Author Topic: Would filling open space in my keyboard case with foam reduce noise?  (Read 7961 times)
Offline wes1099
  • Technology and Dog Enthusiast
I was wondering if I could make my CMStorm Quickfire TK a little less noisy by filling the open space in the case with some sort of foam. I thought that it might make it sound a little less plasticy and high pitched. I was thinking I would try some sort of light open cell foam, but I have no idea. Any suggestions?
[Leopold FC660C]     [GON NeRD 60]    [Infinity Keyboard]    [ Model M Silver Label]
[Topre 45g Silent]     [Gateron Black]    [Cherry MX Black]     [Model Number 1390636]
        [May 20, 1987]
Offline HPE1000
  • Keycap Paparazzo
Re: Would filling open space in my keyboard case with foam reduce noise?
« Reply #1 on: Thu, 18 September 2014, 15:21:39 »
People commonly put a layer or two of shelf liner in the case of their keyboard. I guess it works, I have it inside of 3 of my keyboards.
« Reply #2 on: Thu, 18 September 2014, 15:34:33 »
Make sure it's not conductive. If you put some under the plate it should dampen a lot of the noise.
« Reply #3 on: Thu, 18 September 2014, 15:36:32 »
If your board has Blues, even with adding foam or drawer liner, it will still have that distinctive clicking noise. I've put drawer liner in a few of my boards, including some with Blues, and it doesn't eliminate/dampen that noise.
« Reply #4 on: Thu, 18 September 2014, 16:24:47 »
Felt makes a good dampener without changing anything. You can lay multiple flat sheets in the bottom.
Rather than just stuffing it into larger cavities at random, I cut strips and roll them into cylinders of the proper volume.
And, of course, there are always my EPDM mats!
http://geekhack.org/index.php?topic=59308.0
- D Trump 2026-10-24
Offline wes1099
« Reply #5 on: Thu, 18 September 2014, 19:22:16 »
Never even thought of felt. I will stuff some felt in there soon while I have the top half of my case off for painting.
        [May 20, 1987]
Offline Coreda
« Reply #6 on: Thu, 18 September 2014, 19:30:49 »
Fill your ears with foam and eliminate all noises. It's the better solution OP.
Offline spiceBar
    • ChessTiger.com
« Reply #7 on: Fri, 19 September 2014, 08:31:55 »
Yes it will reduce the noise. You need to fill all the cavities and make sure that the material you use is in contact and even presses a little bit against the back of the PCB. This will absorb the vibrations so less of them will transmit energy to the air in the form of sound waves.
Generally a keyboard filled with some kind of rubber foam or felt sounds less heavy and much more classy.
« Reply #8 on: Fri, 19 September 2014, 11:58:36 »
it would absorb some resonance.. but overall.. the keyboard won't be that much more quiet.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #9 on: Fri, 19 September 2014, 16:42:48 »
I liked how some epdm thick foam tape I had leftover from an AC install kit worked out. Should be able to find it at hardware store and it's not expensive.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #10 on: Fri, 19 September 2014, 17:18:37 »
i use duct tape, layer here, layer there, tad a foam here and so on............, but yes blues will still be noisy :thumb:
landing pads would probably do a better job in what you are wanting
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
« Reply #11 on: Sat, 20 September 2014, 00:23:09 »
If you have MX blues or greens, they will always emit a high-pitched tick tick noise as you type - it is just the design of the switch.
You can dampen the resonance a bit though with some sort of padding.
Offline godly_music
« Reply #12 on: Sat, 20 September 2014, 00:27:16 »
Submerge the keyboard and yourself in mineral oil. It's the right thing to do.
« Reply #13 on: Sat, 20 September 2014, 00:36:37 »
:eek:
Offline Owntrolf
« Reply #14 on: Sat, 20 September 2014, 13:19:16 »
:eek:
Dont worry thats what we do with computers right?
Same principles
« Reply #15 on: Sat, 20 September 2014, 16:20:06 »
I put shelf liner inside my cases. ;)
