Author Topic: Need new keyboard  (Read 2505 times)
Offline Veldslag
Need new keyboard
« on: Thu, 06 February 2014, 13:37:02 »
Hello keyboard experts,
I am thinking to buy a mechanical keyboard, as I now am typing on a Logitech K120 and am not amused by it. I was thinking of buying the Ducky Shine 3, but then I heard of the Cherry stabilizers and that they are bad? Does anyone know a good mechanical keyboard with blue switches? I bought a test kit from WASD recently and I like the blue's the best. I thought of buying a CM storm keyboard, are these ones good? It is important for me that the keyboard is good quality, and is available in the Netherlands. Any suggestions?
Thanks in advance,
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
Re: Need new keyboard
« Reply #1 on: Thu, 06 February 2014, 13:40:28 »
There's nothing wrong with Cherry stabilizers. I'm using them now and they're great. I personally prefer Costar given the choice, but I wouldn't ever pick a keyboard just based on the stabilizers. (Unless I was building it from scratch.)
Ducky Shine 3 is a great board, especially if you want fancy backlighting. If you don't care about backlighting, a Filco Majestouch 2 is in the same price range and is regarded as a higher-quality build. If you want to go with something cheaper from Coolermaster, I'd recommend the QuickFire Rapid. Very nice quality given the price and easy to mod. I'd personally avoid the QuickFire TK due to it's non-standard keyset.
Regardless, you're making a good choice ;)
« Reply #2 on: Thu, 06 February 2014, 14:23:08 »
Correct.. As long as you have a decently straight space bar.. the difference between costar/ cherry is small..
Offline PointyFox
« Reply #3 on: Thu, 06 February 2014, 14:36:12 »
Except when you're replacing keycaps.  Cherry stabilizers are easier to work with.
I like Cherry stabilizers.
« Last Edit: Thu, 06 February 2014, 14:38:11 by PointyFox »
« Reply #4 on: Thu, 06 February 2014, 15:07:30 »
um.. costar takes an extra step yes.. but how often do you do this..... enough such that it is a "problem" draining a significant amount time?...
Really a non-issue...
Offline C5Allroad
  • Formerly HUNTERANGEL121
« Reply #5 on: Thu, 06 February 2014, 15:21:31 »
Ducky makes great keyboards!
Cherry stabs aren't bad! They are easy to work with when swapping caps or cleaning the board... If you don't need backlighting then go for a Filco...
Offline BlueBär
« Reply #6 on: Thu, 06 February 2014, 15:37:01 »
I feel you, my last non-mech was a K120, too :-X
It's good that you already know which switch you want, which form factor would you prefer, tenkeyless, fullsize or 60%? Also do you want a backlit or a non-backlit board?
Offline Veldslag
« Reply #7 on: Thu, 06 February 2014, 16:52:46 »
Thanks for the replies all, very useful. I indeed forgot to mention some things, I prefer tenkeyless because I never use the numpad. Budget isn´t really an issue, getting a good durable keyboard is more important to me. I also would like a keyboard with backlights, and than preferably in white. It looks like the Ducky Shine 3 is my best option as it, unlike the filco, is available here (some importing store, but is legit according to ducky) Any more keyboard suggestions are appreciated.
And is there a way to remove that annoying verification thing when I want to post?
  • Cherry Peasant
  • keycult.com
« Reply #8 on: Thu, 06 February 2014, 17:03:31 »
What verification thing? I don't have to do any verification thing to post.
« Reply #9 on: Thu, 06 February 2014, 17:08:45 »
maybe it's a new spam security feature for new members..
Offline gh_pp
« Reply #10 on: Thu, 06 February 2014, 17:27:59 »
Yeah, new member have to gone through that for the first 20-ish posts. Just keep replying to this thread :)
agreed with riotonthebay, if you are in the US, QFR can be had for $60 on sale.
Since you want backlighting, another option is
http://codekeyboards.com/
but it's only available in black.
Also cooler master is coming out with an updated version of QFR with programmable backlighting.
QFR brown x2, Realforce 45G, Type-S, Keycool 22 blue
Previous keyboards: 55G, IBM Model M, Dell AT101W, Fujitsu FKB4725, G80-3000 clear, QFS green, QFS blue
[WTB] Custom keyboard build
Offline BlueBär
« Reply #11 on: Thu, 06 February 2014, 17:45:39 »
The Shine 3 is a solid choice then :thumb:
I don't think there is a white backlit tenkeyless keyboard, but correct me if I'm wrong.
Offline tbc
« Reply #12 on: Thu, 06 February 2014, 18:10:20 »
shine 3 (and special edition models) and code 87 are the only boards that come to mind.
additionally, the brown mx QF TK comes with white i believe.
Offline n0rvig
« Reply #13 on: Thu, 06 February 2014, 18:24:28 »
I'm surprised but I find Costar stabilizers nicer to swap keys on. Lining up those 3 crosses is easy enough, but I love the satisfaction of getting that wire into the insert.
I like Costar stabilizers.
Offline C5Allroad
« Reply #14 on: Thu, 06 February 2014, 19:07:34 »
Forgot about max keyboard! They have a TKL blue and red LEDs and come in blues and browns.
