Author Topic: Glass MX caps  (Read 8499 times)
Offline Misterorjoe
Glass MX caps
« on: Sat, 19 April 2014, 13:19:48 »
Has it ever been done? And if so, can I get some?  :D
Offline jabar
Re: Glass MX caps
« Reply #1 on: Sat, 19 April 2014, 13:47:32 »
I would imagine the glass being either too heavy for the switch to hold open or too brittle for regular use (especially the cross post).
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline HPE1000
  • Keycap Paparazzo
Re: Glass MX caps
« Reply #2 on: Sat, 19 April 2014, 13:53:15 »
I thought someone here said they tried and they blew up in the kiln so they gave up.
Offline Zeal
    • Zeal Generation Inc.
Re: Glass MX caps
« Reply #3 on: Sat, 19 April 2014, 13:57:14 »
There's a thread somewhere. I think the stems were also too brittle to be removed frequently.
Re: Glass MX caps
« Reply #4 on: Sat, 19 April 2014, 14:16:20 »
maybe do not use the cross..  just make the round stem that would go in,  Then Cut the cross off the cherry slider head.. and Glue the glass part to the slider..
if you need to remove the switch.. desolder the whole thing.. LOL
Offline Misterorjoe
Re: Glass MX caps
« Reply #6 on: Sat, 19 April 2014, 19:31:08 »
Huh, are there any nice looking clear blank caps then? Or maybe acrylics?
Offline Pacifist
  • on hiatus
Re: Glass MX caps
« Reply #7 on: Sat, 19 April 2014, 19:39:20 »
if moz never wants to make another ceamocap then acrylic is probally out of the picture
Offline HipsterPunks
  • Gangnamember
Re: Glass MX caps
« Reply #8 on: Sat, 19 April 2014, 19:43:37 »
"one rage quit and you're blind for life"
sell ass and eat out
Offline HPE1000
  • Keycap Paparazzo
Re: Glass MX caps
« Reply #9 on: Sat, 19 April 2014, 19:44:20 »
And missing a couple fingers
Re: Glass MX caps
« Reply #10 on: Sat, 19 April 2014, 22:38:21 »
not necessarily!
See you can easily make glass or ceramic keycaps that are tougher than PBT. Also, you'd have to design around the stem a little, but it's possible to harden the stem up a lot. I was thinking of sintering some ceramic powder keycaps, but getting the size right would be hard. I suspect you'd have to machine the cruciform stem a little.
Long story short, it'd be a lot easier to make hall effect keycaps in basically any material.
About injuring yourself after hitting a keycap hard: I don't think so. See, you could make it so that the cap bottoms out on the switch housing which would seriously dampen the force. I doubt it'd break at all, but a nice glass-ceramic composite keycap would be more than tough enough to not shatter. Also, such a material would break into large sections rather than shattering completely. Also, you could design a stress raiser so that just the top would shear off safely. There's a lot of ways of making it safe.
TBH I think the hardest part would be to ensure that there's enough friction on the stem to keep the keycap in place.
Offline Danule
Re: Glass MX caps
« Reply #11 on: Sun, 20 April 2014, 14:51:34 »
Glass would probably be too cold to the touch for an enjoyable typing experience.  Also such a hard material would be rough on the fingers.
45g Brown Brown Blue
Offline ynrozturk
Re: Glass MX caps
« Reply #12 on: Sun, 20 April 2014, 15:08:59 »
Same could be said about metal caps, yet people use those with no problems.
IBM Model F | IMB Model M | Poker II MX Brown | Poker II MX Clear | Filco TKL MX Brown | Bastardized Razer Blackwidow TE MX Blue | Logitech G602 |  Cyborg R.A.T. 7 | | Logitech MX518 | Icemat  | Artisan Hien
Offline Danule
Re: Glass MX caps
« Reply #13 on: Sun, 20 April 2014, 15:11:29 »
that is true, I think metal is much easyer to make into a keycap.
Re: Glass MX caps
« Reply #14 on: Sun, 20 April 2014, 16:15:09 »
I tried this once, and failed miserably. The big issue is I had no clue what I was doing mold-making-wise, but the same techniques would apply I think.
Offline Oobly
Re: Glass MX caps
« Reply #15 on: Sun, 20 April 2014, 16:29:32 »
http://keyshop.pimpmykeyboard.com/product/clear-blank-full-104-keycap-sets
Full 104 key clear DCS profile set goes for 40 dollars. They also have them in blue and red semi-clear.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline cherpalla
Re: Glass MX caps
« Reply #16 on: Sun, 20 April 2014, 19:28:17 »
not necessarily!
I actually want to see someone produce this.
c h e r
Re: Glass MX caps
« Reply #17 on: Sun, 20 April 2014, 23:00:57 »
How "cold" it feels is largely a function of the thermal conductivily. Many metals have good thermal conductivety and sink heat from your hand and feel "cold". Glass (and especially glass / ceramic) can be made as as insulator and will not have this issue.
Finally, I strongly disagree that harder materials will be "rough" on the fingers. You can make glass / metal / whatever pretty smooth....
Same here! I'd have done it by now, but DIY'ing materials research projects is much harder and more expensive than normal keyboards / electronics projects. This is a large part of why I like keyboards and electrical engineering and hobbyist stuff and all that.
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
Re: Glass MX caps
« Reply #18 on: Sun, 20 April 2014, 23:47:17 »
you could refractory press medium porosity powdered SiO2 then fire, but medium porosity is typically not transparent, as to get a glass you need to melt then vitrify. there are some glass ceramics that crystallize into transparent glass, but plastic is your best bet for transparent or translucent keycaps. can't help but mention signature plastics' hybrid PBT + PC hybrid caps that combined the two resins to form a compound material that, when injection molded, had a glassy surface on the outside and opaque surface inside. the interesting thing about these, was that unlike overmolding, the change in reflectivity was gradual and isometric. very cool little caps.
Offline cherpalla
Re: Glass MX caps
« Reply #19 on: Mon, 21 April 2014, 07:25:55 »
I'm working on some resin keycap projects atm, trying to do some interesting things with it. I think I just want to see a glass keycap because of the material, not for the transparency.
c h e r
Offline ynrozturk
Re: Glass MX caps
« Reply #20 on: Mon, 21 April 2014, 07:55:23 »
Would be interesting to see what glass caps would look like.
Offline futurebird
Re: Glass MX caps
« Reply #21 on: Mon, 21 April 2014, 17:18:42 »
I have an idea for making porcelain caps using resin casting. There is a kind of imitation porcelain additive that ought to be interesting. It's coming with the next batch of supplies. I'm excited.
Offline cherpalla
Re: Glass MX caps
« Reply #22 on: Mon, 21 April 2014, 18:36:25 »
Awww crap, we have the same idea!!
c h e r
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
Re: Glass MX caps
« Reply #23 on: Mon, 21 April 2014, 19:55:43 »
Thick glass caps (clack solid) with no stiffening ribs, and with bubbles in the glass.
Offline Misterorjoe
Re: Glass MX caps
« Reply #24 on: Mon, 21 April 2014, 21:22:42 »
I would love to have some glass/acrylic/resin caps. That would be sick.
Re: Glass MX caps
« Reply #25 on: Mon, 21 April 2014, 23:41:50 »
Thick frosted glass would be the goal, and it would even be possible to layer different colors that melt at different temps.
Offline cherpalla
Re: Glass MX caps
« Reply #26 on: Tue, 22 April 2014, 07:11:38 »
I'm working on resin caps right now, I have a few different types of resin I'm working with. ^_^
c h e r
Offline futurebird
Re: Glass MX caps
« Reply #27 on: Tue, 22 April 2014, 07:43:25 »
Are you using 1:1 or the harder to mix and cure poly resin? I just de-moulded my first batch of poly pieces and I think due to the small size of the mould they will need a few days to cure. But despite some issues with my inclusions moving around they look promising (to me. Ha Ha...I'm going to do another batch today. ) I'm working on this cool geometric keys mould. But I need more silicone!
They are still too tacky to trim or polish. Hence, the rough look.
Offline pbtforever
Re: Glass MX caps
« Reply #28 on: Tue, 22 April 2014, 09:29:04 »
haha!  Fun!
Offline Demetrium
Re: Glass MX caps
« Reply #29 on: Tue, 22 April 2014, 09:42:33 »
Haha, I was thinking the same. I remember a friend of mine smashed his keyboard back in the day playing X-Wing vs Tie Fighter and literally every key flew off his keyboard. Guy would be dead right now.
Offline cherpalla
Re: Glass MX caps
« Reply #30 on: Tue, 22 April 2014, 11:38:43 »
I have three different types of resin I'm working with, poly, acrylic and epoxy.
They look pretty good from your pics, though.
c h e r
Offline tricheboars
  • Keyboards are Important!
Re: Glass MX caps
« Reply #31 on: Tue, 22 April 2014, 12:46:00 »
would it be possible for the stem insert on the cap itself to have tiny ridges on the inside to prevent all the glass caps from sliding off if upside down?  can you guys get that precise when creating glass molds?  can we make the glass smooth enough that it is comfortable to the touch?
imagine stained glass keycaps and white LEDs.  that would be really cool.
Offline Oobly
Re: Glass MX caps
« Reply #32 on: Tue, 22 April 2014, 13:31:56 »
Quoting myself in case the OP missed my post... You can get a full set of clear keycaps from the link I posted for just 40 dollars!
Offline cherpalla
Re: Glass MX caps
« Reply #33 on: Tue, 22 April 2014, 13:57:40 »
I've got all kind of crazy ideas in my head...
What about using something else for the stem, something less fragile that would adhere to the glass without being damaged during the process?
c h e r
Offline cherpalla
Re: Glass MX caps
« Reply #34 on: Tue, 22 April 2014, 13:58:23 »
Oobly, thanks for the post. I think this conversation is more about material than transparency.  :))
c h e r
Offline tricheboars
Re: Glass MX caps
« Reply #35 on: Tue, 22 April 2014, 14:45:14 »
sure. but how will you attach it to the clear glass cap without some sort of fugly glue?  my worry would be a LED showoff of your badass work work only accent/highlight the method to piece the caps together.
ideally a solid piece would be best no doubt. but then again i know jack **** about glass. all i know is that blowing traditional stain glass can be very dangerous. my aunt passed away at 38 from brain cancer. she made stain glass windows for catholic churches down in Louisiana.  my family always thought the glass blowing might have contributed.  we dont know for sure. but heads up on that.
Offline cherpalla
Re: Glass MX caps
« Reply #36 on: Tue, 22 April 2014, 16:05:09 »
I wouldn't use a regular glue, I would maybe cast the stem and a flat rectangle onto the glass cap or something like that, perhaps with the epoxy resin encasing the glass with a thin coat. I have no idea if this would work, but there are certainly other options other than some ****ty glue and making the adhesion look nice could certainly be part of the art.
c h e r
Offline Melvang
Re: Glass MX caps
« Reply #37 on: Tue, 22 April 2014, 16:40:50 »
The progression very well could have contributed to the cancer, but chances are not from the glass.  Glass itself is very inert.  My bet would be on the lead that is/was (not sure if it is still used) in the framework that holds the pieces together.
Stained glass caps would be awesome.  Though my vote would be for solid 1 price caps but with no ribs.  Glass would be stiff enough that they would should not be needed.
Offline cherpalla
Re: Glass MX caps
« Reply #38 on: Tue, 22 April 2014, 16:48:37 »
They would be so prettyyyyy /girl
c h e r
Re: Glass MX caps
« Reply #39 on: Tue, 22 April 2014, 17:23:17 »
There was a resin keycap GB not that long ago.  Apparently the keys were really, really loose (like press a key, and the keycap pops off when the switch springs back up).
I don't know if that turned out to be a manufacturing defect, or a side-effect of the plastic, but it might be something to bear in mind :)
Offline Pacifist
  • on hiatus
Re: Glass MX caps
« Reply #40 on: Tue, 22 April 2014, 17:25:34 »
iirc manufacturing with humidity and all
Offline cherpalla
Re: Glass MX caps
« Reply #41 on: Tue, 22 April 2014, 18:28:21 »
I bought $140 worth of them... I'm well aware... however, I'm producing them in small batches, without a vacuum or pressure chamber and no humidity issues around here. :)
There's also a few types of cold-casting resins so I'm experimenting.
c h e r
Offline Misterorjoe
Re: Glass MX caps
« Reply #42 on: Tue, 22 April 2014, 19:26:02 »
I did see those, but they are not quite as clear as I was looking for. They are a bit frosted and such.
Re: Glass MX caps
« Reply #43 on: Tue, 22 April 2014, 20:15:40 »
$140 - ouch!
it's often said that you shouldn't criticise someone unless you can do better yourself.  Sounds like you are well on the way to doing exactly that! :)
