Author Topic: Cherry MX Keycap Stabilizer Inserts  (Read 8605 times)
Offline crimsonTofu
« on: Wed, 10 September 2014, 22:05:23 »
Does anyone know where I can get my hands on some keycap stabilizers in Canada? I know I could order them off wasdkeyboards but shipping two little inserts to Canada will cost me ~22...
LOOK AT THE TERROR I AM DEALING WITH. NO SHIFT KEYS!
Offline frosty
  • jukebox hero
Re: Cherry MX Keycap Stabilizer Inserts
« Reply #1 on: Wed, 10 September 2014, 23:44:44 »
what about getting a proxy?
Offline frosty
  • jukebox hero
« Reply #2 on: Wed, 10 September 2014, 23:48:36 »
try this, it's still from WASD Keyboards but now the seller is MK. Maybe it'll have cheaper shipping.
Offline Oobly
« Reply #3 on: Thu, 11 September 2014, 01:07:29 »
Sigh... yet another reason to use Cherry style stabs instead.
AFAIK, WASD and MK are the only places to get them. And they're quite expensive for 2 tiny pieces of plastic. $11 just for 2 Shift keys.
If the plate or PCB support them, maybe try to get some Cherry stabs instead? If you don't like the "mushy" bottom out feel, you can clip them. Then they're better in practically every way than Costar style, IMHO.
Plate mount 2x, 2.25x, 2.75x stabiliser unit:
Mouser sells some: http://fi.mouser.com/ProductDetail/CHERRY/0G990224/?qs=sGAEpiMZZMsaqnnEkh1zaR6b6%2fY%252bBATZ%2fM4l7siKl0I%3d
As does DigiKey: http://www.digikey.com/product-detail/en/0G990224/0G990224-ND/424648
And Farnell/Newark/element14: http://www.newark.com/cherry/0g990224/mx-leveling-mechanism-kit-1x2/dp/98B1430
This place in Canada sells the PCB mount 2x units: http://www.e-sonic.com/product-detail/cherry-electrical/g990742.html?p=11075025&ref=OctopartFeed
And they happen to have 2 in stock :)
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline frosty
  • jukebox hero
« Reply #4 on: Thu, 11 September 2014, 03:47:33 »
OP's keyboard looks like a QFR.
Offline Oobly
« Reply #5 on: Thu, 11 September 2014, 05:20:23 »
Looks that way. So, does it support plate or PCB mount Cherry stabs?
« Last Edit: Thu, 11 September 2014, 05:21:58 by Oobly »
Offline Oobly
« Reply #6 on: Thu, 11 September 2014, 05:43:29 »
From what I can tell, if you enlarge the holes in the plate you can fit Cherry plate mount stabs.
Looks like the PCB doesn't have mount holes for Cherry PCB mount stabs.
Of course the easiest would be to just buy the inserts from Mechanical Keyboards or WASD. I am providing infromation on another possibly cheaper option, but it requires more work.
Offline yomammary
« Reply #7 on: Thu, 11 September 2014, 07:22:16 »
Something like that?
http://www.qwer.io/shop/accessories/2u-cherry-stabilisers/
Shipping doesn't seem too expensive I guess... :-[
RF 87u 55g | Leeku 1800
« Reply #8 on: Thu, 11 September 2014, 07:47:36 »
Yeaaa... but you gotta measure it correctly, and it's kinda hard to get it under there without some cutting or desoldering surrounding switches.
Offline abjr
    • abjr.org
« Reply #9 on: Thu, 11 September 2014, 09:10:03 »
It shouldn't be that expensive. The minimum order on wasdkeyboards.com is $3 and the clips and insert kits are 50 cents for a pair and the springs are 50 cents for one. Their shipping to Canada is under $7 dollars. So it should be less than $10 USD ... where is the $22 coming from?
From their site:
USPS
 First-Class Package International Service $6.55
If you are desperate, just PM me your address. I'll throw 4 in an envelope and send them to you.
« Last Edit: Thu, 11 September 2014, 09:19:05 by abjr »
CM QFR | magicforce 68 (Gateron) | magicforce 68 (Outemu) | Acros 6311-K
Offline abjr
    • abjr.org
« Reply #10 on: Fri, 12 September 2014, 11:42:30 »
So the Post Office here wouldn't just let me throw 4 in an envelope. They were going to make me ship them First Class International in a padded envelope which was almost $9 to ship $1 worth of plastic. I'm nice but I guess I'm not that nice. Not to mention I would have had to fill out a customs form. I guess that shows how naive I was about just throwing 4 in an envelope!
Surely someone in Canada can send you 4 otherwise I would suggest to just order $3 worth of stuff from WASD and it's $6.55 shipping.
Sorry :(
Offline GL1TCH3D
« Reply #11 on: Sat, 13 September 2014, 11:18:04 »
I'm going to be ordering stabilizers from Qwer and I'm in Canada too. We could split the price. PM me
Offline crimsonTofu
« Reply #12 on: Sun, 21 September 2014, 21:11:47 »
Thanks for all the suggestions guys. Abjr ended up sending me 4 inserts so big thanks to you sir.  :)
« Reply #13 on: Sun, 21 September 2014, 21:29:52 »
Sorry :(
$6.16 is the price if you pay online. cheapest possible international shipping. WASD price is a little more to cover the cost of a bubblemailer.
Such a great person. Glad you got it sorted out.
Offline abjr
    • abjr.org
« Reply #14 on: Sun, 21 September 2014, 23:25:44 »
In fact I was able to send them as "First-Class Mail International Large Envelope" in a bubble mailer for $2.29 :)
