Offline yasuo
« Reply #13 on: Sat, 11 January 2014, 00:12:54 »
i think that marketing technique ;D
cherry even be damaged by dust
« Reply #14 on: Sat, 11 January 2014, 11:22:44 »
Of course the touch numpad doesn't use MX... it was sarcasm.
Offline pexon
  • El Jefe of Sleeving
    • Pexon PCs
« Reply #15 on: Sat, 11 January 2014, 11:24:48 »
"the human body engineering science design is very comfortable"
« Reply #16 on: Sat, 11 January 2014, 21:58:05 »
"transmission more accurate fluent"  :D
This is what's known as word salad.
Offline fourzeropooh
« Reply #18 on: Sat, 11 January 2014, 23:29:39 »
Quick Info
Manufacturer Contact Info
Website: http://www.banggood.com
Support Phone: 852-35903678
Support Email: qingqingw3l@gmail.com
Support Website
View other products from Five Star Inc
Return Policies
This item is covered by Electronic Depot Return Policy.
