Author Topic: looking for a decent 40-60 usd mouse -solved-  (Read 6529 times)
Offline thesentinel
« on: Sat, 25 January 2014, 14:55:10 »
I'm going to be using it for playing fpses.
things i want:
-minimal or no flashy lights
-made for righthand use
-not a gross amount of macro buttons
-comfort
-durability
-control
-wired
any suggestions?
« Last Edit: Sun, 26 January 2014, 23:14:13 by thesentinel »
Keyboards are the only thing keeping me from consuming human flesh.
Offline vun
  • Just one more thing
Re: looking for a decent 40-0 usd mouse
« Reply #1 on: Sat, 25 January 2014, 15:04:50 »
CMStorm Xornet
Offline thesentinel
« Reply #4 on: Sat, 25 January 2014, 15:45:35 »
Oops.. currently using the worst keyboard ever (onn slim profile) and not all keys work on the first try.
40-60, not 0..
Offline kmiller8
  •  Post Reporting Timeout
  • Who is that kmiller8 guy?
« Reply #5 on: Sat, 25 January 2014, 15:46:42 »
40-60, not 0..
maybe you should use 40-60 on a good keyboard instead. lol
Offline thesentinel
« Reply #6 on: Sat, 25 January 2014, 15:48:08 »
40-60, not 0..
a cm storm red is already in the mail. P:
Offline vun
Re: looking for a decent 40-60 usd mouse
« Reply #7 on: Sat, 25 January 2014, 21:16:10 »
CMStorm Xornet
spawn is def better.
Yeah, but Spawn may not be available depending on location(CM EU pulled the spawn after bad PR), and the title typo suggested 40-0, so I suggested the Xornet as that is the cheaper option.
Other than the Xornet, the G400 might fit the bill.
Not really up to date on US prices, since mice are quite a bit more expensive here.
« Reply #8 on: Sat, 25 January 2014, 23:28:59 »
CMStorm Xornet
oh?.... what bad pr...
Offline codyeatworld
« Reply #9 on: Sat, 25 January 2014, 23:36:41 »
I picked up a spawn today at frys for $29.99, the xornet was right next to it (same price).
Offline thesentinel
« Reply #10 on: Sat, 25 January 2014, 23:53:03 »
CMStorm Xornet
On Amazon, it only costs 30bucks for the spawn. So.. it seems the choice is spawn?
« Reply #11 on: Sun, 26 January 2014, 13:04:30 »
CMStorm Xornet
spawn is the exact same mouse as the logitech g400 with the perfect 0-acceleration sensor. and angle snapping line correction algorithm..  calibration for 1:1 is actually possible.
also, the "new" g400-s is ugly as crap... wtf were they thinking....
spawn still looks pretty cool.
If someone prefers the g400-s, they should get a used mx 5xx mouse and use the mouse cover from there..
I'm pretty sure the g400-s also doesn't use full omrons either.. whereas mx518 510 etc etc all had full omron.
Offline thesentinel
« Reply #12 on: Sun, 26 January 2014, 13:28:51 »
CMStorm Xornet
I noticed it is an optical mouse. Is there much difference between optical and laser?
Offline vun
« Reply #13 on: Sun, 26 January 2014, 15:51:02 »
CMStorm Xornet
Not much, but most laser sensors used have inherent acceleration or some other flaw, like the PTE z-axis issue, so most people prefer optical since they are usually less flawed.
« Reply #14 on: Sun, 26 January 2014, 18:50:36 »
Sensei RAW. 2nd only to the Sensei.
Offline digi
  • elite af tbh
  • keyboard game on fleek
« Reply #15 on: Sun, 26 January 2014, 18:53:51 »
If you get the Sensei, don't get the chrome one, it wears off pretty easy. I can post pics if you want..
Offline Kamen Rider Blade
« Reply #16 on: Sun, 26 January 2014, 19:39:25 »
Logitech G602
If you can live with the wireless aspect, just get rechargeable 2x AA batteries.
I personally have Sanyo Eneloop's, and the battery life on the G602 is insane
It's pretty much the only mouse most people will ever need, it has all the useful features and is close to perfect IMO.
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #17 on: Sun, 26 January 2014, 20:43:07 »
Always get Sanyo Eneloop's when using wireless mice.  Not only do they last but recharging them is relatively quick compared to most on board batt's.
The G602 is quite a good choice, wireless that doesn't need to be charged every day like the G700S  ::) .
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
« Reply #18 on: Sun, 26 January 2014, 20:51:47 »
Logitech G602
+1
« Reply #19 on: Sun, 26 January 2014, 21:10:42 »
The fact that the G700s lasts only 8-10 hours of real use makes it a joke IMO.
They had such a good mouse, yet they couldn't afford to give it 2x AA battery slots?
-_-
It has one of the best physical designs & buttons layouts along with features, yet they cripple it's wireless which is what it's all about.
They should just make a G701 and take the G700s and strip out the wireless feature and put in a nice braided cable and make it a good wired mouse.
Cause honestly, there is nothing wrong with that mouse, it just has a seriously gimped single AA battery slot and crappy battery life to boot.
Offline thesentinel
Re: looking for a decent 40-60 usd mouse -solved-
« Reply #20 on: Sun, 26 January 2014, 23:13:52 »
 I already ordered the cm spawn, /: *writes down in notes: dont be impatient*
Offline Elrick
  • Hype Master
« Reply #21 on: Mon, 27 January 2014, 02:56:01 »
Good choice according to those that currently are using it.  I have never purchased it as of yet but due to the low price - I figured why not join the crowd  ;) .
Yeah, don't worry about being 'impatient', it effects everyone here on Geekhack, it's quite a natural disease........ difficult to cure.
Offline Protato_Tubby
  • people enthusiast
« Reply #22 on: Wed, 12 February 2014, 20:09:19 »
things i want:
-comfort
-durability
-control
-wired
any suggestions?
Roccat kone pure. 'Buff said.
But, in all seriousness. It's really comfy, has nice build quality( Omron switches, avago 8200 DPI sensor), not too flashy, good driver and adjustment software and might be within your budget. I got it for £39.99. It *is* a bit on the smaller side, however. Or it could be my larger-than-an-iPad hands. xD
DELL AT102W Black Alps | IBM Model M 122 | Matias Tactile Pro 4
Offline olivil
« Reply #23 on: Thu, 13 February 2014, 17:18:59 »
I bought a SteelSeries Ikari Laser NIB on eBay for 40$ shipped. I was a Logitech guy but after trying it at a friend's house I can say it is the most comfortable mouse I've ever tried.
I'd suggest looking into it, maybe you'll get lucky like I did. Otherwise maybe you can consider this 42$ Ikari Optical?
Offline Charizard^
« Reply #24 on: Thu, 13 February 2014, 22:33:47 »
Mine's cord is broken already, had it for about 5 months.
