Author Topic: Which CM Storm keyboards have a standard front row?  (Read 2494 times)
Offline Barracuda
« on: Sat, 06 September 2014, 05:59:44 »
See subject. My brother wants to buy a CM Storm mech, but is there one with a standard layout (other than the novatouch)?
Looking for a matte Blackout V2!
Offline Roibhilin
  • Saver of Humens
Re: Which CM Storm keyboards have a standard front row?
« Reply #1 on: Sat, 06 September 2014, 08:55:26 »
QFR, i've read that it's discontinued though
QFR | Poker II | Quickfire TK
Offline phoenix1234
« Reply #2 on: Sat, 06 September 2014, 08:58:05 »
CM Quick Fire Rapid
CM Quick Fire Stealth
CM Quick Fire XT
CM Quick Fire Trigger
I like linear switches
Offline Barracuda
« Reply #3 on: Sat, 06 September 2014, 09:48:05 »
So the ones with a non standard layout are the Quickfire TKs?
Offline phoenix1234
« Reply #4 on: Sat, 06 September 2014, 10:39:57 »
sure thing, CM may have more like CM MECH, CM Ultimate... If you want something standard, something that you can buy keycap easily on GH, you should get either CM Quick Fire Rapid, CM Quick Fire Stealth, CM Quick Fire XT, CM Quick Fire Trigger, Filco MJ2, Ducky Shine 3 or something similar.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #5 on: Sat, 06 September 2014, 20:48:27 »
The most recent Rapid-i backlit model is also using standard 1.25 modifiers and 6.25 spacebar. They seem to be priced about the same as the older non backlight Rapid.
Offline Barnesdrb
« Reply #6 on: Sat, 06 September 2014, 20:50:43 »
Their space bars is what threw me off on the Quickfire Pro TK with Red Switches.. I really wanted to customize the keycaps on it when I had it. Though the space bar is definitely a bit longer.
"Some men have fast cars, smokin' hot women, or a plethora of guitars.. I have my keyboards."
« Reply #7 on: Sat, 06 September 2014, 22:10:10 »
i recommend just getting the rapid.. it's got all the essentials, NO FLUFF... Just works...
