Author Topic: Question on cherry stabilizers  (Read 2434 times)
Offline CrimsonVertigo
« on: Thu, 26 June 2014, 10:49:12 »
Just wondering why manufacturers do not use the same switches for the cherry stabilizers? Instead of always using mx blacks?
Wouldn't this sort of eliminate the mushiness?
Re: Question on cherry stabilizers
« Reply #1 on: Thu, 26 June 2014, 10:50:06 »
what?
« Reply #2 on: Thu, 26 June 2014, 10:53:58 »
The stems of Cherry stabilisers aren't switch stems. Cherry doesn't make different colours of stabilisers. They're all the same.
Also, do the clip mod and lubricate them.. They won't be mushy anymore.
Offline Pacifist
  • on hiatus
« Reply #3 on: Thu, 26 June 2014, 10:58:44 »
maybe stop using rose system boards?
« Reply #4 on: Thu, 26 June 2014, 11:04:07 »
Thanks, sorry for my ignorance of cherry stabilizers, first time using a Ducky 9008 G2 Pro PBT.
Offline Pacifist
  • on hiatus
« Reply #5 on: Thu, 26 June 2014, 11:05:23 »
clip them and be forever graced with best stabs
« Reply #6 on: Thu, 26 June 2014, 12:45:08 »
N0000..... C0star... ftWWWWWWWWW!!!!!!!!!!
Offline C5Allroad
  • Formerly HUNTERANGEL121
« Reply #7 on: Thu, 26 June 2014, 13:11:49 »
Well. He said best cherry stabs. Not better then costar. I do like costar better too lol. But oh well.
« Reply #8 on: Thu, 26 June 2014, 13:17:13 »
it really wouldn't be tooo hard to cut the bottom of the costar inserts, and glue them onto the plate..
then you can use costar stab as long as you have a universal space-bar
Offline C5Allroad
« Reply #9 on: Thu, 26 June 2014, 13:37:11 »
I kinda wanna do that clip mod on K90 to see how it feels lol
Offline Oobly
« Reply #10 on: Thu, 26 June 2014, 14:37:23 »
The clip mod will sort them out. May as well lube them while you're at it. :)
I prefer Cherry to Costar style stabs, for a number of reasons. They're easier to change keycaps on, don't break so easily, don't rattle and feel great.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
