Author Topic: Ergodox on Windows XP (dont laugh!)  (Read 1358 times)
Offline Purdah
« on: Thu, 02 October 2014, 17:14:33 »
Yes, some of us are still forced to use XP, so is there a way to get the Ergodox to work on Windows XP?
I flashed the firmware with my Mac, but I want to use the Ergodox at work, but it is not recognised when I connect it.
Has anyone managed to get it working on windows XP?
Offline Purdah
Re: Ergodox on Windows XP (dont laugh!)
« Reply #1 on: Thu, 02 October 2014, 21:43:47 »
On further ivestigation it appears as though the usb ports on the front of my machine are broken, so nothing to do with the Ergodox at all  :D
Offline Hyde
  • White Tofu Extraordinaire
« Reply #2 on: Fri, 03 October 2014, 08:52:06 »
Hmmmmm is it safe to assume your keyboard will cost more than your workstation at work.  :p
