Author Topic: Soft Landing pads from Elitekeyboard question...  (Read 1484 times)
Offline Aidenknives
« on: Tue, 09 September 2014, 21:59:34 »
Do you put the pads on the two stabilizers? Would that work/make my spacebar/shift/backspace etc, quieter?
Re: Soft Landing pads from Elitekeyboard question...
« Reply #1 on: Wed, 10 September 2014, 05:33:01 »
LOLOL.. no.. just the switch...
Offline irecresum
« Reply #2 on: Wed, 10 September 2014, 06:31:37 »
can you explain why?
I put o-rings and soft landing pads on all the stabilizer inserts not just the switch as I just figured that would balance out the spacebar height wise.
esoomenona: "****, son. Don't you see my ****ing post count? I matter in this *****"
Offline Aidenknives
« Reply #3 on: Wed, 10 September 2014, 11:47:17 »
Honestly made my shift/enter keys louder...
