Author Topic: Video Camera  (Read 2319 times)
Offline yester64
Video Camera
« on: Tue, 29 July 2014, 20:22:03 »
Hello, i am on a hunt for a video camera. Yeah, you can record with your phone but space is limited and quality is soso.
So i am looking for a good and not to pricey camera that can be charged while using and give good quality videos. What i am a little concerned is what video format the video is recorded and id editing is easy or not so easy.
I have to admit that i have no plan about these kind of cameras. So if someone can point me to a good camera that does not cost a fortune but gives me that what i am looking for that would be great.
My main use will be recording of outdoors/indoors which is kind of generic anyway. Oh yes, and since most cameras are using memory is there anything you have to consider? Like what memory is better and so on.
Thank You
Rosewill RK-9000BR (trashed)
WASD V1 Keyboard Cherry Blue w/40A Hardness O-Rings
Steelseries 6GV2 Red Cherry Switches
Online tp4tissue
Re: Video Camera
« Reply #1 on: Tue, 29 July 2014, 20:49:10 »
hrmm...  I r also in market for dash cams
if ne one's got experience with good dash cams, chime in plz.. thxxx.
Re: Video Camera
« Reply #2 on: Tue, 29 July 2014, 21:20:45 »
This guy reviews dash cams (and action cams and a few other things).  Mostly bottom of the range, but he knows what he is talking about and has found a few real gems:
http://www.techmoan.com/
Offline jameslr
Re: Video Camera
« Reply #3 on: Tue, 29 July 2014, 22:26:17 »
Get a micro 4/3 camera that does 1080p video (most of them nowdays). Sony Alpha Nex-3/5/6/7 (depends on your budget) comes to mind. Not only do you get a camera that takes great video, you get one that takes amazing stills. Plus it's not huge to lug around like a traditional dSLR. There are several other 4/3 mirrorless cameras out there, so just get whatever suits your fancy. That's what I would do anyway. I own a Sony Nex-5N and it's an amazing camera. I'll never go back to point and shoot cameras / compact cheapo cameras.
CM Novatouch | Filco MJ2 TKL w/ HID Lib | REΛLFORCE 87U 55g | CM QFR
Offline paicrai
  • mindblank
Re: Video Camera
« Reply #4 on: Wed, 30 July 2014, 03:30:46 »
get a 1973 vhs camera
THE FEMINIST ILLUMINATI
Offline Oobly
Re: Video Camera
« Reply #5 on: Wed, 30 July 2014, 09:18:00 »
My brother has a really nice Sony which uses a hard drive, but the video format is a bit of a bugger to work with for editing, etc.
I'd recommend getting the best Canon camcorder you can afford. Most of them record to SD and have internal storage, too. SD has become the standard, so it's best to stick to that.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline Malphas
Re: Video Camera
« Reply #6 on: Wed, 30 July 2014, 16:57:32 »
Exactly what I was going to suggest.
That's not actually micro 4/3, but yeah it's a MILC. so same idea. I would still go with micro 4/3 (i.e. Panasonic basically) over other MILC setups though personally.
http://en.wikipedia.org/wiki/Mirrorless_interchangeable-lens_camera#Systems_comparison
More people should be buying MILC cameras. Probably half the people that still buy point and shoots or camcorders would be better served with one, and probably 90%+ of people buying DSLRs would get a better camera for their money with a mid/high-end MILC rather than a bottom of the barrel DSLR.
« Last Edit: Wed, 30 July 2014, 17:00:03 by Malphas »
Offline yester64
Re: Video Camera
« Reply #7 on: Thu, 31 July 2014, 20:10:37 »
So, i guess i should buy a camera instead of a video camera. Looks nice the sony one. It may fit the bill since i am not a heavy recorder but like good quality.
Offline paicrai
  • mindblank
Re: Video Camera
« Reply #8 on: Fri, 01 August 2014, 03:48:28 »
i said vhs darndit
Offline Malphas
Re: Video Camera
« Reply #9 on: Sat, 02 August 2014, 05:51:50 »
Offline yester64
Re: Video Camera
« Reply #10 on: Sat, 02 August 2014, 16:10:51 »
wow. thats quality. Sadly, that camera is out of my league. But still, pretty.
I still have it in my head, kind of burned in, that you need a video camera. So i am guessing that the purpose is grey now. Either is ok it seems.
Thanks for sharing that video. :)
Offline Malphas
Re: Video Camera
« Reply #11 on: Sun, 10 August 2014, 17:12:27 »
Check the GF6 then for a cheaper alternative.
Re: Video Camera
« Reply #12 on: Sun, 10 August 2014, 23:17:07 »
In 1973, VHS existed only as prototypes at JVC. The first consumer camcorders appeared ten years later.
Before camcorders, cameras had to be hooked up to a VCR to record. I think I may still have an old black and white camera somewhere ...
