Author Topic: [Help] Wipe a hard drive so I can sell it  (Read 5146 times)
Offline oNinjaDispatcho
« on: Wed, 22 January 2014, 12:51:54 »
I'm selling my laptop. I got all my files that I want off of the hard drive, but now I need to wipe it.
I made a DBAN usb stick, used to wipe the hard drive by formatting it, but the laptop wont recognize the usb in the boot menu.
Is there some windows equivalent to apple's Target Disk Mode, allowing me to plug the laptop into my desktop, and then boot it as an external hard drive?
Thanks.
I need to wipe this thing asap, I'm  mailing it today.
QFR Mx Reds
Re: [Help] Wipe a hard drive so I can sell it
« Reply #1 on: Wed, 22 January 2014, 12:52:38 »
Can you not use DBAN on CD?
« Reply #2 on: Wed, 22 January 2014, 12:56:06 »
The laptop doesn't have a disk drive, and my external disk drive isnt working for some reason. It keeps disconnecting and reconnecting itself, no matter what computer I connect it to.
It will connect, windows will recognize it, then it will disconnect, windows will recognize that, and it repeats. Endlessly.
QFR Mx Reds
« Reply #3 on: Wed, 22 January 2014, 12:59:46 »
Can you try a different USB stick??
« Reply #5 on: Wed, 22 January 2014, 13:08:07 »
hey i figured it out. it was a problem with the bios setup. I had to turn on legacy support in boot options, whatever that means....
all in all, it worked. thanks spamray :)
QFR Mx Reds
« Reply #6 on: Wed, 22 January 2014, 13:09:37 »
Glad you figured it out. My next suggestions was going to involve a hammer :P
Offline jwaz
  • * based mod
  • #geekhack on freenode
« Reply #7 on: Wed, 22 January 2014, 13:10:31 »
Buy new external CD Drive -> UBCD -> Darik's Boot and Nuke.
« Last Edit: Wed, 22 January 2014, 13:12:02 by jwaz »
« Reply #8 on: Wed, 22 January 2014, 13:15:11 »
well...... DBAN says only 12 hours remaining, so I think the hammer will satisfy my anger.....  :mad:
QFR Mx Reds
« Reply #9 on: Wed, 22 January 2014, 13:20:38 »
Yeah dban is fairly slow....especially depending on the size of the hard drive.
« Reply #10 on: Wed, 22 January 2014, 13:47:25 »
what is faster?
QFR Mx Reds
« Reply #11 on: Wed, 22 January 2014, 13:56:20 »
what is faster?
Honestly not sure, I've only used DBAN and/or physically destroyed the drive.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #12 on: Wed, 22 January 2014, 14:26:42 »
If I need to destroy data fast... I do something like load up hdparm and pass a bunch of rubbish parameters so it totally corrupts the file system. Then I delete all the partitions, reformat and fill the drive again with a bunch of unimportant data, for example you could 100% fill the drive with X amount of copies of Rick Astley mp3s to double ensure any data is overwritten. I find copy files to 100% overwrite is usually quite a lot faster than most secure delete and essentially does the same thing. For the most part doing something like this is going to be good enough to thwart data recovery by any non expert without high end equipment. If feeling nice, I would once again delete the partition and reformat/possibly do fresh install of OS.
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #13 on: Wed, 22 January 2014, 14:30:19 »
lolol rick roll.  ;D
Offline Lanx
« Reply #14 on: Wed, 22 January 2014, 14:35:24 »
i love taking apart old drives and destroying them, one thing to salvage is the HUGE magnet near the read arm, that magnet is super powerful (probably one of those earth magnets or neodynium ****s) i make sure to take that out and use it for like my metallic white board or my fridge (it's a strong ass magnet, whatever you put under there, will not move)
« Reply #15 on: Wed, 22 January 2014, 15:04:16 »
^^ You should see my refrigerator haha....quite a few hard drive magnets on it.
Offline Tym
« Reply #16 on: Wed, 22 January 2014, 15:19:10 »
Do you have one of those big, double door, American delio's with an ice maker...
I've always wanted one of those!
« Reply #17 on: Wed, 22 January 2014, 15:22:20 »
sadly no...mine looks like this :(
51966-0
Offline Lanx
« Reply #18 on: Wed, 22 January 2014, 18:02:56 »
heck most of the double door fridges w/ ice maker these days are 90% stainless steel, which means magnets won't work on em anyways.
« Reply #19 on: Wed, 22 January 2014, 18:13:44 »
eraser.. it's faster and has an intuitive interface. and lets you select from many erase options..
Offline osi
« Reply #20 on: Wed, 22 January 2014, 18:29:13 »
I shot a desktop sized hard drive with a 12 Guage shotgun once.
Take that NSA...
« Reply #21 on: Wed, 22 January 2014, 18:35:42 »
to destroy hard drives:
step 1:
total your car
step 2:
put hard drives in the car
step 3:
make sure car ends up in the crusher
step 4:
kill everyone in sight
step 5:
take all their money
step 6:
salvage hard drive scraps from the crusher
step 7:
buy an industrial blender with the money you killed for
step 8:
blend the hard drives into smoothies.
step 9:
serve the smoothies to the cops when they come for you
step 10:
kill the cops
step 11:
burn their bodies
step 12:
make ash smoothies
step 13:
serve ash smoothies to swat when they come for you
you get the idea
QFR Mx Reds
« Reply #22 on: Wed, 22 January 2014, 18:42:52 »
LOL... seems like a lot of work. Make it easy and use SSD instead... all you have to do is send ATA secure erase command. It send strobe through all the nand resetting state to empty... and it's totally unrecoverable even with forensic. Best part... it takes about 10-60 second depending on capacity.
« Reply #23 on: Wed, 22 January 2014, 19:51:16 »
Delete the partition and format it to another file system.
Turn on you camera and record an hour of the ambient room.
Delete the partition and format again to another file system. Create a bunch of small partitions just for fun.
Anybody that found anything after that would be working pretty hard.
- D Trump 2026-10-24
« Reply #24 on: Thu, 23 January 2014, 10:42:10 »
I ended up doing DBAN quick wipe, took about 5 hours, but at least it was secure. I'm selling the laptop, that's why I wiped the hard drive, and I'll just ship it out today.
QFR Mx Reds
