Author Topic: Enter key stuck and not bouncing back..  (Read 14353 times)
Offline fatchoi
« on: Sat, 13 September 2014, 05:12:49 »
Hi all, recently I built a faceu 60% board. However, when I put the key caps on, there is a big problem with my enter key. The enter key is a standard one with cherry style stab.
I installed my SP dolch enter key but upon the enter just sinks and stuck, not bouncing back...
I tried installing another enter key I have (Poker x key set) and it works well.
Can anyone please help and give some advice?
Edit: forgot to mention my space bar is also working well. My backspace and the 2 shifts are split into 2 keys, so they don't have stab, thus no problem at all.
Offline cherpalla
Re: Enter key stuck and not bouncing back..
« Reply #1 on: Sat, 13 September 2014, 05:51:25 »
Does the second key you tested utilize the stab?
c h e r
« Reply #2 on: Sat, 13 September 2014, 06:30:07 »
The enter key that sticks - is it flag?  Can you put it on a flat surface and see if it wobbles from side to side.
Cherry stabilisers are notorious for low tolerance of warped keys :(
Offline fatchoi
« Reply #3 on: Sat, 13 September 2014, 07:08:33 »
Yes, it does.
Just tried, the key is flat. I indeed also tried the other backspace cap of the same width (dsa cap, so it's compatible) but also fail to work.
I guess the distance of the 3 stems of the SP cap (problematic one) is shorter than my poker (working great)...
Thanks both for replying. Hope I won't end up desoldering every switch and LEDs... My board has a plate and only pcb mounted stab is supported.
It's impossible to easily swap or add stab.  :-X
« Reply #4 on: Sat, 13 September 2014, 07:22:36 »
Next step is to measure, as accurately as you can, the spacing between the stems on both enter keys.
It could take only 0.5mm difference to make the key stick.
« Reply #5 on: Sat, 13 September 2014, 08:49:35 »
Assuming you didn't put the stabs in Backwards..
put the stabs in.. and check for wobble
And check if the 3 holes in the cap are pointing straight down..    you may need to into the stab to compensate.
Offline cherpalla
« Reply #6 on: Sat, 13 September 2014, 15:34:54 »
c h e r
Offline fatchoi
« Reply #7 on: Sun, 14 September 2014, 01:55:58 »
Picture talks...  :)
Seems that there is tiny difference in the stem.
I followed someone else's assembly guide when I assemble the board. And I think it's impossible to invert the stab upside down because the holes in PCB are different between the top and the bottom. The wire is above the switch.
I think the caps' stem are vertical, because I tried another DSA profile backspace key of the same SP dolch set. Same problem..  :(
Offline cherpalla
« Reply #8 on: Mon, 15 September 2014, 10:53:01 »
Picture talks...  :)
There is a slight skewed angle here, so I can't really accurately measure the difference, but it does appear to be enough to cause a problem at the front of the key's base.
c h e r
« Reply #9 on: Mon, 15 September 2014, 11:18:47 »
put stabs into all three holes   ,  then lay a metal ruler ontop  and then on the side,   if it is the Stem,  you should see some spaces between the ruler and the stabs..
