Author Topic: LG34UC97 (Curved Ultrawide Monitor)  (Read 14244 times)
Offline Hundrakia
« on: Mon, 29 September 2014, 14:15:00 »
So, http://www.lg.com/uk/monitors/lg-34UC97 is apparently a thing, with Dell and AOC hot on their heels... I think I might go this way when I finally make a monitor purchase. I just don't game like I used to, and I'm more interested in mmo than fps most of the time.
Thoughts?
Mod Edit: Added a bit more description to the title
« Last Edit: Tue, 30 September 2014, 19:10:19 by HoffmanMyster »
Re: LG34UC97 (Curved Ultrawide Monitor)
« Reply #1 on: Tue, 30 September 2014, 19:14:11 »
Very interesting.  I love my ultrawide (thanks for asking, Sent! :( ), and it would be even better if it were slightly curved, I suspect.  I find myself shifting laterally at some points if I have windows snapped to the sides, so curved seems like the natural progression.   :thumb:
Offline Tiramisuu
« Reply #2 on: Tue, 30 September 2014, 19:16:28 »
light bleed in the corner and no availability yet.   to be seen
Keyboard error F1 to continue.
Poker 2, Gherkin, Lets Split, Planck, Filco
« Reply #3 on: Tue, 30 September 2014, 19:16:47 »
I'm all for curved.. buhhhhhhhhh  gonna need more than 34" if it's 21:9..   this is a really small monitor..
45" is a good spot for 21:9
Offline Tiramisuu
« Reply #4 on: Tue, 30 September 2014, 19:19:25 »
pixel size is good for a monitor at this size.  tough getting the full screen in you peripheral if it is a productivity tool.   Bigger isn't better for productivity.   for movies better off using a television.
« Reply #5 on: Tue, 30 September 2014, 19:22:15 »
we need more 100" tvs...
at that point.. it's about as big as it can get for typical living rooms..
Offline Sent
  • Simplistic Serenity
  • ¯\_(ツ)_/¯
« Reply #6 on: Tue, 30 September 2014, 19:38:02 »
THIS guy. :))
Like Hoff said, I think it'd be nice if my current ultrawide was slightly curved.  At a point, you start to move a bit too much just to take in all the screen real estate.  Of course, this thing is probably gonna cost a pretty penny.  Did a two second Google search and didn't find any info on pricing. :(
Offline Tiramisuu
« Reply #7 on: Tue, 30 September 2014, 19:50:33 »
the uc97 is resting around 4k usd.  The uc95 at 1300 is expensive but almost buyable.
« Reply #8 on: Tue, 30 September 2014, 19:53:03 »
how do you measure the diagonal of a curved monitor? I can think of a few different ways yielding different results depending on the bend radius.
« Reply #9 on: Tue, 30 September 2014, 21:06:23 »
IMO you have to follow the surface, so you'd measure the surface distance from one corner to the opposite corner.  If you did shortest distance corner to corner you'd end up with weird situations where a full circle yields a tiny "screen size".
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #10 on: Wed, 01 October 2014, 04:11:19 »
Oooooooo... That's nice....
Offline paicrai
  • mindblank
« Reply #11 on: Wed, 01 October 2014, 09:15:05 »
i've really wanted a huge sleek shiny curved monitor for a while  :'(
someone plz gibe
THE FEMINIST ILLUMINATI
Offline Hundrakia
« Reply #12 on: Wed, 01 October 2014, 10:21:52 »
If nothing else, we know this is the future for monitors
Offline Signature
  • master of puppers
  • * Marketplace Moderator
  • snoozing
« Reply #13 on: Thu, 02 October 2014, 13:05:22 »
Thoughts?
I guess you saw the Linus review :)
Offline Hundrakia
« Reply #14 on: Thu, 02 October 2014, 13:23:16 »
Thoughts?
I actually did see that review. I want to see one in person now haha
Offline Hypersphere
« Reply #15 on: Thu, 02 October 2014, 13:40:29 »
Interesting idea. My workstations have 3 monitors: 27 inch in the center flanked by two 24 inch. It would seem to make sense to fill in the seams and just have one curved screen. However, this would actually not suit all my needs. This is because in my situation I use the triple monitor setup with 3 computers: Mac, Linux, and Windows. I have various options via Synergy software and/or switches on the monitors to use any combination of the 3 monitors with 3 computers. So, for example, I can have each monitor showing output from each computer, a single computer showing its output on all 3 monitors, or anything in between. Therefore, for this kind of setup, a single curved monitor would not work for all of the options that I use.
« Reply #16 on: Thu, 02 October 2014, 14:22:28 »
that's easy... buy 3 curved monitors and stack them vertically..  problem solved..
Offline Hundrakia
« Reply #17 on: Thu, 02 October 2014, 15:49:26 »
I have want for two curved ones, but likely I'd just have the 21.5 I have currently as the browsing monitor, turned sideways like a glock.
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
« Reply #18 on: Sat, 04 October 2014, 22:40:01 »
Oh this thing! I want one of these.
« Reply #19 on: Mon, 06 October 2014, 11:28:40 »
anyone else considering getting some to mount vertically? Is that even feasible for a curved monitor?
Offline JackMills
« Reply #20 on: Mon, 06 October 2014, 11:35:17 »
As I understood it isn't even possible cause there's no VESA mount, only the mount for the standard leg.
Edit: apparently it depends on region (according to Linus review)
Offline exitfire401
  • The Force is Re/\l
« Reply #21 on: Mon, 06 October 2014, 11:40:37 »
This...I really wanted one and figured after LG's last ultrawide, they would have VESA mount compatibility...It's ultimately a dealbreaker for me because I don't have the room on my desk for it.
Offline Sent
  • ¯\_(ツ)_/¯
« Reply #22 on: Mon, 06 October 2014, 17:09:23 »
The no VESA mount makes me sad.  I really want to stack this or any other two ultrawide on top of each other.  Hmm...
Offline Tiramisuu
« Reply #23 on: Mon, 06 October 2014, 17:24:08 »
No VESA mount and a **** stand.   There should be 1 or 2 more 34" monitor using this panel coming out at more competitive prices in the next couple of months (the flat not the curved).
if the uc65 had a vesa mount it could have been a champion.
Offline Hundrakia
« Reply #24 on: Mon, 06 October 2014, 21:51:57 »
I'm scouring the web daily for a price on that new Dell unit that is coming out, but again I haven't heard on that one having a Vesa mount or not. If I have to, I will rig something up outta my odds and ends to get it mounted. I've done crazier things before!
Offline Hundrakia
« Reply #25 on: Mon, 06 October 2014, 22:00:04 »
Hmm. I never noticed in the video that I watched that the other one was also curved, a 34UC87 with an adjustable stand just might tick that last box for me.
/goes off to Google this monitor
Offline JackMills
« Reply #26 on: Tue, 07 October 2014, 10:12:52 »
Seems that the 34UC87 has a mounting for which you could easily make an adapter plate (if it isn't VESA already), but it would be more expensive than the 34UC97 (1100€ vs 1300€ http://hardforum.com/showthread.php?t=1834533, but I can only confirm the 1100€ for the 97).
I'm not convinced about the curve and a flat 34" combined with an Ergotron stand would still be cheaper. (for example AOC Professional U3477PQU for 530€ and Ergotron LX for180€, taxes not included)
Edit: Corrected price for ergotron LX
« Last Edit: Tue, 07 October 2014, 10:18:00 by JackMills »
Offline Hundrakia
« Reply #27 on: Tue, 07 October 2014, 11:09:06 »
Yeah, that's true.
« Reply #28 on: Tue, 07 October 2014, 11:59:27 »
I'm not sold on curved monitors yet, considering the curvature is not adjustable..
That means the ideal distance from screen is  PRESET @ factory..
So if you wanted it further out, or closer, that just won't happen.
Offline Signature
  • master of puppers
  • snoozing
« Reply #29 on: Tue, 07 October 2014, 12:02:49 »
Depends on how much force you use
« Reply #30 on: Tue, 07 October 2014, 12:35:23 »
 :-\ :-X :-\
True, but consider this... the ideal distance from the screen on a totally flat monitor is essentially infinity.  So any minimal curve will "help" (relative term) in that regard.  Now, if it's curved too much, that's a different issue.
« Reply #31 on: Tue, 07 October 2014, 12:44:25 »
 :-\ :-X :-\
Hmm...........
well if we're talking about LARGE monitors,  the curve is then reduced to a gimmick, because then the distance difference between curved vs uncurved is a set amount..
so the curved portion vs the uncurved portion will only be say, 3 inches difference..
@ a viewing distance of 8 feet, thats 3%...  probably not even noticeable..
ugh....
We've been tricked.. .
Offline Signature
  • master of puppers
  • snoozing
« Reply #32 on: Tue, 07 October 2014, 12:50:26 »
I guess the curve is more of an premium feature for you to pay 200€ extra for something "revolutionary"
Offline Hundrakia
« Reply #33 on: Tue, 07 October 2014, 14:05:13 »
Yeah tp, curved TVs are an accessory that is best reserved for a private theater that one needn't share with anyone they care about.
« Reply #34 on: Tue, 07 October 2014, 14:31:45 »
For a while I had a basement setup with a projector. 12 feet viewing distance, 120inch screen
But eventually I gave up on the whole thing.. because it's nearly impossible to get good blacks with any light in the room..
and this was with an epson 8700ub,
and you really can't use the computer for too long in a completely dark room, because the contrast hurts your eyes..
Offline JackMills
« Reply #35 on: Tue, 07 October 2014, 15:17:29 »
Marketing just knows that men like curves, so curved screens were bound to happen.
« Reply #36 on: Tue, 07 October 2014, 15:20:22 »
Offline Signature
  • master of puppers
  • snoozing
« Reply #37 on: Tue, 07 October 2014, 15:22:32 »
Especially curvy LGs
