Author Topic: Mouse and Mouse Pad Cleaning  (Read 9869 times)
« on: Thu, 05 June 2014, 14:31:44 »
How often do you clean your mouse or mouse pad?
Any recommended procedures?
Re: Mouse and Mouse Pad Cleaning
« Reply #1 on: Thu, 05 June 2014, 14:33:34 »
I wipe my mouse with isopropyl alcohol, wet naps, and/or a soap and water. Mouse pad gets hand washed in the tub/sink with a bit of laundry detergent and soap. Add water, soap, and detergent, roll the mouse pad up and scrub. Or you can use a cloth. I just air dry when I'm done. I've done this to all my mice with no issue. And I have the smaller Steelcase QCK+ mousepads.
Offline sacratoy
    • Twitch
« Reply #2 on: Thu, 05 June 2014, 14:34:33 »
I have a Steelseries QCK Heavy that I wash with hot water and a light shampoo in my bathtub. Had the pad for about 2 years, still looks new.
I have no experience washing mice sadly.
Poker II
« Reply #3 on: Thu, 05 June 2014, 14:35:28 »
If the mouse is really dirty, the cotton swabs/Q-Tips are nice too.
Offline SSIPAK
  • ★ Bootlegcaps ★
« Reply #4 on: Thu, 05 June 2014, 16:30:05 »
I use Lysol disinfecting wipes for my mouse. As for my mouse pad, i use liquid detergent + warm water and scrub my mousepad with a toothbrush.
Offline exitfire401
  • The Force is Re/\l
« Reply #5 on: Thu, 05 June 2014, 16:33:24 »
My mouse either gets a disinfectant wipe or lens wipe once every couple of months. As for my mousepad, when it starts getting bad, I just throw it in the washing machine with a load of laundry and let it air dry.
Offline neunelfer
  • HHKB Pro
« Reply #6 on: Thu, 05 June 2014, 22:21:20 »
I just washed my Artisan Hien per their instructions and it looks brand new. Lay it flat in a pan, soak with warm water and scrub lightly with your fingertips and soap. They warned not to bend or roll it at all. Then I just dabbed it with a towel and laid it flat to dry.
Offline davkol
  •  Post Editing Timeout
« Reply #7 on: Fri, 06 June 2014, 04:40:34 »
Just a wet washcloth to remove dust every now and then.
Offline UnlikeAny
« Reply #8 on: Fri, 06 June 2014, 08:39:20 »
How do you remove dirt from small gaps? I tried using toothpick, but in some parts it's just too big. I'm thinking about getting a needle and cutting/smoothing its pointy end. Don't want to scratch my mouse.
« Reply #9 on: Fri, 06 June 2014, 08:42:19 »
Pocketknife if Q-Tips don't work.
Offline Fire Brand
  • Keeper of Rainbows
  • BISCUITS!
« Reply #10 on: Fri, 06 June 2014, 09:36:36 »
I thought I had posted on this thread or one asking the same question, I basically just showered with the mat under myself, worked pretty well and ended up smelling quite nice if you ask me :p otherwise I just get a damp cloth to wipe it down with and leave it to dry flat outside for a day :)
As for mouse cleaning I usually just open the thing up since I end up messing with them so often and I have so many still boxed I don't use, once opened I just clean them with antibacterial wipes, and if the eye needs cleaning a quick spray of that alcohol based contact cleaner sorts them out as for the pads I just cut new ones out.
My Youtube Channel ~
Keyboards owned
My classified thread :3
Offline suby4me
« Reply #11 on: Fri, 06 June 2014, 09:47:14 »
I usually wipe down my mouse and mat every day or every other day. I just have a microfiber cloth because I'm afraid to use any other material due to scratches. If it's really dirty, just a bit of water on the cloth and then I do a wipe down. For the narrow regions, I used to use a toothpick. The more narrow regions, I use the edge of a twist tie. Whatever works  :))
current: poker 2 | HHKB pro2, Novatouch | off: das keyboard 4 | Ducky 3 TKL | death by coffee das keyboard mac ver. | razer blackwidow | whitefox | corsair K70 RGB
« Reply #12 on: Fri, 06 June 2014, 17:09:23 »
Like once a month I'll wipe down my mp w/ a wet cloth. Actually now that I think about it, since I got one of those Techkeys brushes I don't even think about it and brushing off my gear is like second nature  :)
Offline Photoelectric
« Reply #13 on: Fri, 06 June 2014, 17:12:27 »
I use "7th Generation Surface Cleaner" on like everything--it's non-toxic / ammonia free and is really great for streak-free glass cleaning.  I got it to clean glass habitats for my small pets and have since been using it for everything else for 3 years now: monitors, desk, keyboards, mouse, aluminum mousepad, etc.  It's super cheap too: around $3 on sale at most supermarkets.
I clean my mouse when it looks dirty--maybe every couple weeks I wipe it with a paper towel soaked in that cleaner.  Basically any time I can see or feel any dirt.  I also spray some on a paper towel and do some quick swipes on keyboard caps around once a week.
Offline SSIPAK
  • ★ Bootlegcaps ★
« Reply #14 on: Fri, 06 June 2014, 17:51:29 »
so its safe to use on the monitors? I am just afraid to use glass cleaners on my monitor because i heard that it might strip the coating on it.
« Reply #15 on: Fri, 06 June 2014, 17:54:56 »
It's ammonia-free--I've not had any issues using it on plastics and my monitors (some have tempered glass over them, some don't).
Offline SSIPAK
  • ★ Bootlegcaps ★
« Reply #16 on: Fri, 06 June 2014, 17:56:48 »
Ah okay, thanks for the info. I will have to try this later today.
Offline Zeal
    • Zeal Generation Inc.
« Reply #17 on: Fri, 06 June 2014, 18:41:05 »
I've never had to clean my mousepad...it's always looked as new as day 1. Am I doing something wrong?
« Reply #18 on: Fri, 06 June 2014, 19:13:08 »
Yeah, I'm with you here. I don't know what the rest of these animals are doing. Never really need more than a quick brush off.
« Reply #19 on: Fri, 06 June 2014, 19:35:14 »
My office building is really dusty inside.
« Reply #20 on: Fri, 06 June 2014, 19:37:40 »
Ah...  I actually did this a while back..
Basically  You want to just Wet the surface...   then use a handtowel.. and some mild soap.  and lightly  do small circles on the surface...
This prevents destroying the rubber back, and also prevents the glue from coming undone...
Offline Prelim
« Reply #21 on: Thu, 10 July 2014, 15:08:11 »
watch out with using alcohol to clean rubberized mices like the DA, I just damaged the cover once doing that!
2x GH60 revC - lubed Linjärs 65g / lubed H1s 65g with SPRIT 5mm acrylic plate | Dolch PAC - Cherry housing / Gateron sliders 65g and QMK clips | Raptor K1 G80-1890 stock
Floating on Cherry/GMK caps
