Author Topic: Ducky Mini spacebar feels stuck/sticky  (Read 17307 times)
Offline orangeju1ce
« on: Sat, 06 September 2014, 18:02:21 »
Hello!
I recently got a ducky mini keyboard and it's great except the spacebar feels like it's sticky/stuck half the time.
i pulled the spacebar out and it seems that there's a sticky substance on where the cherry stabilizers are can this be due to overlubing? how can i fix this? i want to type on this keyboard so badly, but the spacebar feels stuck/sticky..i guess what i want to  know is how do i go about decreasing the abount of grease in the stabilizers? would i have to do some desoldering?
« Last Edit: Sat, 06 September 2014, 18:38:14 by orangeju1ce »
Offline cphead
Re: Ducky Mini spacebar feels stuck/sticky
« Reply #1 on: Sat, 06 September 2014, 18:30:26 »
The lube shouldn't make it sticky. It's most likely just the cherry stabilizers being cherry stabilizers. Also check that the spacebar cap is on all the way (all 3 inserts are in correctly).
Offline orangeju1ce
« Reply #2 on: Sat, 06 September 2014, 18:47:20 »
I have uploaded a video describing the problem i have..
Would it be easier to just send this keyboard back... or is this an easy to fix issue
« Last Edit: Sat, 06 September 2014, 18:51:53 by orangeju1ce »
Offline cphead
« Reply #3 on: Sat, 06 September 2014, 18:50:24 »
Looks to me like the right side is lower than the left, so maybe the left insert isn't in all the way? This happens with cherry stabs if the inserts and keycap don't align well.
Offline orangeju1ce
« Reply #4 on: Sat, 06 September 2014, 18:52:53 »
I see. so do i just push down on the left side more or something?
Offline cphead
« Reply #5 on: Sat, 06 September 2014, 18:56:24 »
I don't know for sure if that is the issue you're having, but I would make sure the keycap is as far down as it goes on both sides.
Offline orangeju1ce
« Reply #6 on: Sat, 06 September 2014, 19:03:16 »
Here is another video:
I think it may be something else? I'm not sure..
Offline orangeju1ce
« Reply #7 on: Sat, 06 September 2014, 19:30:27 »
Thanks for trying to help, I really appreciate it.
Offline ryhanson
« Reply #8 on: Sat, 06 September 2014, 19:36:50 »
Have you tried the tape trick? I was having the same issue with my WASD v2 board and my Ducky PBTs. I put a little piece of tape on the outside stabilizer prongs and it worked like a charm. I wish my WASD board was like my Poker II where I didn't have to worry about that dumb stabilizer bar.
« Reply #9 on: Sat, 06 September 2014, 22:10:54 »
it's MOST likely due to slightly warped space bar..
hit up ebay for an aluminum space bar.. they're cnc-ed and most likely super straight.. and they look super c00l
Offline orangeju1ce
« Reply #10 on: Sat, 06 September 2014, 23:35:26 »
Dang.. Well I guess there's no way of fixing this without buying new parts
« Reply #11 on: Sun, 07 September 2014, 04:58:38 »
Aluminium space bar - Tp4 - really!
Try removing the space bar and placing it on a completely flat surface.
See if it sits flat or whether one end is higher.
This is a common problem with space bars, especially PBT space bars.  Although I believe this one is ABS, however it is still a possibility.
Post a pic if you can :)
Offline orangeju1ce
« Reply #12 on: Sun, 07 September 2014, 14:12:30 »
http://i.imgur.com/YvTG4S8.jpg
http://i.imgur.com/fYtvqv0.jpg
http://i.imgur.com/X5g7i7W.jpg
It does seem a bit warped..
I have a spacebar from my cm quickfire keyboard that i used to test if it was a spacebar problem. it still feels a little bit sluggish. i'll post a video of it later..
would it be that the cherry stabilizers are less tolerant to space bar deformities?
Offline orangeju1ce
« Reply #13 on: Sun, 07 September 2014, 14:12:53 »
Also, I dont know if i would want to get an aluminum spacebar.. aren't they a bit expensive? does it feel significantly better than a plastic one?
Offline orangeju1ce
« Reply #14 on: Sun, 07 September 2014, 16:20:54 »
I'm afraid that I don't know what the tape trick is. I googled it and I couldn't find any details  about it.
Could you maybe post a link or go further into what you are describing?
Offline ynrozturk
« Reply #15 on: Sun, 07 September 2014, 17:42:43 »
Just throw on another space bar and see if it sticks.
IBM Model F | IMB Model M | Poker II MX Brown | Poker II MX Clear | Filco TKL MX Brown | Bastardized Razer Blackwidow TE MX Blue | Logitech G602 |  Cyborg R.A.T. 7 | | Logitech MX518 | Icemat  | Artisan Hien
« Reply #16 on: Sun, 07 September 2014, 20:50:52 »
That is warped, although I have seen worse.  Cherry stabilisers are sensitive to keycap shape, and especially for the longer keycaps such warping can cause the issues you are experiencing.
As ynrozturk suggested - can you try a different (non-warped) space bar?
If a different straight space bar works, you could try contacting the vendor to see if they can provide you with a non-warped space bar, especially if the keyboard is still under warranty, which I'm guessing it would be.
Or you can try heating the space bar with a hair dryer, or in very hot water, placing it on a very flat surface, and weighing it down with a book or so to keep it flat.  However if something goes wrong with this process the vendor might not accept the keyboard back as a return.
Offline orangeju1ce
« Reply #17 on: Sun, 07 September 2014, 21:07:10 »
I'll post a video tomorrow or Tuesday. Got a midterm to study for.
Contacting the vendor would be where I bought the keyboard from right?
Thanks for the help.!
Also why do people use cherry stabs if the costar stabs are more forgiving?
Offline Flyersfan1
  • Hi!
« Reply #18 on: Sun, 07 September 2014, 21:14:04 »
A matter of preference really, cherry stabilizers are pretty much perfect when they're clipped and have some lube applied.  Cherry stabilizers are also much easier to swap keycaps with.  While costar stabilizers do provide a crisp key depression on larger keys, the rattle they sometimes gave off always annoyed me a bit, although it can be eliminated pretty easily with some grease.  Sorry to hear about your spacebar, I hope you can either level it off or get a replacement one.
Quote from: Photekq
Offline orangeju1ce
« Reply #19 on: Mon, 08 September 2014, 23:24:02 »
hooray,
i contacted the vendor and he said he'd be able to ship a spare spacebar, however, it would be a ducky shine 2 spacebar instead of a ducky mini one..
which i dont really mind.. much..
but i'll post a video later with a straighter spacebar when i get more time. ><
« Reply #20 on: Mon, 08 September 2014, 23:31:08 »
hooray,
That's excellent!
Hopefully the replacement will be straight.
Please do let us know what happens.
Offline orangeju1ce
« Reply #21 on: Sun, 14 September 2014, 20:00:18 »
Yay.
So I got the Ducky Shine 2 space bar in the mail. The vendor actually sent me TWO!! :D So I got two free spacebars~.
Anyways, the spacebar is better now, it is less sticky but it still kind of feels weird..  I can't put my finger on it. Maybe I'm just not used to cherry stabs? :{
The space bar is great! I mean, it has this spartan looking duck on it instead of the duck chick, but at least it isn't sticky~
Offline Flyersfan1
  • Hi!
« Reply #22 on: Sun, 14 September 2014, 20:05:44 »
Yay.
The folks over @ Mechanicalkeyboards.com are good people, I'm glad they made this right for you.  Enjoy the Ducky Mini!
Quote from: Photekq
« Reply #23 on: Mon, 15 September 2014, 00:41:59 »
Yay.
Cherry stabilisers can feel mushy if you are not used to them.
Offline Oobly
« Reply #24 on: Mon, 15 September 2014, 01:22:19 »
If you don't like how the stabilisers feel on bottom out (what some describe as a "mushy" feel), you can always clip the little bendy tabs (clip mod).
I prefer Cherry stabs over Costar for a number of reasons:
1. Easier to swap caps and less fiddly in general.
2. Less rattly.
3. More forgiving of keycap thickness / internal shape.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
