Author Topic: Sandblasting ABS Spacebar  (Read 3001 times)
Offline neunelfer
  • HHKB Pro
« on: Fri, 24 January 2014, 09:16:12 »
Has anyone sandblasted their Topre spacebar? I've heard people mention it but couldn't find any actual results.
Re: Sandblasting ABS Spacebar
« Reply #1 on: Fri, 24 January 2014, 09:29:55 »
A similar question was asked yesterday in the Simple Questions thread. I provided a bunch of links so the person who asked could have some reading material. In particular, you might like ripster's guide since he shows step-by-step how he sandblasted caps. It's the imgur link.
Offline neunelfer
  • HHKB Pro
« Reply #2 on: Fri, 24 January 2014, 12:06:56 »
Thanks.
Online tp4tissue
« Reply #3 on: Fri, 24 January 2014, 14:29:15 »
do you already have all the sandblast stuff?
Those boxes are stupidly expensive.. it's just a box jebus...
Offline terran5992
  • One With The Cup Rubber
« Reply #4 on: Fri, 24 January 2014, 20:58:40 »
Will this fix the spacebar shine problem?
Online tp4tissue
« Reply #5 on: Fri, 24 January 2014, 21:14:18 »
abs shines up in like 2 weeks if you gotz heavy usage.... I don't see the point.
« Reply #6 on: Sat, 25 January 2014, 19:36:37 »
Nope.
I tried a while ago.
