Author Topic: Mouse Guide 2.0: A list of mice with superior sensors and more.  (Read 1036576 times)
Offline iLLucionist
  • Topre is Love.
Re: Mouse Guide 2.0: A list of mice with superior sensors and more.
« Reply #450 on: Sat, 09 April 2016, 13:26:01 »
I watched a few teardown videos of the g502, that top shell looks a bit thin. I guess I see what you mean
So... what does that have to do with double clicking? Does it matter? Is it crappy quality?
I don't have a G502 so I have no idea what build quality is like. I was just commenting on the thickness of the top shell
Ah ok. I thought you meant something specifically with the thickness of the top shell.
« Reply #451 on: Sat, 09 April 2016, 14:36:05 »
Here's the thing with these mice.. they're not designed to LAST a long time..
for example, even on the Logitechs,
Plastic gets brittle over time..  and all of these mice just has screws going directly into the plastic..
Most of the time, the screwholes are shattered with age..
sigh.......... this happened to my mx510 in the back..
I had to repair it by drilling two holes on the bottom, and tying the back together to the screw using steel wire..
Offline iLLucionist
  • Topre is Love.
« Reply #452 on: Sat, 09 April 2016, 14:44:44 »
Honestly, I believe that Mionix shells are of higher quality than logitech shells. But we'll see.. I only have my two avior 7000's for two years now.
It makes sense that quality is lower... they want you to keep coming back for more when it breaks. But it shouldn't be that way.
« Reply #453 on: Sat, 09 April 2016, 14:51:06 »
I Know righ?
Offline iLLucionist
  • Topre is Love.
« Reply #454 on: Sat, 09 April 2016, 14:53:19 »
I Know righ?
Especially if you're collecting. Perhaps hoping your kids will pick up where you left. But a G502 will never survive a legacy. WE ARE DOOOOOOMED
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #455 on: Sat, 09 April 2016, 15:05:57 »
I Know righ?
Legacy? Kids? Man (or lady idk.. maybe tp knows), some of us wear out equipment faster than others
Offline iLLucionist
  • Topre is Love.
« Reply #456 on: Sat, 09 April 2016, 15:09:54 »
I Know righ?
We'll see how the G502 will hold out once I get one. I'll put it through my rage test and see how it lasts.
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #457 on: Sat, 09 April 2016, 15:15:06 »
I Know righ?
I'll melt through mine with my lava hands :))
« Reply #458 on: Mon, 11 April 2016, 01:14:33 »
Just ordered a G100s because I wanted to try this mythical 69grams.
I think putting d2f-01f 's in it will prolly push it to 70 though..
Offline iLLucionist
  • Topre is Love.
« Reply #459 on: Mon, 11 April 2016, 01:35:11 »
Dat scroll wheel looks vintage man!
Does that require desoldering and soldering?
Offline munch
« Reply #460 on: Mon, 11 April 2016, 02:21:08 »
there's a weight in the top shell that you can unscrew too.
« Reply #461 on: Mon, 11 April 2016, 03:04:10 »
yea, accounting for that, I believe it's going to be ~ 70g
Offline Bucake
« Reply #462 on: Mon, 11 April 2016, 08:21:30 »
i actually put the weight back in..
maybe i didn't give it a fair chance to get used to it, but it was just too light
« Reply #463 on: Mon, 11 April 2016, 12:45:19 »
U just need more skillz....
nawh, Idk,  i'm excited.. hopefully it'll get there soonish..
I just hope it's not a counterfeit..   got it for $11.99 on ebay, but it's new, no box,
Actually no,  I HOPE it's a counterfeit,  then I get to complain about it to Ebay and expose the Evil ebay seller..
Offline iLLucionist
  • Topre is Love.
« Reply #464 on: Mon, 11 April 2016, 12:53:01 »
G100s has a good sensor yes? Honestly, it looks cheap to me.
If changing the buttons requires soldering, why not put in low profile topre? :D
« Reply #465 on: Mon, 11 April 2016, 12:57:08 »
for $11.99,  it IS cheap..
I looked at the PCB design online.. And from what I can tell, it doesn't look like the board would be torqued in any odd way for the traces to break..  So, my guess is, the problems people talk about switches double clicking and malfunctioning after 6 months, is likely due to the solder joint..
I noticed the recent logitech mice have all gone Lead Free.. so.. that might be the cause of the issue..
Offline iLLucionist
  • Topre is Love.
« Reply #466 on: Mon, 11 April 2016, 13:03:29 »
Good to know... I'm about to buy the G502 (and I want an G303 but those have the side tracking issue) once I've felt it in my hands.
(Cold) solder joint? Like literally where the switch pins are soldered to the PCB?
« Reply #467 on: Mon, 11 April 2016, 14:54:36 »
Most likely cold joints..
I noticed this when I took apart my G400 as well.. the soldering isn't very good.
Offline iLLucionist
  • Topre is Love.
« Reply #468 on: Mon, 11 April 2016, 15:08:18 »
Those f**kers. I think these mice are expensive enough to solder properly.
Do you have the g303 yourself?
« Reply #469 on: Mon, 11 April 2016, 15:09:57 »
No I no haz money for G303.. which is why I bought that $11.99 G100s..
Funny, cuz I spent like $40 buying all these D2F-01F.... hahahahahahaha
Offline iLLucionist
  • Topre is Love.
« Reply #470 on: Mon, 11 April 2016, 15:17:52 »
I just bought the Nikon D7200 starter kit with 105-140 lens. I'm literally broke now. That camera better take some damn good pics of mah caps.
« Reply #471 on: Mon, 11 April 2016, 19:16:23 »
Just Ordered some Kester 44 63/37  0.031, excited..   I was gonna get more 0.02,  but If I really think about it.. 0.02 is harder to use because you gotta move the wire really fast to reduce heating time..  whereas the 0.03 is a better balance and you can get things done more quickly..
It's not like 0.02 was any good when i tried it on smd anyway,  something even thinner would be better..
Offline Bucake
« Reply #472 on: Mon, 11 April 2016, 22:32:27 »
G100s has one of the highest price-to-quality ratios imo, as long as you can live without side-buttons (which you probably can since you're used to the WMO).
btw, how many switches did you get for that $40? (ebay?)
« Reply #473 on: Tue, 12 April 2016, 01:52:21 »
you get 25 switches for $40 at Mouser.com
Offline iLLucionist
  • Topre is Love.
« Reply #474 on: Tue, 12 April 2016, 05:27:21 »
F**k 'em side buttons. What's their use anyway? Mis-clicking every damm time? I have them on my avior and I only use them to go back/forward in the browser.
Offline Bucake
« Reply #475 on: Tue, 12 April 2016, 11:20:16 »
yeah a lot of people use M4 for in-game voice-activation, but i only used those buttons for browsing as well.
and now that i'm sometimes using the WMO and G100s, i've gotten used to using ALT+left or right arrow, or just right click -> back/forward. even when i use mice with side-buttons, i just forget about them and use those shortcuts anyway..
side-buttons are almost always in the way of how i grip, i think the G400 is the only exception to this. maybe the IE3 as well, but i don't even remember (it's been a while!)
thanks tp4tissue, will check it out!
« Last Edit: Tue, 12 April 2016, 11:22:46 by Bucake »
Offline iLLucionist
  • Topre is Love.
« Reply #476 on: Tue, 12 April 2016, 17:27:01 »
I know what you mean, it's annoying. My thumb is relatively long apparently, so I touch the "sniper"-button I believe it is? on the g502 as well accidentally. Pff
« Reply #477 on: Wed, 13 April 2016, 13:12:17 »
U mean the "n00b-camper" button. ?
Offline iLLucionist
  • Topre is Love.
« Reply #478 on: Wed, 13 April 2016, 14:44:31 »
That one yeah :P
Went to the store today to feel the g502 in mah hand. It feels smaller than my avior 7000. To be honest, it feels extremely crappy. All plastic works a little bit, squeeks a bit. Really weird. REALLY weird. Mouse button left / right uneven. Scroll wheel feels like it comes off a Trust mouse.
Am I doing the feelingz wrong?
« Reply #479 on: Wed, 13 April 2016, 14:55:39 »
That one yeah :P
Well, the store version is like the promiscuous-village-girl..  So..... I mean, it's been through alot, seen many hands, many rough hands..
Offline iLLucionist
  • Topre is Love.
« Reply #480 on: Wed, 13 April 2016, 15:09:07 »
That one yeah :P
Philosophical one: if it cannot withstand being a **** of many, can it withstand actual proper use by one?
« Reply #481 on: Wed, 13 April 2016, 15:36:34 »
Ya'll remember the M-BT58 ?
This was the Go-To for many offices..
It has a very low malfunctioning speed, so pretty much impossible to game with, even though it does do 570hz.
But check this out,  They bothered to COUNTERFEIT this mouse.. hahahahahahah
What's was the point.. vvvvvvvvv
http://www.abclinuxu.cz/blog/Shteffi/2007/5/alzasoft-asi-prodava-falesne-logitechy
Offline iLLucionist
  • Topre is Love.
« Reply #482 on: Wed, 13 April 2016, 16:41:05 »
Oh man yeah... those were abundant everywhere. You could not hide from them. They felt relatively decent but I had some jitter with them on some surfaces.
What sensor do they have again?
Offline Bucake
« Reply #483 on: Wed, 13 April 2016, 17:21:41 »
i wonder how big the counterfeit industry must be if they even did that mouse.
but maybe it's just because they know some miss the shape, and it was probably relatively easy to counterfeit..
« Reply #484 on: Wed, 13 April 2016, 19:50:12 »
I just don't see how much extra money they could possibly make by going that route ..
I mean, that mouse, while fine for office work, is still fairly crummy
It happened a long time ago though..  During those times, Dollar vs Yuan was still 1:8 vs the 1:6.3 today...
So I guess even a few extra dollar bump was good..
Offline iLLucionist
  • Topre is Love.
« Reply #485 on: Thu, 14 April 2016, 16:44:49 »
Do you guys know the brand "Trust"? Basically, it is Logitech, but crappy execution. But almost the same design. THAT is top counterfeit and apparently it works coz that crap is still being sold.
Offline bocahgundul
  • a seal
« Reply #486 on: Wed, 27 April 2016, 18:14:45 »
Zowie EC1-A is out of stock anywhere can I get a good mouse recommendation? I palm grip and I don't like g502 because of the akward shape and the heavy weight?
tp4? is the list updated?
Offline derpingit
« Reply #487 on: Wed, 27 April 2016, 20:16:00 »
Your post will be referenced for generations to come . Holly crap! . Good job
« Reply #488 on: Wed, 27 April 2016, 21:18:10 »
No the list is not up to date..
Assuming the mouse you're looking at is using one of the sensors above, and that it advertises (no angle snapping/smoothing),
Then it has a GOOD CHANCE of being performance equivalent.
The issue however is...  We don't really have many ways of testing it.. because most people don't own robotic arms at home..
Offline Coreda
« Reply #489 on: Thu, 28 April 2016, 21:01:35 »
Reminds me of this gif someone made of ESReality's benchmarking setup years ago, where a lamp arm and turntable was used.
Though I think in reality it wasn't the mouse that moved but rather the turntable.
« Last Edit: Thu, 28 April 2016, 21:04:16 by Coreda »
Offline bocahgundul
  • a seal
« Reply #490 on: Fri, 29 April 2016, 01:33:17 »
what? u wot m8?  ???
Offline Grim Fandango
« Reply #491 on: Sat, 20 August 2016, 16:05:43 »
Updated and added a few mice (finalmouse 2015 and Logitech G Pro). I don't have time for a huge update, but since this thread still gets so many views I will start adding mice more frequently until the list is up to date and includes the most important models.
« Last Edit: Sat, 20 August 2016, 16:07:50 by Grim Fandango »
Offline nugglets
« Reply #492 on: Sun, 21 August 2016, 13:33:43 »
Really interested in the G Pro. I've always preferred the intellimouse-style shape to Logitech's, but I think I could deal with it for a lightweight 3366 mouse with minimal gimmicks.
Offline Bucake
« Reply #493 on: Sun, 21 August 2016, 18:53:23 »
if you want? @Grim Fandango, i could help out a little bit by PMing you some mice and their specs, for example a few of the newly released 3360 mice
« Reply #494 on: Wed, 24 August 2016, 12:49:19 »
Appreciate the help. Everyone is always fee to submit some mice (and specs) that they think should be added to the list. The only real requirement is that the mouse has been tested by the community and some kind of consensus about its performance and quality has been established.
I am aware there are quite a few mice that can be added to the list. There has been a rapid growth in gaming mice that focus on performance as gamers become more aware of the things we discuss here in this thread. Not too long ago this would have been a pretty short list.
« Last Edit: Wed, 24 August 2016, 12:51:03 by Grim Fandango »
Offline geniekid
« Reply #495 on: Wed, 12 October 2016, 08:55:08 »
This thread should really be stickied.
Offline keentom
« Reply #496 on: Sun, 27 November 2016, 23:06:57 »
Hi there
I have a deathadder. When I choose 1000 as polling rate mouserate.exe still detect a value of ~500
I don't know why.
Anyone can help?
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #497 on: Sun, 27 November 2016, 23:16:32 »
Hi there
I don't know why.
Anyone can help?
I Hope for your sake that your mouse didn't suffer through a power surge like mine did. Looks like a few capacitors were damaged (I don't have the equipment to check) and now the mouse (not a Razer) is stuck on 2k dpi :/
Offline keentom
« Reply #498 on: Mon, 28 November 2016, 01:34:45 »
I uninstalled Synapse and my mouse has nox a polling rate peaks of +1000hz
It works.
Also will unstalling synapse set the dpi to the native DPI?
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #499 on: Mon, 28 November 2016, 01:48:44 »
It works.
Um, I'm not sure. If you saved a profile to the mouse then you'll probably still have your dpi configuration. Mine lost the ability to save or change profiles after the power surge.
I'm glad you found your answer :thumb:
