Author Topic: Poker 2 factory space bar stabilizer lubrication  (Read 1358 times)
Offline feizor
« on: Tue, 27 May 2014, 03:04:04 »
I couldn't find an answer to this anywhere so posting the question here.
My Poker 2 came from the factory with some lubrication sprayed onto the space bar stabilizers. Does anyone know what sort of lube that is? It seems to work really well. I tried putting some grease at the wire joint but it does not work as well as the factory spray on lube for space bar.
Offline Hyde
  • White Tofu Extraordinaire
Re: Poker 2 factory space bar stabilizer lubrication
« Reply #2 on: Tue, 27 May 2014, 10:01:16 »
http://elitekeyboards.com/products.php?sub=access,misc
Lube 1 is thicker, works better for Costar Stab.
Lube 2 is thinner, works well for Cherry Stab.  <--- You want this for Poker 2
EDIT:  omg tp4 is alive !  :D
