Author Topic: FC660M vs FC750R?  (Read 3465 times)
Offline yuukou
FC660M vs FC750R?
« on: Sat, 23 August 2014, 01:46:44 »
Besides size, and side printed keycaps on the 750R, does anyone know any reason to get one over the other?  I am currently looking at both right now. I am also open to suggestions of someone thinks I can get a better keyboard around the 130-180 range.
Offline FrostyToast
  • Litshoard
Re: FC660M vs FC750R?
« Reply #1 on: Sat, 23 August 2014, 01:50:40 »
660c! Join the dark side!  ;D
Quote from: elton5354
Offline yuukou
« Reply #2 on: Sat, 23 August 2014, 01:58:25 »
Honestly if I had the money I would just get a 660c or a HHKB but for now I just need a replacement for my 3 year old noppoo, I would use my filco but while I am at home the blue switches wake up people at night, so I can't use it. orz
Offline yuukou
« Reply #4 on: Sat, 23 August 2014, 03:59:18 »
If I wanted tablet input I have a $500 Intuos for that ^-^
« Reply #5 on: Sat, 23 August 2014, 06:33:24 »
Either should be fine.
You might have a problem finding replacement keycaps for the FC660M, not sure about the FC750R (do they still have non-standard space bars?).
Offline _PixelNinja
  • C=Q/V=ε(A/t)
« Reply #6 on: Sat, 23 August 2014, 10:20:45 »
The stabilizers have a non-standard spacing on the FC750R; you won't be able to change the space bar without modding the stems.
Offline yuukou
« Reply #7 on: Sat, 23 August 2014, 14:57:33 »
I won't be changing much, the keycaps on the fc750r look really good, at most I might swap it out for a Leopold PBT black set, so I have black keys with a white case.
Offline jameslr
« Reply #8 on: Sat, 23 August 2014, 19:14:10 »
I think you can get the board (750R) with black keycaps already on it can't you? Or are the options only white and navy? I wouldn't get the 750R due to non-standard stem spacing on the spacebar. You would have to stick with the Leopold spacebar no matter which cap set you wanted to use on it. Granted the Leo caps are pretty nice so I don't see anyone wanting to change them, but it limits your options. If you want a TKL then get a KUL ES-87 or another Filco.
CM Novatouch | Filco MJ2 TKL w/ HID Lib | REΛLFORCE 87U 55g | CM QFR
Offline yuukou
« Reply #9 on: Sat, 23 August 2014, 22:16:03 »
Oh I wanted the white board, but with black keycaps, I found a PBT black sideprinted set made by Leopold also, so I might pick that up.
