Author Topic: White PTB keycaps with Silver Legends ?  (Read 5420 times)
Offline acidtrip69
« on: Wed, 15 January 2014, 17:00:30 »
Hello i would like to know if theres a white thick or normal ptb keyset with silver legends ? If there is not i would like to ask if anyone would like a set like that so we can get a group buy to make them ? Maybe we an ask Ivan or IMSTO cuz they seems to know who makes the ptb keysets.
Offline acidtrip69
Re: White PTB keycaps with Silver Legends ?
« Reply #1 on: Thu, 16 January 2014, 14:15:51 »
Really ? no one has any info if theses keycaps exist ? are they dye subed or double shot ?
« Reply #2 on: Thu, 16 January 2014, 14:51:08 »
Silver?
hmm...
Well.. you can get those silver printed stickers... and cut them out carefully and put them on the "side" of the key caps..
For side printed..
« Reply #3 on: Thu, 16 January 2014, 15:03:37 »
I've seen white keycaps with grey legends.
Offline acidtrip69
« Reply #4 on: Thu, 16 January 2014, 16:39:42 »
Silver?
hmm...
For side printed..
Nha, thats not good. Won't the stickers just come off super easy ?
Offline acidtrip69
« Reply #5 on: Thu, 16 January 2014, 16:41:40 »
Well it looks like we are going have to "Make It So ! " ahahahah XD so if we can get say white ptb double shot silver legends key set made would people want to join in a group buy for that ?
« Reply #6 on: Thu, 16 January 2014, 17:01:09 »
Silver?
hmm...
For side printed..
not if you put them "on the side" / "front-side"
Offline Oobly
« Reply #7 on: Fri, 17 January 2014, 03:47:21 »
AFAIK you can't get silver PBT material... Anyone feel free to correct me if I'm wrong.
Also, I don't think you'd get enough people interested in silver on white to meet MOQ.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
« Reply #8 on: Fri, 17 January 2014, 06:47:40 »
the problem with "silver " and "plastic"  is that you will need a very thick strip for it to look metallic.. otherwise a thin strip of silvery plastic will just look  GREY
The only other way is to have a reflective silver surface, but that's not easily achievable on plastics, and it wouldn't be durable..
So you see,  SILver plastic text is just not terribly viable for the font labels...
cutting out the stickers is your best bet.. for essentially "side printed" caps
Offline Oobly
« Reply #9 on: Fri, 17 January 2014, 07:40:50 »
+1 to this.
Or just use a silver sharpie and some kind of templates / masks. Would wear off with use on the top, but it could work for front-printed caps.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #10 on: Fri, 17 January 2014, 15:59:25 »
There does exist some metallic ink for dyesublimation for example I have seen it on coffee mugs, but as far as I can tell it is only useable on certain machines with specific capability and/or with certain materials. I am not sure if those used by imsto fall into that category and if it's possible to get a similar result on PBT. It's an interesting idea tough, there could certainly be some interesting design possibilities.
Offline acidtrip69
« Reply #11 on: Sat, 18 January 2014, 13:47:46 »
So you think if you talk to them you think they can give it a try ? you know make a few sets see how they come out ? and if they do come out good maybe talk about making enough for a group buy ?
« Reply #12 on: Sat, 18 January 2014, 14:48:39 »
I see if it's possible at all even. If so I will get one sample key to see how it turns out and can go from there.
Offline acidtrip69
« Reply #13 on: Sat, 18 January 2014, 18:59:21 »
I can't wait to see ^_^ i hope it goes well
