Author Topic: Does anyone else use high DPI?  (Read 64053 times)
Offline yasuo
  • spanengan puyeng newbie
Re: Does anyone else use high DPI?
« Reply #100 on: Wed, 24 September 2014, 05:39:46 »
500dpi on 1366x768 ;D
Logitech MK220 Colemak DH
« Reply #101 on: Wed, 24 September 2014, 09:57:17 »
it makes sense to use even 400 or 200 @ that resolution..
I use 2700dpi @ 2560x1600..
Higher dpi is more ergonomic, because I don't have to move my arm as much to get across the screen
Offline ADFX_Pixy
« Reply #102 on: Sun, 05 October 2014, 22:40:26 »
I don't see any point in using high DPI. I don't really game that much but when I play an occasional game of CoD 4, I play on low sensitivity.
CM Storm Quickfire Stealth Cherry MX Brown
Mechanicalkeyboards.com MK 2016 Cherry MX Brown
Offline munch
« Reply #103 on: Sun, 05 October 2014, 23:45:56 »
you mean WEAKENING? real men exercise by moving low-DPI-powered cursors across multi-monitor setups.
Offline cookie
    • Deskthority
« Reply #104 on: Mon, 06 October 2014, 11:36:54 »
Nope, 400DPI 100% of the time!
Offline yasuo
« Reply #105 on: Tue, 07 October 2014, 09:31:01 »
what size monitor you use?
Offline cookie
    • Deskthority
« Reply #106 on: Tue, 07 October 2014, 09:35:35 »
I have no mouse acceleration enabled on windows 7 and I am using an 27 inch monitor, with a resolution of 1920x1080.
In CS:GO I am playing with a sensitivity of 2.0
Offline iLLucionist
  • Topre is Love.
« Reply #107 on: Mon, 06 July 2015, 08:13:41 »
640x480 :-P Enough is enough..
Offline Lain1911
  • God of the Wired
« Reply #108 on: Mon, 06 July 2015, 22:08:35 »
I'm at 3000 dpi.
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #109 on: Tue, 07 July 2015, 05:17:57 »
Use 3840×2160 and need to have at least 3200dpi on my mouse to cover the screen decently  :thumb: .
Offline iLLucionist
  • Topre is Love.
« Reply #110 on: Tue, 07 July 2015, 08:12:36 »
Perhaps a nice analogy.. I was thinking about this. I now use 1600 DPI on my Avior 700 mostly for my 27" 2560x1440 without acceleration on OS X.
Isn't the DPI you use somewhat comparable to the chassis of a car like sports steering? When you use a relative low DPI (perhaps combined with mouse acceleration) on a high resolution screen it is more like a comfortable saloon car like a big old Mercedes. But when you use high DPI (with mouse acceleration off) the mouse "steers" really direct like a sports car. For instance, when I move my mouse from the middle of the screen to the left, it only takes me 2-3cm on my mat to reach the corner of the screen.
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #111 on: Tue, 14 July 2015, 22:02:43 »
I've been flipping between the top two settings on my R.A.T. 9 - 6400 and 5600(? I think) I seem to be most comfortable with the latter. However, at work I'm using something freakishly slow. Since I primarily use keyboard navigation as a developer it isn't too big of a problem.
Offline alienman82
« Reply #112 on: Mon, 20 July 2015, 21:32:51 »
removed.
« Last Edit: Thu, 01 March 2018, 17:19:05 by alienman82 »
Offline v0idtek
  • I make 3D printed stuff for keyboards.
    • v0idtek
« Reply #113 on: Tue, 21 July 2015, 23:49:00 »
I used to use high DPI when I played Quake. Specifically, I'd have to frequently 180, rocket jump, then swing back with minimal effort. After switching to shooters where managing recoil is the main challenge, I lowered my DPI significantly. I think I'm at 1600 with minimal in-game sensitivity, though in windows I use 4000.
3D printed stuff for keyboards:
www.v0idtek.com
Offline Bucake
« Reply #114 on: Wed, 22 July 2015, 04:18:55 »
800dpi on 1920x1080
to me this feels normal, but going through this thread i guess it's on the low side?
Offline jukaduke1184
« Reply #115 on: Wed, 22 July 2015, 21:26:19 »
1000 dpi is my sweet spot. This is especially true in FPS games.
Offline MykB77
« Reply #116 on: Tue, 20 October 2015, 22:51:02 »
Try this for fun... in Windows anyway.  Turn off the enhance pointer position in Pointer Options in Mouse Properties.  Turn the pointer speed way down.  In your custom gaming mouse software or on your gaming mouse... crank up the DPI really high.  Now, fairly normal movement with extreme control.  This is what I use for graphics and graphical programming for the controls systems I design.  I do this currently with a G700S and put the DPI very high.  If the mouse is moving really fast, turn down the pointer speed in the mouse properties even more.
I forgot to add, I also use a higher quality hard gaming mouse surface... Razer Sphex on home system and a SteelSeries 4HD on job sites.
Feedback?  Anyone try this?
And one more thing, the report Hz rate matters.  Set it as high as possible... 500-1000 Hz is best.
« Last Edit: Tue, 20 October 2015, 22:55:57 by MykB77 »
Offline Leslieann
« Reply #117 on: Wed, 21 October 2015, 21:29:11 »
MykB77 has almost the same as me, G700s on a Razer Sphex surface (works great on glass, but I may change it for something higher dpi).
I leave Windows settings alone, and use 5700 DPI with 1000 polling rate. For cad and graphics it works quite well on dual 1080p screens. I found that with 500 polling I couldn't always get pixel level precision on high detail work. This absolutely eats batteries though. Instead of the 2000 mah battery it comes with, I need a 2700mah to make it through a day of heavy use and even then it's often down at 10% by days end.
However, I tried using it on an old 1024x768 laptop the other day... Not going to work. haha It went flying across the screen with less than 1/4in mouse movement.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline ADFX_Pixy
« Reply #118 on: Thu, 22 October 2015, 02:05:32 »
It's been about a year since I've replied this thread and it's still up here haha.
Right now I'm using a 23.8 inch monitor (Dell U2414H) and I use 400 DPI with it. Looking at other people's DPI levels in this thread are insane for me. I guess I'm used to low sensitivity after playing CS:GO all Summer. I can barely use the 1600 DPI setting on my Zowie EC2-A without feeling I'm going way too fast. I can imagine raising my DPI a little more if I were to get another monitor or even switch to an ultrawide monitor.
« Reply #119 on: Thu, 22 October 2015, 02:23:18 »
I drop to 400 to play go and otherwise casually browse at 3600, previously 5700.
Offline Thumper_
  • Spend all my money.
« Reply #120 on: Thu, 22 October 2015, 02:43:27 »
Back in the days I used 8200 dpi or so, but currently 6/11 in Windows mouse settings and 1200dpi. No acceleration.
Offline Luca_Scorpion
« Reply #121 on: Fri, 23 October 2015, 06:05:29 »
I use 4800 dpi at 1920x1080 for everything, I prefer not having to drag my mouse halfway across my desk to reach something :P
I used to stick with 3200, but after that 4800 is something I got used to quite quickly.
Offline maybeksb
« Reply #122 on: Fri, 23 October 2015, 13:50:24 »
I've been using 4.8k dpi for the last year. Been loving it for general OS maneuvability since I mainly operate on wrist movements. Used to play planetside 2 with this and never had any problems. I'd tone down to 3.2k for aerial stuff and I didn't have too much problem contesting with top players. I saw a previous post addressing this, but it comes down to comfort imo
Edit: Forgot to say that most mice past like ~6k dpi or something uses interpolation or whats-it-called to push the dpi past what the sensor actually captures. Can't say how reliable they are, but I don't trust anything higher than 4.8k
« Last Edit: Fri, 23 October 2015, 13:52:15 by maybeksb »
Offline LXXXIX
  • Just remember all caps when you spell the man name
« Reply #123 on: Sun, 25 October 2015, 20:31:45 »
1600 @ 1920x1080
I have also tried lower sens with no luck. I don't get 200-400 it's insane. Do you guys play air-hockey with your mouse?
Offline Kola93
« Reply #124 on: Sun, 25 October 2015, 21:40:33 »
High DPI is always less accurate than a lower DPI (native) that tracks well.
Regardless, I prefer using the mouse's native DPI! ^-^
Offline tararais
  • Forum Justice Warrior
« Reply #125 on: Wed, 28 October 2015, 06:32:13 »
1600 @ 1920x1080
I think it's for snipers in FPS, so they can make precise movements, whereas really high dps is for pros who are good at doing those 'flick-shots'. Not sure though. Personally I'm comfortable at 7000-8000 with mouse sensitivity 3 on a 1920x1080, a little under 1.5 inches to cross the monitor. I'm used to having small mousepads and limited space, so now even with a giant metal hulk, it's my preference.
Offline mobbo
  • u fk
« Reply #126 on: Wed, 28 October 2015, 14:47:03 »
Really low DPI on a huge mousepad for (450-600) FPS games.
3000+ for RTS and MOBAs (Starcraft and League).
Quote from: Binge
Offline tararais
« Reply #127 on: Wed, 28 October 2015, 14:51:07 »
What mouse sensitivity is that on? AFAIK lots of people use 3, but I'm not sure.
Offline mobbo
  • u fk
« Reply #128 on: Wed, 28 October 2015, 15:03:17 »
Had to check but it's pretty much in the middle.
Quote from: Binge
Offline tararais
« Reply #129 on: Wed, 28 October 2015, 15:59:31 »
If you can increase your dpi, you might want to decrease sensitivity and increase DPI, apparently when you're above 3 sensitivity, Windows starts skipping pixels. If that's not important then  :D
Offline Leslieann
« Reply #130 on: Wed, 28 October 2015, 22:50:01 »
1600 @ 1920x1080
You have to consider how it's controlled.
Your shoulder and elbow are not precise instruments, but they do have a large range of motion, so low resolution works best. Wrists and fingers are precise instruments, but lack range of motion, so high dpi works best. Done right, both should have similar accuracy, but I would give the speed advantage to high dpi.
I'm rarely the best player, but in games that show shooting accuracy, I'm usually right at the top.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline logomachy
« Reply #131 on: Thu, 29 October 2015, 18:56:53 »
No, I use 400 dpi as it is the limitation of the 1.1a.
With 27" becoming the standard and eventually high dpi displays---
I'm worried about the future where no sensor can replace the mlt04 for me.
Offline mobbo
  • u fk
« Reply #132 on: Fri, 30 October 2015, 11:14:50 »
You know what I never noticed anything since I've been playing on a laptop screen for years. Yesterday I just got a BenQ gaming monitor and your suggested change made a really noticeable difference.
Quote from: Binge
Offline mrgoldenzombie
  • Topre is cool I guess....
« Reply #133 on: Sat, 31 October 2015, 00:37:19 »
800 DPI is my choice
O-Ringed Black RealForce 87u  | O-Ringed Novatouch with Miami PBT
Offline grav3serker
  • graves + berserker = grav3serker
« Reply #134 on: Tue, 03 November 2015, 00:38:27 »
I like 800. It works great for me!  :thumb:
Offline pyrolovesmoney
« Reply #135 on: Tue, 03 November 2015, 17:49:49 »
I go to the max dpi on my mouse without software which is 4800 DPI
Offline Bucake
« Reply #136 on: Tue, 03 November 2015, 19:49:46 »
i know what you mean!
it's impossible for me to move back to the mlt04, however, because i'm already used to better/higher tracking speeds.
my favorite is still the WMO, but it just can not keep up with my swipes.
so i just decided to stick with newer sensors/mice, because it's inevitable that the 400dpi of the mlt04 will become insufficient at some point..
(and honestly i feel better knowing that my sensor can keep up with any speed i can get out of my arm/hand!)
i use 800cpi on 1920x1080. it's kind of fast in my opinion, but it's easy to be accurate, so it's fine with me.
Offline csnickba
  • Gateron fanboy and topre lover.
« Reply #137 on: Wed, 04 November 2015, 03:30:00 »
I'm a big fan of 400dpi as a counter strike player. In game sense is 1.1 too so it's especially low. Also I used to be a 1600 user but once I got a big mousepad and lowered that sense, I really can't go back.
Offline davkol
  •  Post Editing Timeout
« Reply #138 on: Wed, 04 November 2015, 04:33:23 »
ITT mostly people, who cannot read or want to boost their post count ASAP.
