Author Topic: Reversible USB cables on Kickstarter  (Read 2556 times)
Offline SpecTP
« on: Fri, 12 September 2014, 10:40:48 »
there is a Kickstarter project to create USB cables (to mini-B available) that are reversible.  The cables are braided as well. https://www.kickstarter.com/projects/madeincollege/belaycords-reversible-usb-charging-cords-iphone-an?ref=popular
Re: Reversible USB cables on Kickstarter
« Reply #1 on: Fri, 12 September 2014, 10:47:02 »
kickstarters are worse than group buys :P
« Reply #2 on: Fri, 12 September 2014, 10:51:54 »
Idkkk... this doesn't seem very sturdy.. and without the more rigid insert piece, I feel like if the cable got tugged, it might break connection?
Overall... I think Lightning has been great, and we should just use something like that for everything...
Offline Data
« Reply #3 on: Fri, 12 September 2014, 10:55:32 »
Lightning port is massive overkill for input devices.  :P
What's wrong with USB?  It's easily the most ubiquitous device port (tied with VGA maybe).
« Reply #4 on: Fri, 12 September 2014, 11:06:17 »
i don't mean direct pcie, etc etc..
I just mean the solid one piece design..  usb is quite fragile.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #5 on: Fri, 12 September 2014, 12:36:00 »
Just wait until next year when USB type C plug comes out. It will be a standard at least for first USB that can be inserted either way. I hope it ends up replacing everything else that USB has used.
« Reply #6 on: Fri, 12 September 2014, 12:48:17 »
100watts eh?   finally  death by USB...
Offline GL1TCH3D
« Reply #7 on: Fri, 12 September 2014, 12:58:57 »
USB-C!
Though kickstarters are awful.
I've participated in 3. 1 turned out to be a scam, 1 turned out exactly as planned and the last turned out half-assed.
Offline esoomenona
  • Gnillort?
« Reply #8 on: Fri, 12 September 2014, 13:33:19 »
IMO, the selling point should be the reversible USB portion, but it just sounds like a "sell to Apple idiots" kickstarter to me.
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #9 on: Fri, 12 September 2014, 13:35:21 »
Makes sense considering apple is either trying or tried to patent this idea already.  Plus, considering the costs involved in getting MFi certification that's required to have usable lightning cables, you might as well target the **** out of them.
That being said, holy **** that price.
« Last Edit: Fri, 12 September 2014, 13:37:03 by tjcaustin »
Offline RED-404
« Reply #10 on: Fri, 12 September 2014, 14:28:10 »
100W = 5A at 20V. Unless your soldering probes to the power leads and stabbing them into your wrists, then finding a way to request the 100W power mode, I think you will be fine.
« Reply #11 on: Fri, 12 September 2014, 16:05:05 »
You know those movie scenes where hack0rz kill people by electrifying them through computer-gear?
Dunnn dun dunnnnn....
Offline RED-404
« Reply #12 on: Fri, 12 September 2014, 16:12:43 »
USB 3.1 100W... Wait, I just thought of something  :eek: we can now make less energy efficient backlit keyboards without LED flicker.  ;D
Offline Tiramisuu
« Reply #13 on: Fri, 12 September 2014, 16:51:19 »
Tripp Lite ur050003rab
Keyboard error F1 to continue.
Poker 2, Gherkin, Lets Split, Planck, Filco
