Author Topic: Hybrid water and air cooling..  (Read 2105 times)
« on: Fri, 31 January 2014, 13:47:37 »
Does any one have more information on such a block..
I can't seem to google-fu it up..
is there a waterblock that's perfectly flat on both sides, and has enough metal contact area "in between/ around the central liquid cavity"
such that.... I could mount another 120mm air cooler to the opposite side..
So that way I could set it to turn on whenever I'm doing something gpu intensive.. but just use the 120mm air cooler  when I'm cruising...
Offline IPT
  • Formerly projectD
Re: Hybrid water and air cooling..
« Reply #1 on: Fri, 31 January 2014, 14:01:54 »
exactly where would the heat be going from the block?
Isn't the point of liquid cooling to have water flowing through the block to keep the block cool?
Are you proposing installing heat fins on a waterblock?  how would that work since in theory the waterblock shouldn't get hot with proper liquid cooling flowing and pumping.
Offline kmiller8
  •  Post Reporting Timeout
  • Who is that kmiller8 guy?
« Reply #2 on: Fri, 31 January 2014, 14:05:08 »
« Reply #3 on: Fri, 31 January 2014, 14:10:55 »
I thought this thread would be about that new ASUS Card
http://rog.asus.com/287742014/gaming-graphics-cards-2/what-is-inside-the-rog-poseidon-graphics-cards/
yea.. that's the idea..
but I want a 120mm tower on it instead of the flat block.
« Reply #4 on: Fri, 31 January 2014, 14:12:37 »
water cooling is LOUD and makes a higher pitch "whine noise"..
I want to avoid this when the computer isn't doing intensive stuff..
that's why I specified that there needs to be adequate "metal contact" around the liquid cavity in the center... because water doesn't conduct was well as metal to metal (obviously)..
Offline Oobly
« Reply #5 on: Sat, 01 February 2014, 06:58:07 »
Get a good, silent pump and mount it with rubber. Use bigger, slower fans on the radiators.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
« Reply #6 on: Sat, 01 February 2014, 12:05:00 »
There's no such thing as a silent pump..
you're probably used to a higher noise floor..
my room is ~ 26-30db with no computers running..
With my current air setup it's ~28-35...
so even if i have the BEST most quiet water pump EVER,  i will hear the tzzztzzztzzzz squegee noise because the environment is so quiet.. and any/all high frequency noise will stand out..
The reason I SAY water pumps are loud has to do with noise floor, not the fact that they're Literally High on DB
