Author Topic: Monitor Repair  (Read 3888 times)
Offline berserkfan
Monitor Repair
« on: Fri, 18 July 2014, 10:10:32 »
Hello
This is akin to a necrobump, but I actually can't find the thread I wrote a long time ago.
I have an LG 2241T LCD monitor. It works fine for the first half hour or so. Then it starts flashing and I have to turn it off.
In the past I was advised to try checking for blown capacitors. That's the most common issue. Now I have opened the monitor, and to my utter horror, all capacitors are ok. The easy solution is not the correct one! I ran my finger over all of them to make sure they were flat on top.
What else can I do to resolve the issue?
Re: Monitor Repair
« Reply #1 on: Fri, 18 July 2014, 10:16:26 »
Hello
did you check the bottoms?
Is the below board the one you checked?
Offline berserkfan
Re: Monitor Repair
« Reply #2 on: Fri, 18 July 2014, 11:21:54 »
Hello
Thanks TP4, yes I checked below and there was a board that looked the same (except mine had 9 capacitators instead of the 8 in the photo). All tops flat and shiny.
Considering how much effort I had to go to in order to remove the monitor backing, I'm really disappointed. Nothing on my board looked out of place (no rust, stains, anything obviously bad.)
Re: Monitor Repair
« Reply #3 on: Fri, 18 July 2014, 11:34:21 »
Hello
the only other thing is try buying a replacement power board..
but, obviously you might as well just buy a new monitor.. haha..
Offline Xenderwind
Re: Monitor Repair
« Reply #4 on: Fri, 18 July 2014, 11:42:22 »
If you cant figure out the problem you can try work arounds.  Maybe try lowering brightness or using a different output instead.  I had a monitor that on hdmi would go black fairly often and come back after a couple seconds but worked completely fine on vga.
GON NS 87 62g clears, QFR 62g clears, Pure 65g blues, HHKB Pro II
Re: Monitor Repair
« Reply #5 on: Fri, 18 July 2014, 12:31:27 »
i would've just tossed the monitor.. hahaha.. this is smarter..
Offline berserkfan
Re: Monitor Repair
« Reply #6 on: Fri, 18 July 2014, 12:33:40 »
awesome idea; thanks! I haven't tried this before!
Re: Monitor Repair
« Reply #7 on: Fri, 18 July 2014, 12:39:03 »
i don't think it's the brightness though, this is an led backlit.. barely uses any power
input is possible
Re: Monitor Repair
« Reply #8 on: Sat, 19 July 2014, 06:12:51 »
What about a monitor on DVI that powers on, then displays the "no signal" message and turns itself off, even though the computer is clearly on?
I checked both ends of the DVI cable - no broken or missing pins, and both ends are correctly plugged in.
Re: Monitor Repair
« Reply #9 on: Sat, 19 July 2014, 11:11:55 »
did you check if it's the computer?
next time this happens, just hit restart on the pc see if it comes back..
Re: Monitor Repair
« Reply #10 on: Sat, 19 July 2014, 21:00:37 »
I have no reason to suspect either.  I powered off the PC, the powered it on again - the monitor did not detect any signal at any time during that process.
