Author Topic: How to stop drive spin up on file delete  (Read 2238 times)
« on: Mon, 20 January 2014, 12:45:20 »
Is disabling recycling bin the only way?
Re: How to stop drive spin up on file delete
« Reply #1 on: Mon, 20 January 2014, 12:50:03 »
Not sure what your asking. Why wouldn't the disk spin up if your accessing it?
« Reply #2 on: Mon, 20 January 2014, 12:54:23 »
it seems that when recycling bin is active.. it will spin-up all my drives if I'm deleting from ANY of the drives.
Shift delete goes over this.. but I obviously don't want to shift-delete all the time..
« Reply #3 on: Mon, 20 January 2014, 12:58:04 »
Weird....mine don't do that. Maybe it has something to do with system restore, which I turned off.
« Reply #4 on: Mon, 20 January 2014, 13:02:42 »
aghaaa why everyone computer better behaved than mine..
Offline damorgue
    • Personal portfolio
« Reply #5 on: Mon, 20 January 2014, 13:02:48 »
Hmm, in the recycle bin settings you can set how much space it should reserve. This is likely distributed over all drives which is why when you delete a file from one drive, it is placed in the recycle bin reserved area distributed across all drives. Just a guess. Perhaps you can set the recycle bin to only reserve space on one drive? This way it will only spin up the drive you are deleting from and the one with reserved recycle bin space.
« Reply #6 on: Mon, 20 January 2014, 13:07:15 »
is that how it works?
I thought each drive has their own allocation
Offline damorgue
« Reply #7 on: Mon, 20 January 2014, 13:14:14 »
I am not sure at all, I have no idea how it allocates it but based on what you said that it spins up all the drives, I see no reason other than it having to write to all of them. This seems like the logical conclusion to me.
« Reply #8 on: Mon, 20 January 2014, 15:48:02 »
Mine does that, Windows 7.  I can hear the second drive spin up when I do all sorts of innocuous things that don't involve it.  The machine kinda freezes for 10 seconds, then continues.  But it does that all the time anyway, not just when spinning a drive up.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #9 on: Mon, 20 January 2014, 17:40:27 »
I always disable power saving on HDD and just set sleep timer earlier. This is also better to do if you have SSD since then it dosen't cut power in the sleep state so garbage collection and internal trim can still run even when PC is sleep. If PC is on I am doing things with it, so I hate waiting for drives to spin up.
« Last Edit: Mon, 20 January 2014, 17:42:10 by IvanIvanovich »
