Author Topic: Building a blacklit mechanical keyboard!  (Read 4420 times)
Offline dodzylla
« on: Fri, 24 January 2014, 05:33:55 »
Hello Guys!
I am a new guy here:) I want to build my own mechanical keyboard with blacklit, i tried to find topics about this, but i don't found.
So i write here some of my questions:
Phantom got PCB for blacklit keyboard?
Where can i buy blacklit capable keycaps?
Where i have to order for parts?
Thanks, Dod!
Sorry if you have topic about this.
Offline Rayne
  • For Science!
Re: Building a blacklit mechanical keyboard!
« Reply #1 on: Fri, 24 January 2014, 06:03:06 »
to answers your first question, the phantom PCB is NOT backlit compatible :(
for the other questions, im sure there are much more knowledgeable people than myself who can give you better answers than i could.
Offline dodzylla
« Reply #2 on: Fri, 24 January 2014, 06:05:00 »
Oh:( thanks you, then i try to search for a blaclit capable:)
But thanks your answer :)
« Reply #3 on: Fri, 24 January 2014, 23:28:04 »
Is your aim to save money, or to gain experience?
If to save money - it will cost you a lot more to buy the parts and build a keyboard from scratch than it would to buy one ready-made.
If to gain experience, you might start looking in to the GH60, a 60% keyboard designed right here on GH.
Offline dodzylla
« Reply #4 on: Sat, 25 January 2014, 05:39:55 »
i want to do it for experience!
thanks your help:)
Offline Chau
  • .5 Korean, .25 Vietnamese, .25 Chinese, Oz accent
« Reply #5 on: Sat, 25 January 2014, 07:13:22 »
There is also the sprit group buy which has everything to build your own. Check it out.
« Reply #6 on: Sat, 25 January 2014, 07:29:02 »
btw, it is called "backlighting", as in the letters on the keycaps being lit from the back as opposed from the front.
Keys don't have to be black. ;)
"Blacklight" is when you have a lamp that radiates just outside the visible spectrum. Some fluorescent material emits visible light when lit by "blacklight". I don't know of any such keyboard. Be aware that even though some of these wavelengths can not be seen and cause the iris to close, they can hurt the eyes. UV lamps often emit also a visible light as an indicator that it is lit.
I know there has been at least one group order of parts for a custom backlit keyboard, but I am not too interested in backlit keyboards so I don't know the specifics.
Offline dodzylla
« Reply #7 on: Sat, 25 January 2014, 07:33:00 »
Thanks guys! i read everything :D  sorry for the wrong word, just when i searched for keyboards , then i found only with "backlit" keyword :)
Offline Britney Spears
« Reply #9 on: Sat, 25 January 2014, 08:23:00 »
What layout do you need? ANSI or ISO?
Either way, search for Ducky Shine keycaps.
You can get ISO ones from Teraset (Finland) which have a great customer service but high shipping rates.
qtan (China) has ANSI ones in store (although the store is currently closed).
Offline dodzylla
« Reply #10 on: Sat, 25 January 2014, 10:44:31 »
ISO, i will do hungarian layout:)
thanks for your help.
Offline Megaweapon
« Reply #11 on: Sat, 25 January 2014, 10:54:01 »
Blacklit?
Ancer Research Groop DFK191ABA11 • IBM Model M13 Part 92G7461 (white) • Rosewill RK-9000
Matias Tactile Pro 3 • Apple Extended Keyboard II (ALPS)
• Rosewill RK-9000I
Offline dodzylla
« Reply #12 on: Sat, 25 January 2014, 10:58:14 »
Yea , that was a mistake :) sorry.
« Reply #13 on: Sat, 25 January 2014, 16:25:44 »
Egdx... backlit is for n00bs..
Yet, there are a couple of guys that have modified their ErgoDox'es to be backlit. I wouldn't call them n00bs. ;)
