Author Topic: Does anyone know what is a discrete switch?  (Read 3556 times)
Offline berserkfan
« on: Sun, 12 January 2014, 02:51:50 »
Googling discrete switches discrete switches didn't give me good info, so I thought I'd ask.
There is a Radioshack computer with what Aer Fixus identified as discrete switches on auction now, auction ending 11 hours, btw.
Offline kolonelkadat
  • Location: the vicinity of an area adjacent to a location
    • Force Project X
Re: Does anyone know what is a discrete switch?
« Reply #1 on: Sun, 12 January 2014, 03:14:44 »
im pretty certain he simply means that the switches are, well, switches. as in they are not a 3 layer plastic sheet assembly or foam and foil assembly. in other words each switch is a single thing
"Obviously, windows are central to Windows. But what is a window?"
Offline tuxsavvy
  • 白HHKBの魔法使い
« Reply #2 on: Sun, 12 January 2014, 05:25:11 »
I think if you look at it on a more general sense. Discrete would mean individual in electronic sort of sense. I was talking to a few people the other day comparing the likes of modern desktop computers versus embedded devices like smartphones, tablets, etc. You have all these SoC, PoP which are packing more stuff on a single die (or a chip in a more layman's sense). Then you get discrete ones which a few or only one component sitting in a single die, and are separate from another. That is a CPU would not have just L1/L2/L3 RAM, with embedded devices you get video chip, maybe a radio (for wireless communication) and other things all on one chip.
So basically, I guess discrete switch would be none other than what kolonelkadat describes. In other words individually packed switch.
HHKB Pro JP Type-S | Northgate Omnikey 101 | APC/"Clicker" F-21 (GOG3YL) | Cherry G80-5000 HAMDE
僕の日本語が下手です。我的中文也一樣爛。
« Reply #3 on: Sun, 12 January 2014, 05:44:27 »
yea pretty sure they mean "individual switches" vs the membrane.
you could go further with tuxsavvy's  route, if we were talking about electronic signaling..
But this is a keyboard switch..
Offline damorgue
    • Personal portfolio
« Reply #4 on: Sun, 12 January 2014, 05:54:24 »
It could also be discrete in the sense that it has discrete signal levels, eg on/off. Hall effect, Topre and such switches could be made into separate units but they don't have on/off states in the same sense. That is done in the controller which has to set a level where a value above it is on and below it is off for instance.
I guess that most commonly it refers to separate physical units as the others have described though.
Offline berserkfan
« Reply #5 on: Sun, 12 January 2014, 06:30:55 »
OK, so it doesn't refer to a name for a switch type, the way Hall Effect and Alps are names of switch types.
I understand the plain English meaning of it; just wasn't expecting that the poster was using a plain English meaning as opposed to an Engineering Geek name!
 :D :D :D :D :D :D :D :D :D :D :D :D :D
« Reply #6 on: Sun, 12 January 2014, 09:54:05 »
Now I understand how to articulate my explanations to people who refer to "Model F switches being better than Model M switches" since buckling spring mechanisms are not "discrete switches" by this definition!
A discrete mechanism does not necessarily indicate a discrete switch.
I don’t give a damn. We’re making a freaking fortune, our country is getting stronger and stronger all the time.
- D Trump 2026-10-24
Offline Aer Fixus
  • And now, back to lurking...
« Reply #7 on: Sun, 12 January 2014, 14:05:58 »
It's been answered already, but to say it myself, I mean that each switch is individual. I found the image of the bottom of the keyboard PCB before I found the switch itself and saw that each switch had solder points. To my knowledge, this is only something that happens with individual keyswitches. If it were capacitive or rubber dome over PCB, there would be no solder points. If it were a sheet of membrane, there would be no PCB.
               SOON: IN PROGRESS:
I lie all the time.... I really don't even like keyboards
