Author Topic: What's closest to Browns but also close to silent?  (Read 7806 times)
Offline keyjay
« on: Fri, 24 January 2014, 02:44:41 »
I'm a power business user. Been using Browns for years and can't imagine liking anything different more than I like the Browns. (I've also seen a pattern where Browns are the keyboard of choice by some of those with insane experience with keyboards and by at least one owner of a well-known company that sells great boards.)
I always install o-rings on my Browns. I like the difference in feel, quieter sound, and slightly shorter travel.
I want to see if there's a really similar-feeling alternative that is really quiet -- so I can type while on the phone and people don't feel insulted (some people tend to feel that way even if I'm diligently listening to and typing virtually every word they're saying; it's just human nature).
I tried a Topre board (not silent) and it's not for me at all. Maybe I'm just too used to the Browns. I love the feel of the Topre keys as far as feel goes, like walking in fresh, soft, powdery snow. Someone described it as a buttery feel, and that's a good way to put it. I just don't want to be on soft, powdery snow or in butter when running for my life... which IS life! Browns with o-rings just work for me to get work done.
I only use standard full-sized layouts. Ideally, I prefer a black board with white lettering.
I'm wondering if there's a different Cherry switch that's really, really close in feel to the Browns yet also close to being silent, or ends up close to silent once o-rings are added.
Offline smknjoe
Re: What's closest to Browns but also close to silent?
« Reply #1 on: Fri, 24 January 2014, 02:54:30 »
I don't think you can get much quieter unless you get some kind of rubber dome (other than Topre.)
SSKs for everyone!
Offline reziak
  • Topre/60% Enthusiast
« Reply #2 on: Fri, 24 January 2014, 03:01:03 »
My quietest board (I have Topre, browns, clears, blues, and reds) is my 55g lubed and stickered red board. I'm not sure if its because it's PCB mounted, the stickers, or both, but it has the softest bottoming out sound I've ever heard on a mech. I didn't believe in the stickers, except that one of the switches isn't stickered and is noticeably louder and pingier when it bottoms out.
HHKB Pro 2 | FC660C | HHKB Pro 2 Type-S
Offline keyjay
« Reply #3 on: Fri, 24 January 2014, 03:17:05 »
I'm curious what "stickers" refers to. I'm not familiar. (I'm not going to mod a board -- the most I'll do is have someone like Weyman at WASD install o-rings for me even if I buy, say, a Leopold from EK).
Reds has occurred to me to possibly consider from vague memories of all I've read here over the years, but I'm guessing 55g will be a bit much for me. The 45g of the Browns really seems to be the sweet spot for me. (I tried a buckling springs from Unicomp once and after a few days or a week I was unable to use it -- just way too firm for my liking.)
Offline smknjoe
« Reply #4 on: Fri, 24 January 2014, 03:21:42 »
Have you ever tried a linear switch? There's nothing smoother or more "buttery" than that. More than Topre (HHKB.)
SSKs for everyone!
Offline tbc
« Reply #5 on: Fri, 24 January 2014, 03:22:44 »
there's really nothing you can do except learn to not bottom out.  especially if you're not willing to even take off your own keycaps.
you'll just have to get a different mic (this is a pretty futile endeavor so i'm told).
Offline keyjay
« Reply #6 on: Fri, 24 January 2014, 03:44:39 »
Let me clarify that: I am certainly willing to pay someone else to mod a board (or two) for me. As long as it's something that's not so out of the norm that well-known people in the field would shy away from doing it.
« Reply #7 on: Fri, 24 January 2014, 03:50:11 »
You could try placing the keyboard on a rubber mat.  That might help to absorb some of the sound resulting from bottoming out, and maybe from when the switch returns to the up position too.
Offline Belfong
« Reply #8 on: Fri, 24 January 2014, 04:08:43 »
What about Matias alps quiet switch? They are really quiet .. as quiet as a mechanical keyboard can get.
Offline Grim Fandango
« Reply #9 on: Fri, 24 January 2014, 04:15:19 »
One thing that kind of helps as well is to put some kind of cloth (a towel, mousepad or something similar) under the keyboard. It really dampens the sound you make when you bottom out. I use o-rings and a mousepad cut to size of the keyboard, and the difference in the amount of noise it makes is quite noticeable.
Offline reziak
« Reply #10 on: Fri, 24 January 2014, 04:30:55 »
Stock reds have the same springs as browns and are 45g. They're a completely linear switch (smooth all the way until you bottom out).
Stickers refer to putting vinyl stickers in the switch. Some people swear by them, other people say they don't do anything. I wasn't a believer until I experienced what I described above. It supposedly reduces any wiggle or movement the switch might have. Stickering a lubing are very common things to do to switches (around here, at least!), and I'd definitely at least recommend the lubing to make the reds as smooth as butter.
Offline davkol
  •  Post Editing Timeout
« Reply #11 on: Fri, 24 January 2014, 10:05:10 »
Is this your thread?
Just get a good noise-blocking mic.
Quote from: Linus Torvalds
I like offending people, because I think people who get offended should be offended.
« Last Edit: Fri, 24 January 2014, 10:09:00 by davkol »
« Reply #12 on: Fri, 24 January 2014, 10:16:19 »
I'm guessing the problem is not the "bottoming out" sound, as you have o-rings installed. I think the noise which remains is the "topping out" sounds when the keys return to the unactuated position after release. There's not a whole lot that can be done about that, unfortunately. You can try things like:
- PCB mounted (non-plate-mounted) keyboard, such as a Cherry G80 series.
- Shelf liner or other dampening material under the PCB in the case to reduce keystroke volume
- Thicker keycaps, to further reduce vibrations which cause noise
Offline davkol
« Reply #13 on: Fri, 24 January 2014, 10:41:32 »
...or latex mod.
Offline davkol
« Reply #15 on: Fri, 24 January 2014, 11:56:26 »
Offline neun_sechs_zwei
« Reply #16 on: Fri, 24 January 2014, 12:17:51 »
How about clears with fatter o-rings?
Feels like less travel/less bottoming.
« Reply #17 on: Fri, 24 January 2014, 12:58:46 »
That was my first thought too.
I would describe the feel as being somewhere in-between that of Cherry MX Brown and Topre, but maybe a bit more raspy.
There may be some good rubber dome keyboard out there with a feel more similar to MX Brown, but the Matias Quiet switch is also dampened on the upstroke which is very unusual.
Offline Oobly
« Reply #18 on: Fri, 24 January 2014, 14:05:55 »
If you're okay with a little modding work yourself (opening switches, adding stickers, some rubber pieces and a couple drops of latex) you can get a PCB mounted board (no plate) and trampoline and latex mod the switches: http://geekhack.org/index.php?topic=50632.msg1117334#msg1117334
The video gives some idea of how quiet they are afterwards.
[EDIT] Oops, Davkol already linked the video. They're even quieter with POM caps on, the ones in the video are PBT.[/EDIT]
« Last Edit: Fri, 24 January 2014, 14:11:36 by Oobly »
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline spiceBar
    • ChessTiger.com
« Reply #19 on: Fri, 24 January 2014, 14:56:29 »
Jdcarpe is absolutely right.
You guys after all this time still do not get that the problem with silencing Cherry MX is not the bottoming out noise.
O-rings, or even better, landing pads, take care of the bottoming out (as long as you are not hammering your keyboard).
The problem is that there is almost nothing we can do to silence the upstroke. Once you have silenced the bottoming out, the upstroke is louder than the downstroke. And it's a very annoying high-pitched sound (plastic against plastic).
The best method I know to silence the upstroke is to put non-conductive grease inside the switch. Not oil. The grease must have lower viscosity than oil. This limits the speed of the plunger on the upstroke and dampens the sounds rather well, but it also changes the feel of the switch. I find it acceptable to my taste, but I'm not sure you would like it.
Silencing the upstroke is possible on Topre switches, and the result is very good. Silenced Topre switches (on a Realforce) are so quiet that I can use it in a room where two people are sleeping (yes, I really do that). It works only with plate-mounted Topres (it's not as effective on the HHKB for example).
« Reply #20 on: Fri, 24 January 2014, 15:02:46 »
^^  oobly says liquid latex works towards silencing the upstroke...
I shall buy some and find out.. once the new Credit card gets here.. gotta spend $1000 this month to get bonus points..
« Reply #21 on: Fri, 24 January 2014, 15:09:32 »
This is all you ever needed to know. Trust the JD. :D
« Reply #23 on: Fri, 24 January 2014, 15:14:16 »
Lies... all of it.......
Too late, it's in my signature now.
« Reply #24 on: Fri, 24 January 2014, 15:15:38 »
My HHKB is very much silent when I type on it, its glorious actually, typing on clears makes too much noise for me now :(
Offline spiceBar
    • ChessTiger.com
« Reply #25 on: Fri, 24 January 2014, 16:20:07 »
I have an HHKB Type-S that makes a hell of noise compared to the Realforce I have silenced myself.
I don't think it's something I can fix, even if I replace the silicone rings inside by landing pads, as I did for the Realforce.
The problem is that the HHKB is all plastic. The case makes a hollow noise when bottoming out and also on the upstroke. In the Realforce you have a metal plate, and it makes all the difference. I'm not saying I don't like the sound of the HHKB, but the modded Realforce is much more silent.
My silenced FC660C also has a metal plate, and is much more silent than the HHKB Type-S.
I think the OP should really consider a Topre. A silenced 45g full size Realforce could be extremely silent and not too alien compared to browns. Okay, yes, this is debatable, but if you don't want people to hear you typing over the phone, I really don't see what other mechanical keyboard would do the job.
« Reply #26 on: Fri, 24 January 2014, 16:24:59 »
Now your making me want to silence my realforce :D
Offline spiceBar
    • ChessTiger.com
« Reply #27 on: Fri, 24 January 2014, 17:13:51 »
Well I'm pretty sure you had seen my thread about it already, but just in case here it is again. How-to:
  http://geekhack.org/index.php?topic=49046.msg1056220#msg1056220
The result of silencing on a FC660C (only the top two rows are silenced):
  http://www.chesstiger.com/images/keyboards/Silenced_FC660C.mp4
Standard Realforce vs silenced FC660C:
  http://www.chesstiger.com/images/keyboards/RF88_vs_Silenced%20FC660C.mp4
Silenced RF87U vs non-silenced one:
  http://www.chesstiger.com/images/keyboards/RF87_silenced_before_after.mp4
« Last Edit: Sat, 25 January 2014, 00:18:57 by spiceBar »
Offline jacobolus
« Reply #29 on: Fri, 24 January 2014, 21:01:15 »
I also say go for the Matias quiet click switches. In my opinion these feel much nicer than MX browns to type on [sharper tactility, higher actuation point], and are quieter too.
Offline SonOfSonOfSpock
« Reply #30 on: Fri, 24 January 2014, 21:18:17 »
I just compared my red and brown switches. The rebound seems louder on my reds. Not sure if that is because of keycaps differences or not.
If I were in your situation I'd try a Matias quiet board. I need to head over to Microcenter and try one out. The other thing I'd consider would be to have an Apple chiclet board just for the phone. That's the quietest board I've ever used.
Offline Oobly
« Reply #31 on: Sat, 25 January 2014, 04:25:58 »
 Jer. 5:21 (King James version): "Hear now this, O foolish people, and without understanding; which have eyes, and see not; which have ears, and hear not."
http://geekhack.org/index.php?topic=50632.msg1113167#msg1113167
« Reply #32 on: Sat, 25 January 2014, 06:41:20 »
Preach oh wise one....  sadly... new card's still not here...
Offline komar007
    • komar's blog
« Reply #33 on: Sat, 25 January 2014, 08:28:37 »
I have recently found that using an acrylic case minimizes the noise very well.
I'm currently typing on clears in an acrylic case, which has no empty space inside (thick acrylic plate, instead of steel, and a rubber pad between the PCB and the bottom layer). I think if you used lubed browns with that, it could be even more silent.
« Reply #34 on: Sat, 25 January 2014, 08:33:35 »
i think if you do oobly's latex mod + trampoline, it'll be pretttty much ultra silent..
because you've then worked at the "source" of the noise.. rather than only dampening reverberation.
Offline C5Allroad
  • Formerly HUNTERANGEL121
« Reply #35 on: Sun, 26 January 2014, 20:27:28 »
You can try clears maybe? They are heavier so that theoretically means that you won't bottom out as easily.
Offline Wildcard
  • When caffeine isn't enough
« Reply #36 on: Mon, 27 January 2014, 00:56:46 »
I used to have reds at work. I could have done a silencing mod, but I thought it was quiet enough that no one said anything. I also use a heavy case to absorb some of the shock and IMO it makes the board a little quieter.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #37 on: Mon, 27 January 2014, 12:35:18 »
my black space invaders
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline kilogeek
  • Nostalgy of a time when quality was a value
« Reply #38 on: Mon, 27 January 2014, 12:47:17 »
Lubing switches will surely make them more silent.
I personally don't like silent keyboards, that's my taste, I love clicky noisy kb :)
But black ALPS feel quite close to brown MX, and once lubed they are  silent, the only sound I have is when the keycap hurts the switch case. I have 1st gen complicated ALPS, someone said next gen are not so good...
If lubed brown with a ring is not silent enough for you than maybe you should use gloves :p
Noise can also be due to keycaps, some cheap plastic keycaps atc like a drum, even with ring they may be noisy, just test without and with keycaps, you may see a difference. Heavier keycaps or keycap using a best quality plastic shall produce less noise IMO, perhaps some kind of hard rubber keycaps may exist... IDK
"Ne pas subir" - Devise de Saint-Cyr.
Offline kilogeek
« Reply #39 on: Mon, 27 January 2014, 12:49:46 »
Oh and you can also fill the inside of your keyboard shell with glass fiber, this is known as a great sound absorber.
