Author Topic: Need recommend for a Laptop  (Read 3825 times)
Offline moemoe666
  • Silence Unicorn <3
« on: Sun, 23 November 2014, 14:12:29 »
Well, after afew weeks of roaming around and finding a new lappy, need alittle help from a great community :D
Budget: About $1300
And I'm looking for a nice gaming one, used/ ref is ok if price is reasonable within the budget
Target: lap with i7 gen 4, GTX 880M or M290x
I did find some Alienware but to far from budget
Have no love with Asus ROG, and MSI GT series :\
Or should I stick with some cheaper graphic card opt like GTX 870m?
any recommend
Stuff:
Black Bird V1: Clear 72g - Light Saver V2 : Black 62g  - Rosewill : Vintage Black - 38gt Acrylic case : Brown 55g - Ducky Z One : Brown - Keycool Brown: R.I.P
Zowie EC2 Evo Black & White - SS Sensei MLG - SS Frost blue - Kana V1 - Kinzu V1
Re: Need recommend for a Laptop
« Reply #1 on: Sun, 23 November 2014, 17:52:18 »
Make sure you really NEEED a gaming laptop..
Because if your budget is $1300..
Essentially.. the difference between a $1300 Desktop and Laptop is double the CPU power, Triple the GPU power..
Offline Rodgaroon
  • Size matters, just ask my wife.
« Reply #2 on: Sun, 23 November 2014, 17:57:42 »
G6v2 (MX Black) | Poker II (MX Brown) | Compact SQ (MX Clears 62g)
Offline exitfire401
  • The Force is Re/\l
« Reply #3 on: Sun, 23 November 2014, 17:59:37 »
http://www.ncix.com/detail/asus-rog-g551jm-intel-core-de-102952-1242.htm
or
http://www.ncix.com/detail/lenovo-y50-notebook-i5-4200h-8gb-d2-100321-1242.htm
Honestly; you don't need an i7 unless you are doing video editing. Go with the Lenovo.
Exactly this. Also, in your price range, you won't find an 880...need to bump 300-500 at least.
« Last Edit: Sun, 23 November 2014, 18:02:51 by exitfire401 »
Offline moemoe666
« Reply #4 on: Sat, 29 November 2014, 18:42:28 »
Thanks alot for your comments
I'd think I should save alittle bit more for a good one.
I do some video editing and gaming for sure :D
Stuff:
Offline MGH
Offline luisbg
« Reply #6 on: Mon, 01 December 2014, 09:13:02 »
I assume you run Windows since you mentioned gaming.
Have you considered the Samsung Series 9? Very nice body.
Leopold FC660M - Brown mx switches - black case - white blank keys :: ErgoDox - Blue mx switches - classic case - black blank keys
Offline ezrahilyer
« Reply #7 on: Mon, 01 December 2014, 11:58:43 »
I second the Lenovo Y50, I know someone who has one and loves it, plus I have always thought Lenovo (especially back when they were IBM) made quality stuff.
Offline luisbg
« Reply #8 on: Mon, 01 December 2014, 12:06:15 »
Lenovo was never IBM. You are probably thinking of the Thinkpad brand.
Lenovo bought the ThinkPad brand. Including the manufacturing technology, the global sales channels and operation teams. So in 2005 Thinkpads stopped being made by IBM and switched to being made by Lenovo. Most people think the quality of Thinkpads has slowly gone down since.
Offline exitfire401
« Reply #9 on: Mon, 01 December 2014, 12:10:45 »
The issue with the series 9 is there is no discrete gpu. Integrated won't get you far if you're planning on gaming (unless it's an iris pro)
Offline luisbg
« Reply #10 on: Mon, 01 December 2014, 12:17:33 »
That's true. They have integrated GPUs.
Offline ezrahilyer
« Reply #11 on: Mon, 01 December 2014, 12:23:09 »
I didn't know they bought the thinkpad line, I always figured they were just a spinoff of IBM, still I liked the Thinkpads, had several of them. Its too bad about the quality going down. I have not owned a lenovo since my last thinkpad (about 2005 or 2006)
Offline luisbg
« Reply #12 on: Mon, 01 December 2014, 12:29:51 »
Lenovo is a Chinese company that has been around since the mid 80's.
The previous company I worked for used to be a big Thinkpad shop. All software engineers/management had Thinkpads without hesitation. Since 2012 they've slowly grown tired and most have switched to some other vendor.
I agree with you. Thinkpads used to be the best made laptops (and best keyboard/trackpoint interface), sad they haven't kept it up.
Offline AFKfapping
« Reply #13 on: Sat, 06 December 2014, 02:44:50 »
I just got one of the new ASUS zenbooks, the portability and power is so satisfying especially with 2 128gb ssd's running striped
Offline luisbg
« Reply #14 on: Sat, 06 December 2014, 05:26:00 »
What is the resolution of the screen? Can't find that information online.
Offline minh278
  • In life we will only fall, How far will we fall?
« Reply #15 on: Mon, 08 December 2014, 22:01:56 »
Look into getting a 970m should perform better than an 880m i think they are still round the same price. You could look into a clevo or sager rebrand though people consider them ugly. I do not recommend laptop gaming due to laptops do not have proper heat dispersion and shorten the part lifespan(mostly the battery due to exposing the lipo to high heat ranges) but an clevo, asus rog, msi, alienware usually are better at heat dispersion. Remember the thinner the laptop is the more it is unsuited for gaming.
Keyboards:  Final Fantasy XI XIth Anniversary keyboard (topre 45g) | Realforce Rgb (topre 45g, Eva Noctilucous keyset) | Mionix Zibal 60 (mx black, Vortex doubleshot) | Greymark (white alps) | IBM model M (found in the trash!)
