Author Topic: How would 62g springs in Red vs Clear feel?  (Read 6618 times)
Offline Karura
  • Professional Canadian
  • SKidata life.
« on: Fri, 03 October 2014, 06:21:20 »
Hello,
Just doing some research and would like to hear some experiences from you guys before I decide to mod my switches.
I'm planning to do a custom board, and wonder what would the difference be between red and clear switches with 62g springs in them.
So far I'm a big MX red fan as you can tell by my signature, so perhaps I might be happy with them lubed up and modded, then again ergoclears are pretty well regarded by the community.
I like the idea of a stiffer red, and honestly have no idea how a light tactile ergoclear would feel for gaming since I'm used to linear.
How do they compare?
« Last Edit: Fri, 03 October 2014, 06:23:46 by Karura »
Offline kitsun8
  • In need of some cash
Re: How would 62g springs in Red vs Clear feel?
« Reply #1 on: Fri, 03 October 2014, 06:54:22 »
The main difference between the two switches, as you have already noted, is in the tactile feedback the clears have over the linear reds. The springs are really just a preference as you can have 62g or 65g for ergo clears. If you want a stiffer red, maybe you could go with black? They're both linear and black is just stiffer so it might save you mod time if you care about that side of things. Tactile IMO is in the middle ground between typing and gaming. If you play a lot of fps the reds/blacks might be better since some people say its easier to doubletap without tactile feedback (e.g. double tapping q in CS) alternatively, you could go crazy with your switch types and have certain colours for certain keys. I have red switches on my z,x and q for games like OSU and CS with the rest being browns. This doesn't affect me too much since I hardly use those keys when typing anyways, so in the end it really depends on what YOU want to do ;D hope that helps haha
Offline Oobly
« Reply #2 on: Fri, 03 October 2014, 07:31:14 »
Hello,
So far I'm a big MX red fan as you can tell by my signature, so perhaps I might be happy with them lubed up and nodded, then again ergoclears are pretty well regarded by the community.
62g Reds will feel like.... Reds - with a slightly stronger spring.
62g ErgoClears are a completely different beast. They are the most tactile MX switch I have yet tried and also my favourite. The bump is large and effective. You can use it as a reference for where the actuation takes place, you can "rest" the switch on the bump on the upstroke to keep it ready to actuate again by just pressing a tiny bit harder. Useful for "twitch" games like fast-paced FPS. They also feel great for typing :)
« Last Edit: Fri, 03 October 2014, 07:33:12 by Oobly »
Buying more keycaps,
it really hacks my wallet,
but I must have them.
« Reply #3 on: Fri, 03 October 2014, 07:43:46 »
I recorded some of my thoughts on this mod here if you're interested in reading.
Offline munch
« Reply #4 on: Fri, 03 October 2014, 16:03:37 »
cool. so 62g reds are still lighter than original blacks? "korean springs"?
Offline rainb1ood
  • so pretty so plastic
« Reply #5 on: Fri, 03 October 2014, 16:14:12 »
How do they compare to Ergoclears with regular spring from MX Brown?
Offline Karura
  • SKidata life.
« Reply #6 on: Fri, 03 October 2014, 16:26:26 »
^Wiki covers this, apparently just a larger tactile bump with the clears
Offline RED-404
« Reply #7 on: Fri, 03 October 2014, 16:31:45 »
Cherry MX Red 45 cN = 45.887229584 g
Cherry MX Black 60 cN = 61.182972779 g
Cherry MX Linear Grey 80 cN = 81.577297038 g
So umm your making MX Blacks I think.
Unless I am misunderstanding something or just suck at math. The odds of this are good.
Edit: I learned something. ⇩⇩⇩⇩⇩⇩⇩⇩⇩⇩⇩
« Last Edit: Fri, 03 October 2014, 16:46:33 by RED-404 »
Offline Karura
  • SKidata life.
« Reply #8 on: Fri, 03 October 2014, 16:34:41 »
To make it clear, there are two ways of calculating forces, accentuation force (Cherry) or bottoming out force (Korean).
So for example Cherry says reds are 45g, but the bottoming out force for them are 55-60g in reality.
So Korean springs with 62g would only be a tad heavier than stock cherry red springs, and way lighter than blacks.
Hope that clears things up, been reading a lot on it.
« Last Edit: Fri, 03 October 2014, 16:37:00 by Karura »
Offline RED-404
« Reply #9 on: Fri, 03 October 2014, 16:42:03 »
Thanks +1 internetz
Offline jacobolus
« Reply #10 on: Fri, 03 October 2014, 16:44:30 »
Put the clear springs in the red switches. Then put either the red springs or the 62g springs in the clear switches.
Offline kitsun8
« Reply #11 on: Fri, 03 October 2014, 17:08:49 »
Red springs are really light and i've heard that sometimes the clears have trouble coming back up
« Reply #12 on: Fri, 03 October 2014, 18:00:17 »
62g clears seems to be the favorite mod
62g reds don't see too much of a difference from stock reds. A little lighter, yeah, but not much.
Offline jacobolus
« Reply #13 on: Fri, 03 October 2014, 18:14:18 »
If you lubricate the sliders, they’re fine. If you don’t lubricate the sliders, they’re still mostly fine; if the occasional sticking might bother you, then either use slightly stiffer springs or add some lubricant.
Or just give up on mediocre tactile MX switches, and get some nice Alps switches instead.
Offline rainb1ood
« Reply #14 on: Fri, 03 October 2014, 18:57:00 »
I used the wiki search box and couldn't find it, can you post the link here? Just to be clear, I want to find out from anyone who have both experience using ergoclear with 62g spring and regular mx brown springs.
« Last Edit: Fri, 03 October 2014, 19:00:14 by rainb1ood »
Offline Karura
  • SKidata life.
« Reply #15 on: Fri, 03 October 2014, 19:23:15 »
Sure, it's in here: http://deskthority.net/wiki/Cherry_MX_Ergo_Clear
"Somewhat like the Brown switch, but with a bigger, longer tactile bump."
Offline kitsun8
« Reply #16 on: Fri, 03 October 2014, 19:23:49 »
The tactile feedback is definitely more noticeable. If you look at the switch mechanisms you will see that there is a bigger bump. I've been using clears for a bit and they're a bit stiffer than browns which i like for typing as i don't bottom out as much. They're also good for gaming :))
Offline Karura
  • SKidata life.
« Reply #17 on: Fri, 03 October 2014, 19:24:20 »
Nice writeup, I noticed that you didn't like lighter switches like Reds to begin with, but if you were to pick between stock MX Red and 62g lubed Reds, would you say the 62g Reds are an improvement to you?
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #18 on: Fri, 03 October 2014, 19:24:42 »
word to the mothership
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline rainb1ood
« Reply #19 on: Fri, 03 October 2014, 20:07:27 »
I see, I have ergo clears with mx brown as my daily driver, that is why I'm curious if using 62g springs will have better tactile
Offline kitsun8
« Reply #20 on: Fri, 03 October 2014, 20:09:23 »
I'm hoping that alps GON 60% IC goes through ;)
Offline kitsun8
« Reply #21 on: Fri, 03 October 2014, 20:13:55 »
It feels like a biiiig difference  ;D
Offline munch
« Reply #22 on: Sat, 04 October 2014, 04:55:34 »
wha- lighter than stock reds? How Can This Be ! ! ? !
Offline frosty
  • jukebox hero
« Reply #23 on: Sat, 04 October 2014, 04:57:54 »
62g reds = worn in vintage blacks but with a gritty stem (that is if you have not lubed the 62g reds)
62g clears = omg omg omg omg omg omg
light but springy. The tactile sensation is really gooooood.
Offline Karura
  • SKidata life.
« Reply #24 on: Sat, 04 October 2014, 05:33:00 »
One more question regarding this then; what about getting 67g or 68g springs for Clears, because eventually the springs will wear down and lose about ~5g?
« Reply #25 on: Sat, 04 October 2014, 08:05:23 »
Would you say the 62g Reds are an improvement to you?
No. I find 62g too light. I have 65g blacks in my Epsilon. The red and black stems are the same.
Eventually the springs will wear down and lose about ~5g?
You'll be bored of the hobby way before you wear your Springs enough to lose 5g of actuation force.
Offline munch
« Reply #26 on: Sun, 05 October 2014, 09:45:22 »
I am slightly confused. TacticalStache says 62g reds (korea springs?) are lighter than stock reds, but you ^ CPTBadAss say in your nice post that they're heavier than stock reds.
HOPING that the gold springs in the GB section would be slightly heavier than Reds but lighter than Blacks.
I think your post seems more well-written-out and whatnot but I suppose it can depend greatly on what springs used too... :p
« Reply #27 on: Sun, 05 October 2014, 13:33:37 »
In the red, it would just feel like blacks...
the clear springs are more than 62
Offline PointyFox
« Reply #28 on: Sun, 05 October 2014, 13:39:35 »
Vintage blacks do not need to be worn in to feel like they do.  Even unused ones feel the same way.
Offline jacobolus
« Reply #29 on: Mon, 06 October 2014, 03:14:52 »
His “worn in” was clearly with reference to the 62g part; as in, 62g springs are like heavily used MX black springs; not sure that’s especially accurate though.
« Last Edit: Mon, 06 October 2014, 03:17:11 by jacobolus »
Offline frosty
  • jukebox hero
« Reply #30 on: Mon, 06 October 2014, 03:49:56 »
ya with the 62g part.
