Author Topic: HEFI Diagnostics At Startup- How To Turn Off?  (Read 3271 times)
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« on: Fri, 24 October 2014, 18:32:13 »
does anybody know how to turn off or disable the UEFI diagnostics at windows startup?
i don't know what i did, but on startup now i have to go through that on my HP Envy Windows 8 machine.........driving me crazy and i cannot find how to turn off?
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
Re: HEFI Diagnostics At Startup- How To Turn Off?
« Reply #1 on: Fri, 24 October 2014, 18:46:48 »
It's likely you either triggered it from some kind of HP software (assistance, recovery something like that) that's bundled with your computer and you should just turn it off through that OR you have a UEFI bootable device that you forgot about and is still plugged in.
It might also be a setting in your BIOS if it's been heavily customized by HP.
« Last Edit: Fri, 24 October 2014, 18:55:52 by the1onewolf »
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #3 on: Fri, 24 October 2014, 21:13:36 »
were you in the bios playing around ?
i went into the bios afterwards, but still no dice getting rid of it.
something about it is some kind of default for windows 8?
it is about to drive me nuts.........i know there is some way to get rid of it, but i have not figured out yet :-\
« Last Edit: Fri, 24 October 2014, 21:15:27 by terrpn »
« Reply #4 on: Fri, 24 October 2014, 23:27:18 »
if you didn't go into the bios to CAUSE IT..  then it must be a windows 8 thing.. I've never seen it on Win 7
Offline Novus
  • Mondai nothing~
« Reply #5 on: Sat, 25 October 2014, 02:25:30 »
It's likely not a windows thing.
« Last Edit: Sat, 25 October 2014, 02:28:45 by the1onewolf »
Offline trizkut
« Reply #6 on: Sat, 25 October 2014, 03:38:32 »
Maybe it's an HP thing?  HP website says to press f2 to go enter UEFI diagnostics..  If you haven't touched the BIOS, maybe your f2 key is stuck?  :blank:
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #7 on: Sat, 25 October 2014, 10:40:47 »
yea............i'm thinking it is a HP thing.
that's is why i hate buying computers vs building my own, so much bundled garbage on them :-\
will get my IT guy at the office to fix
« Reply #8 on: Sun, 26 October 2014, 17:52:25 »
reload any computer with a fresh copy of windows as soon as you get it.
« Reply #9 on: Mon, 27 October 2014, 15:21:31 »
Fresh copy of Windoz 7 ***
