Author Topic: Keycaps, sound and feel?  (Read 3903 times)
Offline DrinkTea
« on: Wed, 15 January 2014, 22:22:08 »
Does the material and thickness of keycaps affect the feel and sound of typing on any keyboards? Or is it purely for aesthetics and fingertip sensation? Thank you.
Offline neunelfer
  • HHKB Pro
Re: Keycaps, sound and feel?
« Reply #1 on: Wed, 15 January 2014, 22:25:25 »
Yes, thicker keys generally have a deeper, more solid sound. PBT and ABS usually sound different from each other too. In my experience, ABS has a slightly higher pitched sound.
Offline DrinkTea
« Reply #2 on: Wed, 15 January 2014, 22:29:05 »
Are there any recordings comparing otherwise identical boards with different caps?
Offline neunelfer
  • HHKB Pro
« Reply #3 on: Wed, 15 January 2014, 22:38:36 »
I actually have a couple videos comparing the two.
Filco, Blacks with stock ABS
Filco, Blacks with PBT
It might be kind of hard to tell the difference, but there definitely is one.
Offline DrinkTea
« Reply #4 on: Wed, 15 January 2014, 22:44:46 »
I hear the difference. PBT sounds like more of a thud in those videos. How much of that is just weight and not material? Also, how much of that sound difference would be removed with the use of landing pads or o rings?
Offline neunelfer
  • HHKB Pro
« Reply #5 on: Wed, 15 January 2014, 23:12:44 »
I actually have yet another video of the PBT with o-rings, which I have since removed. They alter the feel and sound a little too much for my liking.
I think it mostly comes from the material in this case, because the PBT and ABS are approximately the same thickness.
Offline Oobly
« Reply #6 on: Thu, 16 January 2014, 02:46:41 »
Even at the same thickness, PBT weighs more because it is denser. More mass = lower pitch.
The feel is affected by a few factors. The surface, the weight and the profile. PBT is "drier" feeling, almost like unglazed ceramic. It is also denser, which increases the impulse required to move the key.
The combination results in a less "cheap" sound and feeling, IMHO.
Personally, I prefer POM. It is even denser than PBT and I like the smooth surface feel.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
« Reply #7 on: Thu, 16 January 2014, 03:17:10 »
pom felt a little stick to me.. but it's not a huge issue since I don't have sweaty hands.
« Reply #8 on: Thu, 16 January 2014, 03:22:03 »
I keep seeing the title cut off in the index and reading it "Keycaps, Sound and Fury"
That should be a thread, and also a movie
« Reply #9 on: Thu, 16 January 2014, 03:35:44 »
oooo... that does ring like earth, wind, and fire..
it should be    keycap (singular), sound and fury
They all have two intonations
Offline bamze
« Reply #10 on: Thu, 16 January 2014, 11:07:55 »
Haha i like your "yet another video" library  :thumb:.
Camo Filco blue, ducky shine 3 red, filco brown, ibm model M, CM Novatouch.
Offline Oobly
« Reply #11 on: Thu, 16 January 2014, 11:42:19 »
I get the impression of a hero typing furiously, hair blown back by the blast of hot air from his furiously thundering, flaming fingers, churning out paragraphs a second for.... his book report... or something. A review of keycaps rated by their resistance to melting or shattering.
Offline strict
  • TKL Zealot
« Reply #12 on: Thu, 16 January 2014, 12:45:25 »
I just aquired my first set of PBT keycaps and that is an excellent way to describe their texture. The feel of PBT is simply amazing.
Regarding the OPs questions, I have noticed a slight tone change when switching out my stock Filco ABS caps for the BangGood PBT caps I'm using now. Both sets of caps are pretty thin but the PBT ones seem to have a slightly deeper tone. I feel like it even kind of helped reduce the "pinging" that my Filco suffered from to a small degree.
« Last Edit: Thu, 16 January 2014, 13:18:36 by strict »
Offline Linkbane
« Reply #13 on: Thu, 16 January 2014, 13:45:36 »
I think the Keycool (i.e. banggood) is the new start for a lot of members. It was my first exposure to PBT caps, and I personally really like them; a nice roughness which grips my fingers, and not very heavy. For some reason, it's medium-thick, which I actually think is nice. It has a higher pitch than the thick PBT on my Ducky, but the difference between rough and very smooth make them difficult to compare. They both are great.
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
« Reply #14 on: Thu, 16 January 2014, 13:52:40 »
Pom is the only one I haven't tried.
But between pbt and abs I truly feel no damn difference.
But then again I have weird fingers.
« Reply #15 on: Thu, 16 January 2014, 13:58:51 »
you got dem workin man fingers
