Author Topic: Iron man keycap from Keypop brightness issue  (Read 1980 times)
Offline Aidenknives
« on: Wed, 06 August 2014, 13:56:46 »
So this Iron Man keycap I purchased from Keypop isn't lighting up as much as I hoped. :( (Poker II on max brightness) I figure it is because the LED is behind the switch... Is there anything I can do to make the eyes of the keycap glow brighter??? Thanks!
Offline paicrai
  • mindblank
« Reply #1 on: Wed, 06 August 2014, 14:39:50 »
reflective coatings inside, replacing the led? a tiny mirror inside to focus more light on the eyes?
THE FEMINIST ILLUMINATI
Offline Aidenknives
Re: Iron man keycap from Keypop brightness issue
« Reply #2 on: Wed, 06 August 2014, 14:46:52 »
I was considering the mirror but idk where I would get a mirror that small...
« Reply #3 on: Wed, 06 August 2014, 15:37:07 »
use the shiny side of aluminum foil glue-sticked to slivers of cardboard..
Offline Oobly
« Reply #4 on: Wed, 06 August 2014, 15:42:44 »
I put thin paper in the eyes of my Cinnn Iron Man so it looks more like the real thing and doesn't need the LED to be so bright to make the eyes shine.
Maybe it would work with your Iron Man, too?
Buying more keycaps,
it really hacks my wallet,
but I must have them.
