Author Topic: Hello and Quick Question!  (Read 1588 times)
Offline ecamarata
« on: Tue, 08 July 2014, 21:01:54 »
Hello I'm new to Geekhack, I've have been using mechanical keyboards for about 6 months now and I love it. I code and Game a little, I currently use a Das Professional with MX browns as my main keyboard and I just recently switched from a CM Quickfire TKL backlit with MX reds. I also use a CM  quickfire Rapid TKL with MX browns at work and I absolutely love that keyboard! So that's me right now; I am looking into getting a different keyboard and selling my Das because I like the TKL style better. I also think I want to get something backlit, so I was thinking either the CM quickfire TKL rapid-i with MX browns or the keycool 84 or 87 with MX browns. I know the keycool 84 is a smaller form factor (70% instead of 80% or whichever the percent is) My question is this I really like that the function keys on the keycool 84 are inline with the number row, do they make a mechanical keyboard that has the same style as the keycool 87 or quickfire rapid TKL that has inline function keys? All comments and keyboard suggestions are greatly appreciated thanks!
Re: Hello and Quick Question!
« Reply #1 on: Fri, 11 July 2014, 08:11:24 »
Have you seen this?
You can make any key do whatever you want..
