Author Topic: Hard vs Soft  (Read 5161 times)
Hard vs Soft
« on: Tue, 28 October 2014, 04:04:00 »
... boiled Eggs..
also..
Do you LIKE the sulfur taste when it's Over-boiled...  I've been told that I'm weird for liking it.
Re: Hard vs Soft
« Reply #1 on: Tue, 28 October 2014, 04:21:03 »
Over easy so you can make a hole in one sandwich.
80997-0
Offline peachesenregalia
Re: Hard vs Soft
« Reply #2 on: Tue, 28 October 2014, 04:38:16 »
Smells and tastes more like methane, which I find borderline revolting.
Good feeling of oneness.
Offline Oobly
Re: Hard vs Soft
« Reply #3 on: Tue, 28 October 2014, 04:46:12 »
Fried, semi-soft, so the white doesn't go all tough and the yolk can be used for dipping toast into....
Don't like 'em boiled. If I have to choose, I take soft, though.
And I don't like the sulphur smell, but each to their own.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Re: Hard vs Soft
« Reply #4 on: Tue, 28 October 2014, 05:09:53 »
if only poaching was easier.. I would do that all the time.
Offline paicrai
  • mindblank
Re: Hard vs Soft
« Reply #5 on: Tue, 28 October 2014, 07:54:40 »
i thought we were talking about ****s you nerds gosh
THE FEMINIST ILLUMINATI
Re: Hard vs Soft
« Reply #6 on: Tue, 28 October 2014, 07:56:09 »
Not sure what you are doing to make your eggs taste like methane, I've never had this experience.  ???
Re: Hard vs Soft
« Reply #7 on: Tue, 28 October 2014, 08:22:07 »
These take 10 minutes but work great. Swish a drop of oil around on the inside and they slide out.
http://www.bedbathandbeyond.com/store/product/poachpod-reg-set-of-2/1014676970?Keyword=egg+poach
- Franklin Roosevelt 1933
Offline JPG
  • Model F is my new passion!
Re: Hard vs Soft
« Reply #8 on: Tue, 28 October 2014, 08:28:54 »
Looks brilliant. I don't eat eggs often enough to justify this, but it looks very great!
Re: Hard vs Soft
« Reply #9 on: Tue, 28 October 2014, 08:37:55 »
Joke:
What goes in hard, straight, and dry, and comes out soft and gooey?
Chewing gum.
Offline Oobly
Re: Hard vs Soft
« Reply #10 on: Tue, 28 October 2014, 09:34:57 »
QFT... Poached eggs on toast... Now I'm getting hungry.  :D
Offline osi
Re: Hard vs Soft
« Reply #11 on: Tue, 28 October 2014, 11:33:48 »
eggs over hard is the best Over medium is ok too, but not too runny!!
Re: Hard vs Soft
« Reply #12 on: Tue, 28 October 2014, 11:43:28 »
Am I the only one here who grew up eating runny eggs with grits?
Offline epzy
  • HHKB Fiend
  • ded
Re: Hard vs Soft
« Reply #13 on: Tue, 28 October 2014, 11:44:00 »
soft
Re: Hard vs Soft
« Reply #14 on: Tue, 28 October 2014, 11:45:10 »
Also deviled
Re: Hard vs Soft
« Reply #15 on: Tue, 28 October 2014, 11:48:50 »
...liquid anyone?
« Last Edit: Tue, 28 October 2014, 11:50:38 by SpAmRaY »
Re: Hard vs Soft
« Reply #16 on: Tue, 28 October 2014, 11:50:43 »
What, like Eggbeaters?
Offline azhdar
  • Praise the AZERTY god
Re: Hard vs Soft
« Reply #17 on: Tue, 28 October 2014, 11:55:15 »
Exactly , as we say in France, I like Oeuf à la coque but it needs to be fresh eggs
Now i'm hungry u_u
Azerty Propagandiste
Re: Hard vs Soft
« Reply #18 on: Tue, 28 October 2014, 15:43:47 »
Now i'm hungry u_u
man that looks complicated... having to break the shell without cracking the rest. .
Re: Hard vs Soft
« Reply #19 on: Tue, 28 October 2014, 20:16:33 »
The egg poachers I got last time also didn't work out...
the microwave one was inconsistent, and the stovetop one was a pain in the ass to clean (and you have to watch it like a hawk, or else it fully cooks)
Re: Hard vs Soft
« Reply #20 on: Tue, 28 October 2014, 21:36:42 »
Use your finger and wipe one drop of oil around on the inside before you put the egg in.
If you use the same size egg you should be able to get the time down for the degree of doneness you prefer. Pull it out and plop it into a bowl of cold water to stop the cooking if you are especially picky.
Offline eth0s
  • Peace & Love
Re: Hard vs Soft
« Reply #21 on: Tue, 28 October 2014, 21:46:51 »
Joke:
Chewing gum.
What sticks so far out of a man's pajamas that you can hang a hat on it?  His head (and/or penis).
Is that a joke?
As for eggs, the best kind are eggs benedict, by far.  They are poached eggs and ham on an english muffin smothered with egg sauce (sauce hollandaise).  If you've never eaten eggs benedict, then you are an unenlightened philistine.
Re: Hard vs Soft
« Reply #22 on: Tue, 28 October 2014, 21:48:01 »
:facepalm: i literally laughed out loud
Re: Hard vs Soft
« Reply #23 on: Tue, 28 October 2014, 22:01:26 »
I think simplified Eggs bene.... is good enough..
ham + poach egg + lemonjuice + some butter..
assuming the proportions are right,   close your eyes,  you won't know the difference..
if you had to emulsify the yoke and butter, that is pretty time and nerve consuming..
Offline munch
Re: Hard vs Soft
« Reply #24 on: Tue, 28 October 2014, 23:51:03 »
poached. creamy yolk. eggs benedict style I guess? never had an eggs benedict but it always looks great.
I like it 'sous-vide' the best but it just takes kinda long to do so (~1hr).
or shallow fried thai-style, so good.
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: Hard vs Soft
« Reply #25 on: Tue, 28 October 2014, 23:57:32 »
Depends on what I am having with it. Mostly I go kind of in between so the yolk is mostly congealed but not solid. I like that best especially with noodles.
If you like Benedict, you should try Croque Madame. Béchamel, Gruyere and Black Forest Ham on crunchy French bread with egg on top. I usually make it more like a Monte Cristo, then put the egg on top raw and pop it in the broiler for a moment.
Offline azhdar
Re: Hard vs Soft
« Reply #26 on: Wed, 29 October 2014, 02:18:21 »
Now i'm hungry u_u
You simply tap the top so it's start to shatter , then you cut off the shattered part with a knife . Easy and delicious .
Re: Hard vs Soft
« Reply #27 on: Wed, 29 October 2014, 02:49:05 »
When ever I hear the word (noodles..)
I go make some.. it's insane..   /addiction
Re: Hard vs Soft
« Reply #28 on: Wed, 29 October 2014, 06:57:55 »
Cooking scrambled eggs without them sticking to the bottom of the pan LEVEL=IMPOSSIBLE
non-stick pan? they stick even more for some reason than a stainless skillet
more oil/butter? now they are burnt AND stuck to the pan
lower heat? no difference at all, still sticking
« Last Edit: Wed, 29 October 2014, 06:59:48 by noisyturtle »
Re: Hard vs Soft
« Reply #29 on: Wed, 29 October 2014, 07:05:18 »
ur serious? u can't scramble eggs ?
Offline osi
Re: Hard vs Soft
« Reply #30 on: Wed, 29 October 2014, 07:06:51 »
I like to cook up some bacon and then fry eggs. After cooking the bacon, I give the pan a little rub down but leave some bacon grease in there--just enough to where the eggs do not stick. Mmmmm
Re: Hard vs Soft
« Reply #31 on: Wed, 29 October 2014, 07:07:49 »
No without a mucous-thin layer of brown calcified **** that would survive a nuclear blast forming on the bottom of the pan.
Re: Hard vs Soft
« Reply #32 on: Wed, 29 October 2014, 07:26:12 »
When I was in college, I had a job waiting tables in a restaurant. They hired a new kid who knew nothing about anything, and asked me to help train him.
One of our items was Eggs Benedict, and I was explaining it to him. Clearly, he was just not "getting it" and kept looking at me with a completely puzzled look.
Finally, after about the 3rd try, his eyes lit up with a big smile and he said "Oh! You mean an Egg McMuffin?"
