Author Topic: Which finger do you use to press the "C" key (QWERTY)?  (Read 22996 times)
Offline faceyourfaces
« on: Sun, 02 November 2014, 13:10:48 »
The correct way is using your middle finger but I've found it a lot more comfortable to type with my index finger.
Offline paicrai
  • mindblank
Re: Which finger do you use to press the "C" key (QWERTY)?
« Reply #1 on: Sun, 02 November 2014, 13:11:19 »
index or thumb
THE FEMINIST ILLUMINATI
Offline FoxWolf1
  • 154
« Reply #2 on: Sun, 02 November 2014, 13:19:22 »
Thumb.
« Reply #3 on: Sun, 02 November 2014, 13:25:52 »
index..
for  thumb, you have to move your thumb inwards and raise your wrist slightly,  that is a very difficult movement.
« Reply #4 on: Sun, 02 November 2014, 13:30:41 »
palm
« Reply #5 on: Sun, 02 November 2014, 14:19:09 »
Index master race
Offline BlueNalgene
« Reply #6 on: Sun, 02 November 2014, 14:38:54 »
People use their thumb to press it? While typing?  You lot are mad.
Middle finger.
Offline paicrai
  • mindblank
« Reply #7 on: Sun, 02 November 2014, 15:51:54 »
Middle finger.
someone bring this creature in for autopsy at area 51
Offline BlueNalgene
« Reply #8 on: Sun, 02 November 2014, 16:13:33 »
Middle finger.
I'm a lefty and my hands are impressively broad.
Quarter for scale
« Reply #9 on: Sun, 02 November 2014, 16:16:30 »
I can palm a basketball, so I guess my hands are pretty big too.
Offline Grim Fandango
« Reply #10 on: Sun, 02 November 2014, 16:41:10 »
It is one of the two ways in which my touch typing differs from the standard/correct way. I use my index finger to type "C". Though to be honest, I think it is just as fast and possibly a little more comfortable.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #11 on: Sun, 02 November 2014, 16:43:01 »
**** 'proper'. I do whats comfortable for me.
Offline TacticalCoder
« Reply #12 on: Sun, 02 November 2014, 17:01:25 »
Middle finger. Works fine for both staggered and matrix layout. A secretary taught me to touch-type many years ago: I asked her to teach me because she beat me fair and square at a typing contest between the two of us (I was already typing since easily 15 years and thought I was fast... She beat me and so I decided to learn to type correctly and asked her to teach me).
« Reply #13 on: Sun, 02 November 2014, 17:42:54 »
pointer or middle finger
Offline Eszett
« Reply #14 on: Sun, 02 November 2014, 18:05:22 »
I type almost everything with my index finger, due to a lack of technique :-)
« Reply #15 on: Sun, 02 November 2014, 18:06:25 »
You have much to learn, welcome to GH.
Offline 00zeRO
  • mechanicalkeyboards.com
  • * Commercial Vendor
  • The 00verseer of Vault 77
    • Mechanical Keyboards
« Reply #16 on: Sun, 02 November 2014, 18:11:35 »
palm
ROFL...so...what you are saying is that you are typing on a broken membrane, and that is the only way to get it to register.
+1
Daily Driver: Typist A w/Midnight Dawn | Kailh BOX Clicks
Junktown 2: Now on eBay!
« Reply #17 on: Sun, 02 November 2014, 20:43:30 »
Index finger. I also use it to press X about 50% of the time.
I'm not the best QWERTY typist.
Offline FrostyToast
  • Litshoard
« Reply #18 on: Sun, 02 November 2014, 20:45:25 »
I type with my middle finger for "C" most of the time as well.
I have to shift my hand way too far left to press it with my index.
Quote from: elton5354
Offline epzy
  • HHKB Fiend
  • ded
« Reply #19 on: Sun, 02 November 2014, 20:46:04 »
left index finger
Offline Telephasic
« Reply #20 on: Sun, 02 November 2014, 20:52:15 »
Index. Gonna give middle a try. See if I notice any improvements.
Offline jacobolus
« Reply #21 on: Sun, 02 November 2014, 21:09:54 »
I’m impressed by your pinkies, and surprised you use your ring fingers for Alt.
Here’s me:
The “p” key is obviously placed for the right ring finger to press. :-)
« Last Edit: Sun, 02 November 2014, 22:44:57 by jacobolus »
« Reply #22 on: Sun, 02 November 2014, 21:11:03 »
i had to google which was my index finger
i am very ashamed right now
but index finger
« Reply #23 on: Sun, 02 November 2014, 22:09:42 »
I’m impressed by your pinkies, and surprised you use your middle fingers for Alt.
Here’s me:
you use thumb for alt? I cant curl mine over enough.
Offline FrostyToast
  • Litshoard
« Reply #24 on: Sun, 02 November 2014, 22:23:50 »
Not even a year ago I used only my ring, middle, and index fingers to type. Not even my thumb for spacebar. This is what I call "The Velociraptor"
One day, I said to myself, "I type like ****."
So I took a large portion of my day and the following days to correct my typing by only pressing keys with the finger that was supposed to be used in that column.
I started at a grueling 40 WPM and it was highly discouraging when I was typing at a snail's pace and I wanted desperately to go back to the velociraptor but I remained vigilant.
Now I can type at around 80 WPM which is pretty much what I was typing at before... One might say that my efforts were in vain as I didn't improve much at all, but my typing experience is much more comfortable.
Also: I don't actually press the "C" key with my middle finger 100% of the time. When I have too type a word like "cockatrice" I would use the middle finger for the first two Cs and then in order to press the E immediately after the C, I would have to press the C with my index and then the E with my middle. Hope that makes sense.
Offline mogo
« Reply #25 on: Sun, 02 November 2014, 22:40:16 »
Middle finger for me. Here's a map of my finger zones, but keep in mind that less-common keys like the bar key or square brackets usually involve me stopping everything and actually looking down at my keyboard and using whatever finger is convenient at the moment...
edit: 4 is def a middle finger. Whoops.
Offline bear95
« Reply #26 on: Mon, 03 November 2014, 05:22:53 »
Middle finger for me.... index when copy pasting
Offline paicrai
  • mindblank
« Reply #27 on: Mon, 03 November 2014, 07:09:37 »
hurr hurr left shin
Offline osi
« Reply #28 on: Mon, 03 November 2014, 07:10:49 »
Left index finger!!
Offline davkol
  •  Post Editing Timeout
« Reply #29 on: Tue, 04 November 2014, 11:23:31 »
The F* finger, because ErgoDox Master Race.
Offline esoomenona
  • Gnillort?
« Reply #30 on: Tue, 04 November 2014, 12:31:35 »
« Last Edit: Tue, 01 September 2015, 08:28:20 by esoomenona »
Offline davkol
« Reply #31 on: Tue, 04 November 2014, 12:38:39 »
Next thread: what finger do you use for G?
Offline esoomenona
  • Gnillort?
« Reply #32 on: Tue, 04 November 2014, 12:39:49 »
« Last Edit: Tue, 01 September 2015, 08:27:17 by esoomenona »
Offline Oobly
« Reply #33 on: Tue, 04 November 2014, 14:24:34 »
Left index. Basically the same as jacobolus' pattern, except sometimes I shift my hands outwards and use the middle instead of ring.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline bazh
« Reply #34 on: Tue, 04 November 2014, 14:33:29 »
middle finger. The only key that I type differently from the "proper way" is b, I always use right index on "B"
ah, forgot "6"
HHKB Pro2 white
Newbie again
Offline Lanx
« Reply #35 on: Tue, 04 November 2014, 15:18:04 »
You staggered guys, need to get some Matrix in your diet.
Offline NeedAFix
  • Ten Seconds until Midnight
« Reply #36 on: Tue, 04 November 2014, 17:53:13 »
The middle finger? Hahah, no thanks.
I use my thumb, so much easier.
The Bird of the Hermes is my name,
eating my wings to make me tame.
