Author Topic: I hate GeekKeys Ironman Key Cap. So Heres a better one.  (Read 6249 times)
Offline BuffBen
« Last Edit: Sat, 24 May 2014, 01:48:02 by BuffBen »
Offline anoxy
  • Deal with it
Re: I hate GeekHack's Ironman Key Cap. So Heres a better one.
« Reply #1 on: Sat, 24 May 2014, 01:27:19 »
Not a fan of ironman myself, but I think it would look even better if the mask was recessed into the cap a bit more.
Offline baldgye
  • Will Smith Disciple
Re: I hate GeekKeys Ironman Key Cap. So Heres a better one.
« Reply #2 on: Sat, 24 May 2014, 04:22:14 »
Everytime I see 'ironman' keycap I'm disappointed it's not just a bust of Robert Downey Jr...
Offline Michael
  • Formerly Bro Caps
« Reply #3 on: Sat, 24 May 2014, 05:52:54 »
Offline baldgye
« Reply #4 on: Sat, 24 May 2014, 06:18:15 »
I knew you'd be the one to pull through for me
Offline blackbox
« Reply #5 on: Sat, 24 May 2014, 06:40:27 »
Hm which process did you use to procude that key? laser? pad print?  :p
The LAN table!
Offline Michael
  • Formerly Bro Caps
« Reply #6 on: Sat, 24 May 2014, 06:41:36 »
Flesh Stamp.
Offline blackbox
« Reply #7 on: Sat, 24 May 2014, 07:17:38 »
Flesh Stamp.
oh right, forgot about that technique!
The LAN table!
Offline tigersharkdude
« Reply #8 on: Sat, 24 May 2014, 07:22:35 »
Are these seriously on $4 for the "strong and flexible plastic"?
EDIT: and is just me or is the Iron Man's head facing the wrong direction on the key profile?
« Last Edit: Sat, 24 May 2014, 07:27:28 by tigersharkdude »
« Reply #9 on: Sat, 24 May 2014, 07:39:46 »
Definitely a must buy right there.
« Reply #10 on: Sat, 24 May 2014, 07:58:26 »
make it happen, BroCap'n ... I'd buy it
Offline C5Allroad
  • Formerly HUNTERANGEL121
« Reply #11 on: Sat, 24 May 2014, 13:03:22 »
14k gold.....
Woah....
It looks really cool. But not really a fan of Iron man lol.
Offline BuffBen
« Reply #12 on: Sun, 25 May 2014, 07:11:53 »
14k gold.....
Woah....
i just allowed all types to be purchased its not only 14k gold.....
Offline BuffBen
« Reply #13 on: Sun, 25 May 2014, 07:13:13 »
no its not facing the wrong way.
Offline pexon
  • El Jefe of Sleeving
    • Pexon PCs
« Reply #14 on: Sun, 25 May 2014, 07:58:29 »
What profile is that then? What row?  ::)
« Reply #15 on: Sun, 25 May 2014, 13:11:58 »
Have you actually made one and tried it out?  Looking at the bottom of the model, it looks like the iron man mask you used will interfere with the switch housing since it sticks through the bottom of the cap a considerable distance.
« Reply #16 on: Sun, 01 June 2014, 09:15:15 »
ordered one yesterday and received this this morning
"Hi Brad,
After taking a closer look, we cannot print part of your order xxxxxxx, placed on 05/31/2014.
We’ve credited $4.27 to your Shapeways account for the following:
1 X Iron Man Head in Coral Red Strong & Flexible Polished designed by ben_c_mona - $4.27"
« Reply #17 on: Sun, 01 June 2014, 09:24:33 »
Yes! That is awesome!
Just watched iron man 3 last night. Love those movies.
Too bad this cap doesn't work.
« Reply #18 on: Sun, 01 June 2014, 17:51:28 »
From Shapeways "Also, the note on the rejection from production on the iron man head was as follows: “The areas noted in the attached picture are too thin to withstand our manufacturing process without breaking. They are at risk of breaking during the polishing process. All materials specified as dyed or polished are manually cleaned and then submerged in a circular vibratory tumbler full of thousands of ceramic pellets for several hours. Each pellet is approximately 4.5mm wide and 11mm long, and will exert a slight pressure on all sides of your model during polishing. This can cause some wires or walls to break. The larger the model, the thicker the wires and walls must be to support the overall geometry and the pressure around the model during powder removal, as well the weight of the ceramic pellets during polishing. Thickening the areas shown in the picture will decrease the possibility of the model breaking during the polishing cycle. We encourage you to iterate on your design to ensure a quality print.”
I'll post a picture shortly
Offline CaptLock
« Reply #19 on: Mon, 02 June 2014, 09:13:29 »
I want one!
« Reply #20 on: Mon, 02 June 2014, 11:07:38 »
Idk....  while I am not a fan of the iron man key myself..   THIS one is facing UP..
when you look down at the keyboard... you'd be looking at Ironman's chin..
so.... idk...
To begin with, I really don't think -heads- really translate well on the keycaps medium.
Offline cherpalla
« Reply #21 on: Mon, 02 June 2014, 21:26:41 »
Just some advice for the future:
"I hate GeekKeys Ironman Key Cap. So Heres a better one."
Feng is a member of this community. While I think we all, including him, can appreciate adverse opinions, this subject line is rather rude. You don't need to bash someone else's artwork to market your own.
Just my two cents.
Cherp
c h e r
