Author Topic: CM Quickfire Rapid Aluminum Case  (Read 4870 times)
Offline Jools
« on: Tue, 21 October 2014, 21:04:55 »
I was wondering if anyone knew where to get one or if there are any places who actually sell them. Any help would be appreciated, thanks!
Re: CM Quickfire Rapid Aluminum Case
« Reply #1 on: Tue, 21 October 2014, 23:04:41 »
I think the vortex case will fit but I'm not 100% sure:
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=212
TEX case might as well:
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=281
Offline Sniping
« Reply #2 on: Wed, 22 October 2014, 03:13:06 »
I think the TEX case is the only option at the moment (but a very good option at that). The Vortex cases haven't been sold in a while and there isn't much of a market for TKL cases that are readily being sold right now.
Offline Jools
« Reply #3 on: Wed, 22 October 2014, 15:50:24 »
Thanks guys!
« Reply #4 on: Wed, 22 October 2014, 15:52:34 »
anything that works for a Filco will work for a QFR
Offline FrostyToast
  • Litshoard
« Reply #5 on: Wed, 22 October 2014, 15:54:09 »
I thought the vortex case did work with the qfr...
Fairly positive it does.
Quote from: elton5354
« Reply #6 on: Wed, 22 October 2014, 16:00:28 »
for qfr, the daughter board has  to go outside..  idk if the tex case can situate it inside.. it looks like it might.
« Reply #7 on: Wed, 22 October 2014, 16:01:22 »
i forgot about the daughter board
it should still work if you put something there to prevent shorts
Offline esoomenona
  • Gnillort?
« Reply #8 on: Wed, 22 October 2014, 16:05:03 »
« Last Edit: Wed, 02 September 2015, 13:43:59 by esoomenona »
