Author Topic: Spacebar Clipping Keyboard  (Read 2320 times)
Offline jk1900
« on: Sun, 19 January 2014, 11:33:38 »
Hi all,
I am currently using a noppoo choc with red switches. I also have a noppoo with black. The keyboard with the red switches had a spacebar that is constantly clipping the edge of the keyboard, as in it is rubbing against the keyboard very distinctly and it is driving me crazy.
The stabilizer platform was slightly wobbly so i glued it back in place but this did nothing. I cannot notice any difference between the red and black switch keyboard and even tried switching the spacebars around.
Has anyone suffered this? Any suggestion on how to fix it?
Re: Spacebar Clipping Keyboard
« Reply #1 on: Sun, 19 January 2014, 12:58:54 »
Hi all,
could you video tape this with ur phone.. and upload to youtube so we can see this?
Offline jk1900
« Reply #2 on: Sun, 19 January 2014, 13:56:13 »
feature=youtu.be
not sure about the quality but I am sure you can hear the rubbing of the keyboard that i am talking about
« Reply #3 on: Sun, 19 January 2014, 14:05:25 »
Are you sure you glued it back in place correctly? Can you remove the spacebar and take a picture to show us? Seeing it might be more helpful.
Offline jk1900
« Reply #4 on: Sun, 19 January 2014, 14:10:18 »
http://imgur.com/3j8irFB
The glue is just on the left side of the spacebar under the metal stabilizer bar. The glue is not touching anything but the base.
« Reply #5 on: Sun, 19 January 2014, 20:29:46 »
check the space bar for straightness..
Do you have another space bar? have u tried the other space bar.
