Author Topic: Most Crisp MX Blue Board  (Read 4956 times)
Offline Altis
« on: Fri, 27 June 2014, 18:27:48 »
What I'm trying to find is which boards have the most crisp sounding and feeling MX Cherry Blue switches.
I have an MX Blue board already, the Razer Blackwidow 2012 (I know, I know... it was my first mechanical board), and I love the click, but it's like my keys sound kind of mushy... they also feel a little mushy.
This is the kind of thing I'm looking for:
It's as if the whole thing is tight as a drum. My RBW sounds like mush by comparison. The thing is, I went to the local store and tried the current BW and it sounded quite a bit better. Then they sound completely different when you click the sample keys on the ones that are still in their boxes...  :eek:
What I'd like to know is what keyboards tend to be like that, or what qualities they have to make them sound that way (mounting board, keycaps, etc).
I know I'm starting to sound like a keyboard junkie looking for the next fix...
Thanks for your help!
Re: Most Crisp MX Blue Board
« Reply #1 on: Fri, 27 June 2014, 18:35:43 »
it takes 10,000 key clicks to get the blues into ultra smooth mode...
the reason black widow is mushy is because the keycaps have poor tolerance, and the stems are not smooth..
Check out imsto thick pbt.. those have the smoothest cherry mx cap stems I've tried.
Offline jacobolus
« Reply #2 on: Fri, 27 June 2014, 20:24:22 »
MX blue is just not a very crisp switch, in general. You might want to try a Model F, or if you prefer modular switches, SMK “monterey” blue alps-mount switches, clicky black Hi-Tek “space invaders”, or Alps or Matias clicky switches.
Offline Premonition
  • HHKB Elite
« Reply #3 on: Fri, 27 June 2014, 20:27:24 »
I've tried several MX Blue boards, and found that Ducky boards were a bit squishy. The Quickfire TK I used was really crisp and sharp, though, maybe give that a try.
Offline Defect
« Reply #4 on: Fri, 27 June 2014, 20:31:06 »
This gonna sound like a ****-ish answer but the most crisp MX blue is most things non-MX.
MX is linear by design and they were very clever in using a two part slider to create a click, but Alps, Matias, and Buckling Spring all do clicks better than MX can.
Offline Sniping
« Reply #5 on: Fri, 27 June 2014, 20:31:47 »
My thoughts exactly. I think that Alps is a lot crispier than MX, and not just the rare switches. I also enjoyed using the Model F too.
Offline Lanx
« Reply #6 on: Fri, 27 June 2014, 20:42:53 »
you want the best board? settle for an old school 1970's buckling spring, nothing comes close, but mx the is the easiest to design with in the modern era, so that's where you're stuck.
Offline Premonition
  • HHKB Elite
« Reply #7 on: Fri, 27 June 2014, 20:49:31 »
Is it really this hard to answer some newb's question on this forum without degenerating into elitism? Come now.
Offline ideus
  • Björkö.
« Reply #8 on: Fri, 27 June 2014, 21:45:07 »
It seems very easy for the people to get out of context. In this case MX Blue SW are the context. Why not try to answer the question within context?
Offline jacobolus
« Reply #9 on: Fri, 27 June 2014, 22:23:47 »
Sorry, I’m not trying to be “elitist”, I just don’t think any Cherry MX switches are, objectively, very “crisp”.
It’s not like these other keyboards are so outrageously inaccessible either:
You can often find a good-condition used white Alps board on ebay for $25–35 shipped, or a Model F AT or SMK “monterey” blue board for, I dunno, $60–70? (Or less if you’re lucky/look around for a while.) Space invaders are rare to find, but usually not outrageously expensive.
If you want to stick to new keyboards, the Matias Tactile Pro isn’t really out of line with MX-based boards, price-wise.
If the OP is attached to MX blue switches, that’s totally fine, and I’m sure there are useful suggestions of particular MX cases and keycaps that will accentuate the sound. But if he’s really just looking for something “crisp”, then I think advice to explore other switches is entirely reasonable.
Offline dante
« Reply #10 on: Fri, 27 June 2014, 22:27:10 »
During last holiday season I stopped into my local Fry's and test drove a CM Storm QFR and XT both with MX Blues ... both brand new (I took them out of the box) the XT felt much more crisp and satisfying to type on.  Probably the best MX Blue board I've ever tried.  Something was just off about the QFR ...
Offline Beca
  • what am i doing with my life
« Reply #11 on: Fri, 27 June 2014, 22:30:00 »
I feel like there are some variations with mx blue batches, even with the same keyboards. I remember reading a post complaining about mushy blues on their blackwidow, while their brother's blackwidow was much more crisper. I think that over time, the blue switches start to get a bit more quieter.
I have owned two mx blue keyboards, a Poker 2 and a Noppoo Choc Mini. I loved how crisp the Poker 2 sounded while my Noppoo just sounded all old and worn out. The Poker 2 is much higher quality imo, it has very solid construction and lacks the wobbliness/creakiness of the Noppoo case. My friend's QFR with blues sounds and feels extremely crisp.
I think what happens though, is that keyboards with thinner, abs keycaps tend to have a clickier, high pitched sound. Thick PBT or POM can make the same click sounds, but they have a nicer, deeper thock when the keycap bottoms out.
If you put a mat underneath your keyboard, it is most likely going to sound more muted as well. The bottom out sound will be softer so the clicks may sound louder in comparison.
One more thing to my rambling comment: videos are probably not ideal when comparing keyboard sounds. Microphones may capture only the higher pitched sounds and that's what makes it sound "crisper" in the video while in reality, it may not sound like that at all.
« Reply #12 on: Fri, 27 June 2014, 22:31:14 »
I would say: buy a buckling spring board
If you really want blues, putting the board in a metal case adds some auditory enhancements.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #13 on: Fri, 27 June 2014, 22:56:27 »
out of the 2 mx blues boards i own-- i would say both are somewhat mushy; 1 has costar, 1 has cherry stabs
mx greens (mine has costar stabs) if you are sticking to mx feel crisper to me
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline lightsout714
« Reply #14 on: Sat, 28 June 2014, 02:15:52 »
The blues on my quickfire feel nice and crisp. Funny thing is I prefer them with the stock abs caps. I have put thick pbt caps on two different boards with blues and didn't like the feel at all. Put  the "junk" caps back on and it feels great.
Offline remdell
« Reply #15 on: Sat, 28 June 2014, 04:09:47 »
I've tried complicated white Alps, complicated blue Alps, space invaders, MX blues, MX greens, and several kinds of simplified white Alps.  MX greens, buckling springs, and clicky Alps seem to be quite up there in terms of crispiness.  Yet, for some reason, I find the simplified Alps switches (Alps.tw Type OA2) on my Macally MK96 to be the crispiest and crunchiest of the bunch.  I must be crazy.
« Last Edit: Sat, 28 June 2014, 04:11:47 by remdell »
Rukia PC | RF87U Digilog | Norbaforce MKII Palm Desert | Zenith ZKB-2R | Datadesk MAC-101
Offline jacobolus
« Reply #16 on: Sat, 28 June 2014, 04:53:07 »
That’s possible. If you want really snappy, go for amber omrons.  They’re a bit stiffer than my preference, but they are very very clicky.
Offline Defect
« Reply #17 on: Sat, 28 June 2014, 05:50:37 »
Thin ABS and thin PBT are my favorite for MX Blues.  Only time i like ABS haha
Offline Kayla
  • :3
« Reply #18 on: Sat, 28 June 2014, 05:52:51 »
This thread is painful to read.
If you want stiff blues get greens.
If you want a stiff keyboard key something sturdy and built with quality like a ducky or a poker; if you need more sturdiness splurge for aluminum.
If you want CRISP then the key material is a problem; if youre using ABS, PBT is much more of a solid experience. Although for some games I prefer the thin light ABS caps (like for osu!), for typing and most casual faming I prefer PBT and POM.
If you want to go thr extremeist route, then you can get an ALPS/BS/Whatever else was suggested in this thread route. MX Blue's tactility is better experienced on other things because it is but an emulation.
Offline Altis
« Reply #19 on: Sat, 28 June 2014, 07:47:45 »
Thanks for the replies everyone. I should have been more specific about me. Not quite a noob as I'm now searching for my 9th keyboard ;)
My KPT102 has KPT blue (similar to blue alps)... They are very tactile, to the point of being pretty heavy. The hollow plastic case makes it feel a little worse, which I hope to fix with a custom case.
It seems I'm not the only one to notice that MX blues seem to vary quite a bit between boards. It's just really difficult to find out that sounds and feels just right without first trying it. I'm hoping there are a few boards that are normally that way.
Might have to try the QFR as they don't stick Filco around here, and the price is quite good. It's a shame the Rapid is being phased out in favor of the Rapid-i, at a hefty premium.
« Reply #20 on: Sat, 28 June 2014, 08:04:41 »
I love these replies that start with "I don't want to sound like a **** or elitist." That's exactly how you sound if you preface your statement with that. If you want to give your opinion without sounding like that, maybe you should learn to phrase your replies in the manner that reflects the attitude you want to show.
Anyways, I compare all mx blues to the ones in my Filco. To me, those are what mx blues should feel like. They're crisp and clicky for blues, even two years of daily typing my board.
Offline Mooby
  • Funployee
« Reply #21 on: Sat, 28 June 2014, 08:22:36 »
I have tested blues on Filco MJ1 fullsize, MJ2 TKL and QF XT so far and can say I liked the feeling of the MJ2 best.
Maybe it's an option for you to put something under your keyboard for a little dampening effect. After I bought a leather base for my desk it changed how the switches feel (also blues) to the positive. This had way more effect  on the feel than the difference between different keyboards.
Offline Altis
« Reply #22 on: Sat, 28 June 2014, 09:01:46 »
Yeah the mat underneath certainly helps with overall noise (mostly the deeper sound that resonates the desk top), but it doesn't help with the crunchy/mushy feeling of these keys.
Without being able to try a specific Filco, it'd be a little risky putting all that money at something that might be the same or only slightly better than what I have already. I would just want to be fairly certain that it will be crisp and tight.
Offline Mooby
  • Funployee
« Reply #23 on: Sat, 28 June 2014, 09:10:14 »
Get a used one. If you don't like it sell it.
Offline Lain1911
  • God of the Wired
« Reply #24 on: Sat, 28 June 2014, 10:16:27 »
The poker II gives me the enjoy my feels satisfying click with blues. Maybe it's a pbt thing?
Offline shantanujoshi
« Reply #25 on: Sat, 28 June 2014, 10:22:01 »
Love when people try to give you unwanted random advice when all you asked was about crispy blues lolllls
Anyway just to throw in my input on your question. I've been swapping blues for a long time and actually posted on an issue very similar to yours recently - that crispy click I think comes from a combination of blue switches - thinner caps - and a hard base. My das ultimate is probably the 'crispiest' keyboard I've used. I tried to get thinner abs and pbt keycaps on a poker 2 and that really got me close to the das. The CMS quickfire rapid was somewhere inbetween the das and the poker 2 as far as crispiness. The Das 4 isn't as crisp imho to the old das.
TL;DR For me in order of crispiest blues I've used: DAS (3?) - DAS 4 - CMS Quickfire Rapid - Poker 2's with thin ass keycaps
Hope this helps!  ;D
Never judge a man by his post count
[Hasu 55g HHKB PINK RFs] [GON HHKB Zeals] [GON TKL w/ Erg Clears] [IBM SSK] [VE.A Zeliostotles] [Ergodox Gatistotles]
Offline calavera
« Reply #26 on: Sat, 28 June 2014, 10:24:43 »
The presence of plate will affect the overall feel as well. Example: filco with plate vs. 1800 cherry without plate. Can't say which I like more as I've grown out of blues all together.
I'm having trouble understanding what the "crispiness" is refering to. The sound?
« Reply #27 on: Sat, 28 June 2014, 12:23:04 »
I don't think it can be a fair test comparing boards unless they have the same keycaps on. With blues more than any other switch (IMO) the caps seem to play a very large part in feel.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #28 on: Sat, 28 June 2014, 12:50:51 »
right, i would say on my end not as crisp without a plate....
i was trying to stay on topic-- "mx" and then blues and not wander to other switches
i gotta get a filco :cool:
Offline Lammie
« Reply #29 on: Sat, 28 June 2014, 12:52:20 »
Matias CLICKY switches! In between mx blue and mx green..Meaning, not too light, not too heavy/stiff. Just middle path. This is how the mx blue should have been... Or ghetto greens if you wanna stick with mx switches
Topre Realforce 55g
Topre Leopold FC660C 45g
Matias Quiet Pro Mini
Cherry ML G84-4100LPAUS
Cherry MX Green QFTK
Model M Unicomp 103
Offline Pacifist
  • on hiatus
« Reply #30 on: Sat, 28 June 2014, 12:54:37 »
model f is very crisp, you should try it and see if you like it
Offline Altis
« Reply #31 on: Sat, 28 June 2014, 13:11:49 »
I think you're right. That's part of what I'm trying to figure out... Which factors make for the cleanest MX blue sound.
The link in my OP seems to be among the most clean/crisp/tight sounding MX Blue keyboard. I know recording devices and methods will affect it, but even in the store I've experienced so much variation.
As for the DAS, I have an MX Brown version of it. It might vary as well but it seems more rattly than my QFR (which has reds, though). The keycaps and plate/casing on my QFR seems the most solid (of my MX boards).
I'm thinking the Filco and CM boards might be the best bets for the most solid/crisp/tight sounding and feeling MX blue keyboards.
I appreciate all of your inputs!
