Author Topic: I need help...  (Read 2179 times)
Offline barkinos98
  • Illinois
I need help...
« on: Fri, 05 September 2014, 14:31:16 »
Guys, i bought a QFR recently and i love the blues, coming from browns i can feel these are a bit better when talking feedback.
But unfortunately the noise is annoying me, i know how to solder and have some extra time, so i need new switches.
After seeing there are many switch types out there, idk what to get but from what i figured i'd love heavier clears with springs or the greys but both of them seem very very hard to acquire. Can anyone guide me to find switches/springs?
Thanks so much already! :)
Happy Hacking Professional 2  | Logitech G710+ | Quickfire Rapid MX Clears
Offline cphead
Re: I need help...
« Reply #1 on: Fri, 05 September 2014, 14:32:18 »
switches available at mechanicalkeyboards.com
Offline esoomenona
  • Gnillort?
Re: I need help...
« Reply #2 on: Fri, 05 September 2014, 14:35:34 »
In particular, http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=597
More than enough for your desire.
Re: I need help...
« Reply #3 on: Fri, 05 September 2014, 14:37:04 »
For the QFR might want to get plate mount instead http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=853
Offline esoomenona
  • Gnillort?
Re: I need help...
« Reply #4 on: Fri, 05 September 2014, 14:41:38 »
Indeed. I didn't know they offered both. Very nice.
Offline barkinos98
  • Illinois
Re: I need help...
« Reply #5 on: Sat, 06 September 2014, 09:16:59 »
Just out of interest, what exactly is the difference between plate/pcb mount switches?
As it appears i'm goign to have to de-solder the switches any way so after de soldering 87 so i'd prefer the one thats easier to do :P
Offline jorgenslee
Re: I need help...
« Reply #6 on: Sat, 06 September 2014, 09:25:44 »
There are no noticeable differences of plate/pcb mount switches aside from the two additional feet in pcb mount switches to add additional stability. Aside from that, they function the same. You have to make sure though if the pcb supports pcb mount switches.
Offline user 18
Re: I need help...
« Reply #7 on: Sat, 06 September 2014, 09:34:27 »
QFR PCB does not support PCB mount switches. If you do order PCB mount, it is possible to convert them by snipping the extra feet off of the bottom of the switch housing -- I use a small pair of wire cutters to do this.
Avatar by ashdenej
Offline barkinos98
  • Illinois
Re: I need help...
« Reply #8 on: Sat, 06 September 2014, 12:49:56 »
Oh...
So pretty much going with plate mount ones it'll be easier and a somewhat more solid/reinforced way (no voiding warranties on switches at least), not to mention it'll fit lol.
One last thing though, how sensible is it to change the plate? I mean, in the first place what does it do other than providing a backdrop sorta purpose as well as making the keyboard more solid.
I'm going to order a bag of MX Grays because they seem the best of what i want, no click, tactile and heavy (blues and browns feel too light). Can anyone comment on the tactility between greys and clears? I know clears are more tactile browns and wonder if the greys are perfect for me or like browns but heavier.
Re: I need help...
« Reply #9 on: Sat, 06 September 2014, 13:45:11 »
Grays being heavier are less tactile than clears.
Re: I need help...
« Reply #10 on: Sat, 06 September 2014, 15:23:47 »
are you insane..   with the amount of work involved.. you might as well just buy another QFR with brown..
Offline Oobly
Re: I need help...
« Reply #11 on: Sun, 07 September 2014, 02:18:11 »
If you're changing all the switches, then changing the plate is a valid option, especially if you get a plate that allows you to open the switches. I would also not recommend getting gray switches unless you have massively strong fingers. I think Clears would suit you best, they're stiffer than browns with more tactility. Grays are much stiffer than browns and not quite as tactile as Clears.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Re: I need help...
« Reply #12 on: Sun, 07 September 2014, 02:26:05 »
While youre at it, you can Krytox lube your switches to make them quieter. Then after you can add Orings to your keycap sets as well.  I get my Orings on ebay. 10x as many for the same price. Can put them in all of my keysets. Clears are my favorite but Reds, Blacks, or Browns would be quiet too.
Offline barkinos98
  • Illinois
Re: I need help...
« Reply #13 on: Sun, 07 September 2014, 14:32:04 »
Hm...
So my best bet would for a quiet but tactile switch would be clears, right?
Might just buy a tester for now and try it out... lol
Offline Oobly
Re: I need help...
« Reply #14 on: Mon, 08 September 2014, 08:55:23 »
Hm...
Yup.
And if you're going to open the switches to lube them, you may as well trampoline mod them instead of buying orings. Then you don't have to worry about different keycap profiles, oring sizes and keycap crossbar heights changing the feel of the switches.
