Author Topic: OMG.. middle clicking  (Read 5248 times)
« on: Tue, 17 June 2014, 11:53:59 »
on (firefox) browser tabs closes them...
WOW!!!!!!!!!!!
  • Live long and prosper
Re: OMG.. middle clicking
« Reply #1 on: Tue, 17 June 2014, 11:56:36 »
and this is news how?
it's the same in Chrome.
tp thread is tp thread
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #2 on: Tue, 17 June 2014, 11:59:07 »
And IE
« Reply #4 on: Tue, 17 June 2014, 12:01:59 »
I just double click my firefox tabs to close them.
Offline intelli78
« Reply #5 on: Tue, 17 June 2014, 12:03:33 »
It also opens links in a new tab :)
« Reply #6 on: Tue, 17 June 2014, 12:04:09 »
? doesn't work on my FF...  is this a custom setting?
« Reply #7 on: Tue, 17 June 2014, 12:21:12 »
Oh I guess I must have one of those fancy add-ons or extensions installed for it :D
Offline Frenir
  • HHKB Viking
« Reply #8 on: Tue, 17 June 2014, 12:22:55 »
You can also Middle-Click an already open program in you task bar and it'll open a new window of that program :)
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #9 on: Tue, 17 June 2014, 12:24:35 »
Unless they are those fancy non-standard links that hijack you into a popup window or force you to open in the current tab.  Those make me fly into a blind rage.
tp, have you ever used linux regularly?  Select + middle mouse to copy/paste is pretty much the best thing ever.
« Reply #10 on: Tue, 17 June 2014, 12:27:06 »
holy crap I have so been missing out....I don't ever use middle click for anything but this is one useful tidbit I will keep in mind...thanks!! :thumb:
« Reply #11 on: Tue, 17 June 2014, 12:34:00 »
Double WOW!!!!!!!!!
« Reply #12 on: Tue, 17 June 2014, 12:35:45 »
I scroll with middle click because the speed is easier to control
Offline baldgye
  • Will Smith Disciple
« Reply #13 on: Tue, 17 June 2014, 12:37:17 »
I use it all the time when browsing the web, but literally never thought of using it on the desktop... life, changed.
Offline Frenir
  • HHKB Viking
« Reply #14 on: Tue, 17 June 2014, 12:38:42 »
I do the same :D
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #15 on: Tue, 17 June 2014, 13:03:35 »
Ctrl + W you mouse wielding plebs
|||My other keyboards :
x
Offline Frenir
  • HHKB Viking
« Reply #16 on: Tue, 17 June 2014, 13:11:01 »
AND ctrl + t opens new tab.
ctrl + shift + n... ahem...
« Reply #17 on: Tue, 17 June 2014, 13:17:37 »
I think Middle click has the advantage ... because Ctrl+W only works if the very next tab will be the one you want..
Usually I 'd have at least 5 tabs, up to 10 maximum...  So the very next tab after Ctrl+W isn't likely to be the one I'm after..  So I'd have to move the mouse ANYWAY.. to get to the one I want..
If I move the mouse ahead of time to the tab section, then that sets me up for smooth transition combo of middle click, move then left click..
Offline eth0s
  • Peace & Love
« Reply #18 on: Tue, 17 June 2014, 13:17:48 »
Middle Clicking is one of the signs of the apocalypse.
Offline Coreda
« Reply #19 on: Tue, 17 June 2014, 13:21:22 »
Actually I think it opens a new instance in the apps I've tested it with, but in some apps doing so is a new window. Neat shortcut I also stumbled upon recently since installing W8.
There was a similar thread on another forum recently, where I posted a long-ish list of tips  ^-^ If this were an Opera browser thread though it would be virtually endless  :))
Middle-clicking empty space on my Firefox tab bar re-opens previously closed tabs. I think its Tab Mix Plus enabling that feature.
« Last Edit: Tue, 17 June 2014, 13:23:49 by Coreda »
Offline Pacifist
  • on hiatus
« Reply #20 on: Tue, 17 June 2014, 14:10:37 »
Its so stupid...so many times I've accidentally closed a youtube vid
« Reply #21 on: Tue, 17 June 2014, 14:42:18 »
You need to put more points into your clixkills..
Offline paicrai
  • mindblank
« Reply #22 on: Tue, 17 June 2014, 15:58:08 »
HOW DO ALL Y'ALL SUCKAS NOT KNOW THIS
GET WITH IT
THE FEMINIST ILLUMINATI
Offline FrostyToast
  • Litshoard
« Reply #23 on: Tue, 17 June 2014, 15:59:56 »
Dude, I changed my "sniper" button on my mouse to middle click.
It's just THAT useful.
Quote from: elton5354
Offline esoomenona
  • Gnillort?
« Reply #24 on: Tue, 17 June 2014, 16:04:31 »
I prefer Double Click to Reload (also, ever see this one? https://addons.mozilla.org/en-US/firefox/addon/text-link/h ). That is, until I learned of VimFx, where I can just press r... and x to close, and X to reopen.
But for you out there who don't know:
Ctrl+r - reload
Ctrl+shift+r - reload cache
Ctrl+t - new tab
Ctrl+shift+t - reopen closed tab
Ctrl+w - close tab
Ctrl+l - focus on address bar
Ctrl+k - focus on search bar
Ctrl+tab and Ctrl+shift+tab  - move in between tabs
« Last Edit: Tue, 17 June 2014, 16:07:03 by esoomenona »
Offline esoomenona
  • Gnillort?
« Reply #25 on: Tue, 17 June 2014, 16:08:50 »
I also do this in Firefox: go to about:config, and modify this mousewheel.with_control.action to 1. This allows to hold the Ctrl key while scrolling which allows you to scroll without zooming in or out. Then Ctrl + - and + to scroll in or out.
« Reply #26 on: Tue, 17 June 2014, 17:17:40 »
GET WITH IT
Sorry PaiPai..  we older.. slower.... and generally more lethargic
Offline hcry4
  • HHKB Hoarder
« Reply #27 on: Tue, 17 June 2014, 17:21:16 »
I tend to ctrl-click for opening links in new tabs.
« Reply #28 on: Tue, 17 June 2014, 19:04:35 »
My firefox knows when I'm done fapping, and closes all tabs automatically.
Offline Smasher816
  • HHKB Master
« Reply #29 on: Tue, 17 June 2014, 20:54:29 »
I knew that but I didn't know about closing tabs too.
Yes, yes it is. Highlight some text = copy, middle mouse = click. Nice for some quick edits without grabbing the keyboard.
Offline davkol
  •  Post Editing Timeout
« Reply #30 on: Thu, 19 June 2014, 06:22:51 »
...or just 'x'. Meet VimFX.
Seriously though, how is this news? O.o
