Author Topic: Post Pictures Of Your Desk/Set Ups!  (Read 2478853 times)
Offline iLLucionist
  • Topre is Love.
Re: Post Pictures Of Your Desk/Set Ups!
« Reply #5800 on: Sat, 22 April 2017, 15:46:46 »
Philips Hue provides the lighting
Wait... did you drill a hole in your desk to tuck away the HHKB cable?
Yes
Interesting, I think I did not saw this before.
There is this channel on YouTube... Rate My Setup. And there you see more people doing it.
It looks very clean, I like it. But I wouldn't quickly do it myself.
OK, this channel I don't know, thanks for that! I also would not put a hole in my wooden desktop plate, but a refreshing idea for cable management (in which I am really bad).
I always think I made my setup clean. Then I go online and see these amazing setups: instant depression.
Offline Severe
  • HHKB Zealot
« Reply #5801 on: Sat, 22 April 2017, 17:31:09 »
Rebuilding the PC today and redoing some desk layout. new pics soon
HHKB Pro 2 Black Lubed 55g
Logitech G502 (Gaming) Logitech MX Master 2 (Day to day)
Offline Severe
  • HHKB Zealot
« Reply #5802 on: Sat, 22 April 2017, 22:09:05 »
Rebuild done!
Specs:
Core i7 7700k at 4.8 ghz Cooled by a Corsair H100i V2
32GB of COrsair Dominator Platinum DDR4 @ 4000mhz
Asus Z270i Mini ITX motherboard
NVidia GTX 1080ti Reference
Fans are Noctua PPC 2000RPM
Corsair power supply
166638-0
« Reply #5803 on: Sat, 22 April 2017, 22:20:23 »
Rebuild done!
Specs:
similar build. what voltage for 4.8? I kept trying to push for 5.0 but didn't find anything stable that I was comfortable with. Also with a H100i v2
Offline Severe
  • HHKB Zealot
« Reply #5804 on: Sat, 22 April 2017, 22:42:05 »
Rebuild done!
Specs:
1.245 volts very stable.
The 7700k is a hot little ****er, I had to replace the corsair fans on the 100iv2 with better from Noctua to keep the temps down. It never goes over 68c but it also hovers in the high 30s and low 40s at 1% cpu usage
Offline iLLucionist
  • Topre is Love.
« Reply #5805 on: Sun, 23 April 2017, 06:16:58 »
Rebuild done!
Specs:
That's similiar to my build as well (i7 6700K but not OC yet, 64GB DDR4, 980 Ti Strix OC D2, Noctua everything).
Looks nice and clean man!
How did you drill a hole in your desk?
Offline Rayoui
« Reply #5806 on: Sun, 23 April 2017, 07:22:27 »
I always put my computer under the desk. I don't want lights flashing in my face and fan noise right next to my head all the time. Not to mention how much room a full tower takes up on top of a desk.
I like minimalist not-being-there style. I like my desk as clean as possible. Preferably, I want another place for my audio interface and my external USB drive as well. And get rid of my monitor stand.
Fans agreed, but not an issue. I built a very very silent pc. Power supply fan is always up until 80% load, GPU fan is off until gaming. CPU fan is only 800rpm (Nocta NH-D15, so are the two noctua 120/140mm case fans.
I HATE pc noise. I want to hear nothing but my own breathing and the clickclack or thock of mah boards.
I'm also a fan of minimalism and quiet builds. I use a Fractal R2 without a window so there are no external lights other than the power indicator. All six case/radiator fans are 140mm Noctua fans and GPU fans are off unless gaming. I still like the PC under the desk so what little noise does come through doesn't interfere when I'm using open-back headphones.
I thought about doing an ITX build because they look so cool but tiny fans + reference GPU cooler = Boeing 747 in the living room.
Mira SE  |  Clueboard  |   B.face  |  HHKB Type-S
Offline iLLucionist
  • Topre is Love.
« Reply #5807 on: Sun, 23 April 2017, 08:04:29 »
Yeah exactly. I I were to do an ITX build (I was thing about one with the Fractal Core case), I'd probably go for an underpowered system and try to cool it almost passively. Seasonic has 400W fanless PSU's. a 750Ti should also exist without fan. Then you're only left with CPU cooler. So if you stick a i5 or i3 in there and the Noctua NH-D15 should fit in that confined space. Then I guess you have a near silent PC still in a small form factor and yet upgradeable.
Small boxes exists, passively cooled. But again, as with Apple products (mac mini comes to mind), everything is custom and soldered. That's exactly the kind of products I'm nowadays trying to stay away from.
Offline Severe
  • HHKB Zealot
« Reply #5808 on: Sun, 23 April 2017, 10:25:28 »
16mm spade bit is perfect for being just big enough to get the small side of the USB thru for your keyboard. Then it's just a matter of being very sure about where you want to put the hole. Mine is dead center left to right. but back a few inches from the front. works great for my HHKBs but my Pok3r is a bit wonky because the cord comes out of that on the left side not center
Offline iLLucionist
  • Topre is Love.
« Reply #5809 on: Sun, 23 April 2017, 11:14:26 »
It looks nice buuttt... aren't you afraid that if you want to change your setup you have that wide gaping hole in your desk?
Offline kiwi99
  • that's a gnarly dookie
« Reply #5810 on: Sun, 23 April 2017, 13:03:59 »
Rebuild done!
Specs:
which case is this? cant tell with the lighting haha
Offline Khers
  • Schrödinger's box
« Reply #5811 on: Sun, 23 April 2017, 14:46:45 »
« Last Edit: Tue, 03 July 2018, 08:57:42 by Khers »
Offline iLLucionist
  • Topre is Love.
« Reply #5812 on: Sun, 23 April 2017, 15:16:11 »
Fine monitor you got there! I recently bought the same for a build I did for someone.
Offline Khers
  • Schrödinger's box
« Reply #5813 on: Sun, 23 April 2017, 15:32:20 »
« Last Edit: Tue, 03 July 2018, 08:57:36 by Khers »
Offline alienman82
« Reply #5814 on: Sun, 23 April 2017, 15:43:40 »
removed.
« Last Edit: Thu, 01 March 2018, 12:58:42 by alienman82 »
Offline davkol
  •  Post Editing Timeout
« Reply #5815 on: Sun, 23 April 2017, 15:46:02 »
Somebody loves Microsoft…
Offline alienman82
« Reply #5816 on: Sun, 23 April 2017, 15:47:32 »
removed.
« Last Edit: Thu, 01 March 2018, 12:58:40 by alienman82 »
Offline jcc04
« Reply #5817 on: Sun, 23 April 2017, 16:30:15 »
I am a sucker for matte black, I really need to get rid of this white pok3r...
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #5818 on: Sun, 23 April 2017, 17:11:16 »
I got the other color spectrum.  Great case
Love that background.  Where did you find it?
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline iLLucionist
  • Topre is Love.
« Reply #5819 on: Sun, 23 April 2017, 17:16:51 »
How can you tell? What am I not seeing?
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
« Reply #5820 on: Sun, 23 April 2017, 17:21:27 »
Microsoft sticker on the tower.
Offline iLLucionist
  • Topre is Love.
« Reply #5821 on: Sun, 23 April 2017, 17:37:39 »
Omg... why didn't I see that before. Guess I'm trying to channel all their influences on me out hehe
    • WTB/WTTF Thread
« Reply #5822 on: Sun, 23 April 2017, 17:41:11 »
Yeah I had to look for it too. Took me a bit.
Offline alienman82
« Reply #5823 on: Sun, 23 April 2017, 17:50:55 »
removed.
« Last Edit: Thu, 01 March 2018, 12:58:22 by alienman82 »
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #5824 on: Sun, 23 April 2017, 18:14:42 »
Not sure where I got it, but here I attached it:
Cool. Thanks
WTB/WTS/WTT ---->
Offline kiwi99
« Reply #5825 on: Sun, 23 April 2017, 18:18:31 »
I've never seen an ncase look so bad  :)) pls
Offline alienman82
« Reply #5826 on: Sun, 23 April 2017, 18:41:21 »
removed.
« Last Edit: Thu, 01 March 2018, 12:58:19 by alienman82 »
Offline Severe
  • HHKB Zealot
« Reply #5827 on: Sun, 23 April 2017, 19:05:41 »
It's was 70$ for the desk top. If I change and need to replace the desk. I'd just get a new top for it
Offline Severe
  • HHKB Zealot
« Reply #5828 on: Sun, 23 April 2017, 19:06:50 »
Rebuild done!
Specs:
Fractal design define  nano S
Offline davkol
« Reply #5829 on: Mon, 24 April 2017, 04:36:14 »
Offline Khers
  • Schrödinger's box
« Reply #5830 on: Mon, 24 April 2017, 05:39:26 »
« Last Edit: Tue, 03 July 2018, 08:57:31 by Khers »
Offline iLLucionist
  • Topre is Love.
« Reply #5831 on: Mon, 24 April 2017, 08:41:35 »
Smart thinking. Now I wanna drill holes...
Offline Severe
  • HHKB Zealot
« Reply #5832 on: Mon, 24 April 2017, 12:08:45 »
Once you drill the hole, and no longer see that cord running around on the desk top, you won't be disappointed
Offline iLLucionist
  • Topre is Love.
« Reply #5833 on: Mon, 24 April 2017, 12:12:05 »
Yeah first I need to get myself a nice piece of wood. Then I'm gonna gape that piece of wood no doubt. Hopefully I don't mess it up..
Offline davkol
« Reply #5834 on: Mon, 24 April 2017, 17:07:30 »
First-world problems…
Offline iLLucionist
  • Topre is Love.
« Reply #5835 on: Mon, 24 April 2017, 17:19:54 »
But...but... the not seeing of the cables will be sooo satisfying!
But yeah... it's not necessary of course.
Offline duynguyenle
  • Personal text? What personal text???
« Reply #5836 on: Wed, 26 April 2017, 10:13:23 »
What mouse pad is that?
| QFR            | Leeku 1800    | Raptor K1      | Dolch Pac
Offline alienman82
« Reply #5837 on: Wed, 26 April 2017, 10:49:11 »
removed.
« Last Edit: Thu, 01 March 2018, 12:58:06 by alienman82 »
Offline duynguyenle
Offline alienman82
« Reply #5839 on: Wed, 26 April 2017, 13:34:09 »
removed.
« Last Edit: Thu, 01 March 2018, 12:58:04 by alienman82 »
Offline menuhin
« Reply #5840 on: Wed, 26 April 2017, 15:25:35 »
The mouse should also catch up with the monitor and the keyboard.
IBM M13 black
NeXT non-ADB keyboard (AAE)
HHKB Pro 2 HasuBT
Offline alienman82
« Reply #5841 on: Wed, 26 April 2017, 15:33:25 »
removed.
« Last Edit: Thu, 01 March 2018, 12:58:00 by alienman82 »
Offline MMKB
« Reply #5842 on: Wed, 10 May 2017, 17:19:11 »
Key klack and kitty.
Offline TopreFan333
« Reply #5843 on: Fri, 12 May 2017, 00:38:29 »
What's the screensaver? I dig the type.
Offline Coreda
« Reply #5845 on: Fri, 12 May 2017, 08:36:20 »
Sleek looking case. Mind me asking which board that is? Looks like something less than a 60% with the lack of number row, which is curious.
Offline RobotMalcolmX
  • hackerman
« Reply #5846 on: Fri, 12 May 2017, 09:19:01 »
Looks like a JD45 to me.
Offline MMKB
« Reply #5847 on: Fri, 12 May 2017, 10:04:47 »
Padbury it is.
Offline Str1pez
« Reply #5848 on: Fri, 12 May 2017, 11:59:34 »
Finally got my VB87M operating on my Win 7 work machine.  Feels nice to have my own peripherals finally.  Mouse is an old Logitech G5.
Now if only my company would upgrade this old ass 17" 4:3 monitor...
Offline danwomansan
  • Also known by my real name, ********!
« Reply #5849 on: Fri, 12 May 2017, 17:07:30 »
crowded desk, lots of screens for various things
it's pronounced "danw omansen", not "dan woman san"
