Author Topic: Linear Switches Lighter than MX Reds?  (Read 11691 times)
Offline ike2030
« on: Wed, 22 January 2014, 05:05:59 »
Are there any linear mechanical switches out there that take less force to actuate than cherry mx red?
Offline yasuo
  • spanengan puyeng newbie
Re: Linear Switches Lighter than MX Reds?
« Reply #1 on: Wed, 22 January 2014, 05:07:53 »
Cutting spring to 25g/10g
Logitech MK220 Colemak DH
Offline Oobly
« Reply #2 on: Wed, 22 January 2014, 05:20:11 »
AFAIK, Reds are the lightest mechanical linear switch. Topre 30g are lighter, but not linear.
You can get softer springs for Reds, though. Originative 55g or 45g springs would both be lighter than stock Red springs. If you want REALLY light, go for the 45g ones. Some force diagrams here: http://geekhack.org/index.php?topic=46449.msg981041#msg981041
Buying more keycaps,
it really hacks my wallet,
but I must have them.
« Reply #3 on: Wed, 22 January 2014, 05:42:28 »
you can buy the 45 g springs from Originative co..  they're 15g lighter...
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #4 on: Wed, 22 January 2014, 16:01:08 »
are you only talking about new switches?
i know futaba linears are pretty light, but those are on old boards and probably not what you are wanting
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline ike2030
« Reply #5 on: Wed, 22 January 2014, 16:03:11 »
How do i get a hold of an originative 45g linear keyboard?
Offline kmiller8
  •  Post Reporting Timeout
  • Who is that kmiller8 guy?
« Reply #6 on: Wed, 22 January 2014, 16:06:24 »
ike my buddy!
You do not get a originative keyboard, it's the name of a vendor.
http://www.originativeco.com/collections/accessories/products/springs
You buy the springs, and swap them into your MX switches (which in the case of that Rk-9k you have would involve you having to desolder every switch)
« Reply #7 on: Wed, 22 January 2014, 16:36:06 »
Why don't you lube the reds first?
That is the simplest and easiest thing to do, and may give you everything that you are looking for.
"you've got to cheat like hell"
- D Trump - 2026-09-10 Dallas, Texas
Offline strict
  • TKL Zealot
« Reply #8 on: Wed, 22 January 2014, 17:30:49 »
Have you ever actually used MX reds? As someone who owns MX reds, I seriously cant imagine wanting anything lighter.
Like everyone else has said, your best bet would be to pick up a board with red or black switches and swap out the stock springs for a set of the 45g/55g originative springs. Keep in mind, Originative measures their springs at bottom out force and Cherry measures their spring force at actuation. Stock red springs are roughly 60g to bottom out so to swap in 45g springs would make your keys about 15g lighter.
If you get a board with Plate mount switches you will have to desolder all of the switches to swap the springs. However, if you were to get a board with PCB mount switches you can just pop the top off and swap the springs without having to desolder anything.
« Reply #9 on: Wed, 22 January 2014, 17:50:56 »
if you look at the graph.. it's only 10g lighter...
Offline strict
  • TKL Zealot
« Reply #10 on: Wed, 22 January 2014, 18:13:26 »
ಠ_ಠ
